Trọn Bộ Full Giáo Trình Catia V5
F
Bình luận: 3Lượt xem: 6,391
FujiTran
Giáo Trình Catia Pro - Let's Learn Catia Video Tutorials
Catia Pro - Let's Learn Catia Video Tutorials | 15.36 GB
CATIA is the leading modelling package in the world with huge number of tools and abilities. Learning such a package requires plenty of time and serious effort to enable you to master its use at the required level with sufficient knowledge and understanding of the package. It is not easy to find a comprehensive and easy way to understand the CATIA package and be competent in using it.
Standalone Course contains over 730 fully illustrated tutorials (Video Format) with more than 33 hours of play time.Is a Multimedia Training Package (Video+Audio Narration) With All Possible Features That Make Learning Fun And Easy.It is your best opportunity to be a professional in CATIA within very short time
MAGNITUDE ENGINEERING SOLUTIONS CATIA V5 VIDEO
Magnitude Engineering Solutions Catia V5 Video Tutorial-FoRTuNe | ISO | 1.91 GB
Learn the basic and advanced features of Catia V5 step by step with the Catia V5 Tutorial DVD by Magnitude Engineering Solutions. The DVD plays instantly on your computer and comes with its own menu and media player so there is no instillation required. Just insert the DVD and choose what lesson you want from the menu. You're able to play pause rewind or fast forward at anytime giving you the flexibility to learn at your own individual pace. These tutorials are made by industry professionals who will give you the tools to learn and master Catia V5 quickly and easily. This Catia V5 Tutorial is applicable to all versions of Catia V5 and comes with everything listed below.
135 Video Tutorials
Project part files required to follow the tutorials
Screen Resolution of 1280 x 800
Audio narration for each tutorial from start to finish
Sample projects
CATIA V5 Video Tutorial. DESIGN & CNC TOOLPATH
English | AVI | Camtasia | 1680x1048 | 1063 kb/s | 15.00 fps | PCM 22050Hz mono 352Kbps | 8.59 GB
Genre: eLearning
24 Hours Total of concentrated intensive Training (11 Hours of Audio narration + 13hrs of advanced samples). This tutorial has what it takes for you to become a CATIA V5 professional. Our DVDs are super easy to follow and will help you to become a CATIA programmer and a designer at a super fast rate. These DVDs will greatly minimize the time it takes for you to Master Catia Software. Our complete tutorial is design to accommodate any level of prior Catia experience. It will be a great learning tool for a beginner, and will also be a great resource for an advance programmer. This training in a classroom will cost you around $5,000 for 2 weeks. This is a great deal that will provide you with a lot more information than any school.
Sketcher
1. Entering the Sketcher Workbench
2. Becoming Familiar with the Interface
3. Sketching from a New Part
4. Creating Simple Geometry
5. Applying Constraints
6. Analyzing Sketches
7. Modifying sketches
8. Creating a Pad
9. Sketching from an Existing Part
10. Creating a Positioned Sketch
11. Using the Normal View
12. Cutting the Part by the Sketch Plane
13. Setting the Datum Mode
14. Modifying an Output Feature
15. Before You Begin
16. Using the Sketcher Grid
17. Using Tools for Sketching
18. Using Colors
19. Cutting the Part by the Sketch Plane
20. Defining a Visualization Mode for Sketcher Elements
21. Defining a Visualization Mode for Wireframe Elements
22. Converting Standard/Construction Elements
23. Hiding or Showing the Sketch Absolute Axis
24. Entering the Sketcher Workbench
25. Creating a Positioned Sketch
26. Changing a Sketch Support
27. Sketching Simple Profiles
28. Creating Profiles
29. Creating Rectangles
30. Creating Circles
to 120
Part Design
121. Using Surfaces and Curves
122. Joining Surfaces or Curves
123. Extrapolating Surfaces
124. Extracting Geometry
125. Creating Intersections
126. Creating Projections
127. Creating Boundaries
128. Entering the Part Design Workbench
129. Creating a Pad
130. Drafting a Face
131. Filleting an Edge
132. Editing the Pad
133. Mirroring the Part
134. Sketching a Circle from a Face
135. Creating a Pocket
136. Shelling the Part
137. Opening a New CATPart Document
138. Sketch-Based Features
139. Creating Pads
140. Using the Sub-Elements of a Sketch
141. Creating Up to Next Pads
142. Creating Up to Last Pads
143. Creating Up to Plane Pads
144. Creating Up to Surface Pads
145. Creating Pads or Pockets from Surfaces
146. Creating Pads Not Normal to Sketch Planes
147. Creating Multi-Pads
148. Creating Drafted Filleted Pads
149. Creating Pockets
150. Creating Multi-Length Pockets
to 256
Assembly Design
257. Entering Assembly Design Workbench and Opening a CATProduct Document
258. Fixing a Component
259. Inserting an Existing Component
260. Setting Constraints Between Components
261. Moving Constrained Components Using the Compass
262. Adding and Renaming a New Component
263. Designing a Part in an Assembly Context
264. Editing a Parameter
265. Replacing a Component
266. Analyzing Assembly Constraints
267. Reconnecting a Broken Constraint
268. Detecting Clashes
269. Editing a Component
270. Exploding the Assembly
271. Creating an Assembly Document
272. Updating an Assembly
273. Analyzing an Assembly
274. Defining a Multi-Instantiation
275. Fast Multi-Instantiation
276. Inserting an Existing Component with Positioning
277. Managing Constraints
278. Moving Components
279. Translating Components
280. Rotating Components
to 535 more.
Catia Training Manuals & Exercises
Genre: eLearning
GESAB Books
-Basic Fundamentals Book 1
-Basic Fundamentals Book 2
-Detail Drafting
-Detail drafting Exercise guide
-Detail for Dummies
-Expert Mechanical Book 1
-Expert Mechanical Book 2
-Surfacing
Unico Books
-Advanced Surface Design Exercises
-Advanced Surface Design Theory Part_1_2_3
-Complementary Course Surface Design 1-2
-Complimentry Course Solid Design Excersises
-Basics Course General Exercises 1-2
-Basics Course General Exercises 2-2
-Basics design theory
Exercises
General Course
-Exercises assembly
-Exercises curve and surface
-Exercises drawing
-Exercises dress up features
-Exercises hybrid modeling
-Exercises sketch based features
-Exercises sketcher
Solid Course
-Exercises boolean operations
-Exercises dress up
-Exercises hybrid
-Exercises modifying
-Exercises pattern
-Exercises sketcher
Surface Course
-Exercises curves
-Exercises operations
-Exercises surfaces
Trọn Bộ DVD - 200k, pm me if you need:
TrainingCourse8668@gmail.com
DT: 01225523847
