Cách đo áp suất buồng đốt?
phong38
Bình luận: 30Lượt xem: 11,270
maquina
1-Apague el encendido y el sistema de inyección de combustible antes de realizar una prueba de compresión. La mayoría de los fabricantes recomiendan calentar el motor durante la prueba 1
2-Place the throttle plate in a fully open position to allow an unlimited amount of air to enter the cylinders during the test
3-Remove all spark plugs from the engine
4-Connect a remote start button to the boot system
5-There are many types of compression gauges available. The type of screw tends to be the most accurate and easy to use
6-Carefully install the meter in the spark plug hole of the first cylinder
7-Connect a battery charger to the car to allow the engine to start at constant and normal speeds needed to obtain accurate test results
8-Press the remote start button and observe the indicator reading after the first revolution of the engine
9-Allow the engine to rotate four revolutions and observe the reading after the fourth. The reading should increase with each revolution
10-Observed readings must be recorded. After all the cylinders have been tested, a comparison of the cylinders can be made
11-Before removing the meter from the cylinder, release the pressure from the cylinder using the meter release valve
12-Each cylinder must be tested in the same way
13-After completing the test on all cylinders, compare them. If one or more cylinders are much lower than the others, continue testing those cylinders with the wet test
14-Pour a small amount of oil into the weak cylinder (s)
15-Reinstall the compression gauge on that cylinder and perform the test
16-If the reading increases with the presence of oil in the cylinder, the most likely cause of the low original readings was a poor sealing of the piston ring. Using oil during a compression test is usually called a wet test
Bác viết gì vậy ạ, xem không hiểu? Chắc là tiếng Pháp
Nguyễn Xuân Giang
Giữ xe
where do you live?
