ĐỘNG CƠ V8 CỦA HYUNDAI LÀ PHIÊN BẢN CỦA MITSUBISHI CỦA NHẬT BẢN CÓ KỲ NỔ LÀ 1-5-4-2-6-3-7-8.
THÌ NỔ CỦA ĐỘNG CƠ DOOSAN V8 GẮN TRÊN XE DAEWOO LÀ 1-5-7-2-6-3-4-8. DÃY MÁY BÊN TRÁI (TÀI) LÀ 1234, BÊN PHỤ (PHẢI) LÀ 5878.
* NẾU BẠN CHƯA BIẾT THỨ TỰ KỲ NỔ THÌ CÁCH TÌM KỲ NỔ CHO ĐỘNG CƠ V8 NHƯ SAU:
- ĐỐI VỚI ĐỘNG CƠ 4 THÌ KHI TRỤC KHUỶU QUAY GIÁP VÒNG KỲ NỔ LÀ 720 ĐỘ.
- 720 ĐỘ/ 8 = 90 ĐỘ.
BƯỚC 1: BẠN HÃY XÁC ĐỊNH MÁY SỐ 1 NẰM Ở BÊN TRÁI HAY BÊN PHẢI? (TAY BIÊN NẰM TRƯỚC TIÊN ĐẦU TRỤC KHUỶU NẾU GẮN LIỀN VỚI PISTON BÊN TRÁI LÀ SỐ 1 NẰM BÊN TRÁI... VÀ NGƯỢC LẠI...). VÍ DỤ Ở ĐÂY BẠN ĐÃ XÁC ĐỊNH ĐƯỢC PISTON SỐ 1 NẰM BÊN TRÁI. NHƯ VẬY TA CÓ KẾT QUẢ DÃY MÁY BÊN TRÁI LÀ 1,2,3,4 VÀ BÊN PHẢI LÀ, 5,6,7,8.
BƯỚC 2: BẠN QUAY TRỤC KHUỶU CHO MÁY SỐ 1 ĐÊN ĐIỂM CHẾT TRÊN (ĐCT), DÙNG QUE THĂM NHỚT KIỂM TRA ĐẦU PISTON LÀ BIẾT. LÚC ĐÓ BẠN LÀM DẤU TRÊN THƯỚC NHỚT ĐỂ KIỂM TRA VÀ XÁC ĐỊNH ĐCT CỦA CÁC PISTON CÒN LẠI. SAU ĐÓ BẠN DÙNG THƯỚC NHỚT ĐỂ KIỂM TRA CÁC PISTON DÃY MÁY BÊN PHẢI XEM PISTON NÀO CÙNG SONG HÀNH LÊN ĐCT CÙNG MÁY 1 (VỀ NGUYÊN TẮC PISTON CÙNG SONG HÀNH LÀ MÁY 1-6; 2-8; 3-5; 4-7). VẬY Ở ĐÂY MÁY 6 SONG HÀNH CÙNG MÁY 1, TA KIỂM TRA MÁY SỐ 6 SUPAP XẢ VỪA ĐÓNG VÀ SUPAP HÚT VỪA CHỚM MỞ ĐỂ XÁC ĐỊNH ĐƯỢC MÁY 1 ĐANG Ở KỲ NỔ.
BƯỚC 3: BẠN QUAY TRỤC KHUỶU THEO CHIỀU MÁY CHẠY ĐÚNG 90 ĐỘ, SAU ĐÓ DÙNG THƯỚC NHỚT ĐỂ KIỂM TRA ĐẦU PISTON CỦA 2 MÁY SONG HÀNH ĐANG Ở ĐCT, RỒI KIỂM TRA SUPÁP CỦA 2 MÁY ĐÓ XEM MÁY NÀO SUPAP ĐANG Ở TRẠNG THÁI TỰ DO LÀ XÁC ĐỊNH MÁY ĐÓ LÀ KỲ NỔ KẾ TIẾP.
CỨ VẬY, BẠN QUAY TIẾP TRỤC KHUỶU ĐÚNG 40 ĐỘ KIỂM TRA TIẾP ĐỂ XÁC ĐỊNH THỨ TỰ KỲ NỔ ĐẾN MÁY CUỐI CÙNG.
CHÚC BẠN THÀNH CÔNG. THÂN!
