hieu_198989
xe em khi mở công tắc đề máy thì xuất hiện đèn báo check động cơ . khi máy nổ rồi thi đèn không tắt cứ sáng liên tục . các anh cho em hỏi xe em nó bị gì ? em ở tp biên hòa nếu muốn sửa lỗi đó thì phải đến chổ nào ?
CỤ ĐỌC ĐƯỢC FLASH CODE RỒI THÌ SO SÁNH VỚI CÁI NÀY LÀ RA LỖI CỤ Ạ
2009 > D6CB > Fuel System > DTC Troubleshooting Procedures > Troubleshooting
DTC LIST
No
DTC
FLASH CODE
DESCRIPTION
REMARKS
1
P0105
1121
AMBIENT PRESSURE SENSOR FAULT
FL-29
2
P0112
1112
AIR TEMPERATURE SENSOR LOW INPUT
FL-32
3
P0113
1113
AIR TEMPERATURE SENSOR HIGH INPUT
FL-40
4
P0117
1312
COOLANT TEMPERATURE SENSOR LOW INPUT
FL-50
5
P0118
1313
COOLANT TEMPERATURE SENSOR HIGH INPUT
FL-56
6
P0119
1314
HIGH COOLANT TEMPERATURE MALFUNCTION
FL-63
7
P0182
1332
FUEL TEMPERATURE SENSOR LOW INPUT
FL-69
8
P0183
1333
FUEL TEMPERATURE SENSOR HIGH INPUT
FL-76
9
P0191
1321
FUEL PRESSURE MALFUNCTION
FL-85
10
P0192
1322
FUEL PRESSURE SENSOR LOW INPUT
FL-90
11
P0193
1323
FUEL PRESSURE SENSOR HIGH INPUT
FL-101
12
P0196
1232
AIR PRESSURE SENSOR LOW INPUT
FL-111
13
P0197
1233
AIR PRESSURE SENSOR HIGH INPUT
FL-121
14
P0198
2222
ECU INTERNAL TEMP. SENSOR FAULT
FL-129
15
P0335
2121
CRANK SENSOR FAULT
FL-131
16
P0336
2122
CRANK SYNCHRONIZATION ERROR
FL-145
17
P0337
2123
CRANK HIGH FREQUENCY ERROR
FL-156
18
P0340
2111
CAM SENSOR FAULT
FL-166
19
P0341
2112
CAM SYNCHRONIZATION ERROR
FL-179
20
P0342
2113
CAM HIGH FREQUENCY ERROR
FL-189
21
P0500
0510
AIR PRESSURE MALFUNCTION
FL-199
22
P0501
5211
VEHICLE SPEED SENSOR HIGH FREQUENCY ERROR
FL-202
23
P0503
5212
VEHICLE SPEED SENSOR FAULT
FL-218
24
P0511
5111
IDLE SWITCH 1 FAULT
FL-234
25
P0513
5113
IDLE SWITCH 2 FAULT
FL-243
26
P1149
1212
PEDAL SENSOR LOW INPUT
FL-252
27
P1150
1213
PEDAL SENSOR HIGH INPUT
FL-261
28
P1211
3111
INJECTOR 1 OPEN CIRCUIT
FL-268
29
P1212
3112
INJECTOR 1 SHORT CIRCUIT
FL-276
30
P1213
3113
INJECTOR 1 LOW SHORT TO GROUND
FL-285
31
P1214
3114
INJECTOR 1 LOW SHORT TO BATTERY
FL-292
32
P1215
3115
INJECTOR 1 HIGH SHORT TO GROUND
FL-298
33
P1216
3116
INJECTOR 1 HIGH SHORT TO BATTERY
FL-305
34
P1221
3121
INJECTOR 2 OPEN CIRCUIT
FL-312
35
P1222
3122
INJECTOR 2 SHORT CIRCUIT
FL-321
36
P1223
3123
INJECTOR 2 LOW SHORT TO GROUND
FL-330
37
P1224
3124
INJECTOR 2 LOW SHORT TO BATTERY
FL-336
38
P1225
3125
INJECTOR 2 HIGH SHORT TO GROUND
FL-342
39
P1226
3126
INJECTOR 2 HIGH SHORT TO BATTERY
FL-349
40
P1231
3131
INJECTOR 3 OPEN CIRCUIT
FL-356
41
P1232
3132
INJECTOR 3 SHORT CIRCUIT
FL-365
42
P1233
3133
INJECTOR 3 LOW SHORT TO GROUND
FL-374
43
P1234
3134
INJECTOR 3 LOW SHORT TO BATTERY
FL-380
44
P1235
3135
INJECTOR 3 HIGH SHORT TO GROUND
FL-386
45
P1236
3136
INJECTOR 3 HIGH SHORT TO BATTERY
FL-393
46
P1241
3141
INJECTOR 4 OPEN CIRCUIT
FL-400
47
P1242
3142
INJECTOR 4 SHORT CIRCUIT
FL-408
48
P1243
3143
INJECTOR 4 LOW SHORT TO GROUND
FL-417
49
P1244
3144
INJECTOR 4 LOW SHORT TO BATTERY
FL-423
50
P1245
3145
INJECTOR 4 HIGH SHORT TO GROUND
FL-429
51
P1246
3146
INJECTOR 4 HIGH SHORT TO BATTERY
FL-436
52
P1251
3151
INJECTOR 5 OPEN CIRCUIT
FL-443
53
P1252
3152
INJECTOR 5 SHORT CIRCUIT
FL-451
54
P1253
3153
INJECTOR 5 LOW SHORT TO GROUND
FL-460
55
P1254
3154
INJECTOR 5 LOW SHORT TO BATTERY
FL-466
56
P1255
3155
INJECTOR 5 HIGH SHORT TO GROUND
FL-472
57
P1256
3156
INJECTOR 5 HIGH SHORT TO BATTERY
FL-479
58
P1261
3161
INJECTOR 6 OPEN CIRCUIT
FL-486
59
P1262
3162
INJECTOR 6 SHORT CIRCUIT
FL-494
60
P1263
3163
INJECTOR 6 LOW SHORT TO GROUND
FL-503
61
P1264
3164
INJECTOR 6 LOW SHORT TO BATTERY
FL-509
62
P1265
3165
INJECTOR 6 HIGH SHORT TO GROUND
FL-515
63
P1266
3166
INJECTOR 6 HIGH SHORT TO BATTERY
FL-522
64
P1311
3311
INJECTOR 1 BALANCE ERROR
FL-529
65
P1321
3321
INJECTOR 2 BALANCE ERROR
FL-536
66
P1331
3331
INJECTOR 3 BALANCE ERROR
FL-543
67
P1341
3341
INJECTOR 4 BALANCE ERROR
FL-550
68
P1351
3351
INJECTOR 5 BALANCE ERROR
FL-557
69
P1361
3361
INJECTOR 6 BALANCE ERROR
FL-564
70
P1523
5233
BATTERY VOLTAGE HIGH ERROR
FL-571
71
P1524
5234
BATTERY VOLTAGE LOW ERROR
FL-576
72
P1525
5235
BATTERY OVER VOLTAGE MALFUNCTION
FL-581
73
P1600
5611
ISO COMMUNICATION ERROR
FL-586
74
P1613
4444
ECU MALFUNCTION
FL-595
75
P1616
3224
ECU POWER RELAY ERROR
FL-610
76
P1618
4112
PEDAL SENSOR 5V SUPPLY ERROR
FL-621
77
P1619
4121
AIR PRESSURE 5V SUPPLY ERROR
FL-630
78
P1640
5612
CAN COMMUNICATION ERROR
FL-638
79
P1651
3211
CHECK ENGINE LAMP DRIVE FAULT
FL-644
80
P1652
3212
OVERHEAT LAMP DRIVE FAULT
FL-650
81
P1653
3213
ENG BRAKE INDICATE LAMP DRIVE FAULT
FL-657
82
P1654
3214
EXHAUST BRAKE DRIVE FAULT
FL-664
83
P1655
3215
ENG BRAKE LO/HI DRIVE FAULT
FL-670
84
P1656
3216
ENG BRAKE MED/HI DRIVE FAULT
FL-676
85
P1657
3221
AIR HEATER INDICATE LAMP DRIVE FAULT
FL-682
86
P1658
3222
AIR HEATER SUB RELAY DRIVE FAULT
FL-687
87
P1659
3223
CRS/RSG/PTO INDICATE LAMP DRIVE FAULT
FL-694
88
P1999
1266
AIR HEATER MALFUNCTION
FL-699
89
P2149
2212
REMOTE PEDAL SHORT TO GROUND
FL-710
90
P2150
2213
REMOTE PEDAL OPEN/SHORT
FL-719
Ban kiem tra loc dau co ban va co nuoc hay khong, xong roi ban thao coc am ac quy khoag 15phut roi lap lai, neu den bao check van bao thi ban nen keu tho den kiem tra
Có thể kiểm tra mã lỗi qua đèn CHECK ENGINE sau đó tra bảng mã lỗi (có 4 số)xe em khi mở công tắc đề máy thì xuất hiện đèn báo check động cơ . khi máy nổ rồi thi đèn không tắt cứ sáng liên tục . các anh cho em hỏi xe em nó bị gì ? em ở tp biên hòa nếu muốn sửa lỗi đó thì phải đến chổ nào ?
là làm sao bạn .tôi mới qua chạy con này nên không biết nhiều . xin bạn hướng dẫn tận tình . thankCó thể kiểm tra mã lỗi qua đèn CHECK ENGINE sau đó tra bảng mã lỗi (có 4 số)
Làm thao tác như sau:
- Bật chìa khóa ON, không nổ máy. - ấn và giữ SET/INC hoặc RES/DEC khoảng 3 giây, đèn CHECK ENGINE sẽ chớp. Khi đèn chớp sẽ đọc mã lỗi (4 chữ số): hàng ngàn, hàng trăm, hàng chục và đơn vị (khoảng thời gian nghỉ giữa hàng ngàn, hàng trăm, hàng chục và đơn vị dài hơn và bằng nhau). Ví dụ: Mã lỗi 1333 thì đèn sẽ chớp 1 lần rồi nghỉ 1 lúc, sau đó chớp 3 lần lại nghỉ 1 lúc, tiếp đến chớp 3 lần rồi nghỉ 1 lúc, cuối cùng chớp 3 lần rồi nghỉ dài hơn và chuyển sang báo mã lỗi khác. Mã lỗi 1333 báo trục trặc ở khu vực cảm biến nhiệt độ nhiên liệu.
bác cho em hỏi là 2 chữ SET/INC or RES/DEC nằm ở chỗ nào ạ. em chưa biết mong bác chỉ giúp ạLàm thao tác như sau:
nối tắt TE1 với E1.cái đó là OBDI cụ ạ.giờ mấy dòng đời cao thì không áp dụng đượcCác bác cho em hỏi là Cách check lỗi bằng đèn như thế này có áp dụng được với các dòng xe khác không ạ??? Ví dụ D6CA, D6CB... trên xe bus đó ạ
P/s: Em nhớ lúc trước học thì có nghe nói đối với dòng TOYOTA thì để kiểm tra người ta nối tắt chân gì gì đó trong cái giắc kiểm tra. có đúng không các bác nhỉ![]()
hình như cụ có tài liệu của huyndai phải không..có thể share mình ít được không.NHÀ CHÁU NGHĨ XE CỦA CỤ ĐỜI CAO THẾ THÌ HẲN ÍT LỖI LẮM CỤ LÊN KIỂM TRA CÁI LỌC DẦU DIEZEN XEM CÓ VẤN ĐỀ GÌ KHÔNG.
CỤ TẮT CHÌ KHÁO THÁO CỰC ÂM ẮC QUY RA ĐỂ 30 GIÂY SAU ĐÓ LẮP LẠI NỔ MÁY LÊN XEM CÓ MẤT ĐÈN CHECK KO NẾU MẤT NHÀ CHÁU NGHĨ LÀ DO LỌC TẮC LÊN BÁO LỖI.
CÒN KHÔNG NHÀ CHÁU GỬI CỤ CÁI CÁCH ĐỌC LỖI THỦ CÔNG NHƯ SAU Ạ
