[Tài Liệu] - GearTrax, CamTrax
C
Bình luận: 5Lượt xem: 11,345
Ctrl+C
Hai Add-ins hỗ trợ vẽ bánh răng và cam trong Solidworks. Khá hay
GearTrax™ provides the designer with an easy to use tool for creating solid models of drive components. Create spur, helical, straight bevel and involute splines with true involute tooth profiles.
GearTrax™ is intuitively easy to use for the designer with limited gear experience yet powerful enough for the gear expert. The animation window shows the spur/helical gear mesh which updates as the data is changed. It is extremely useful in understanding how changes to the gear parameters reflects on the gear mesh.
GearTrax™ is more than a library program. Each part model is created with it's specific requirements just as a designer would, but rather than taking hours or days, the part is created in seconds. GearTrax creates solid models of spur and helical gears, bevel gears, worm gears, involute splines, timing belt pulleys, chain sprockets and V-belt pulleys. GearTrax™ also integrates with Excel to create data sheets.
CamTrax™ helps the designer create solid models of virtually every type of cam with the dynamic motion control parameters your system requires. During the design, CamTrax™ generates charts when linked with Excel and adds a profile list to your drawing. Camnetics, Inc. is dedicated to providing the design engineer with accessible software for developing high speed machine cams!
CamTrax™ standard cam types include cylindrical cams, plate (aka disk) cams and linear cams. Choose the follower type that the design requires; on center translating, off center translating, swinging arm and flat-faced reciprocating. Selecting different motion synthesis is a snap with CamTrax. Choose between virtually any standard cam motion with a couple mouse clicks. With Excel the designer can analyze the cam motions and compare different motion synthesis. Don't have Excel? Output can also be to a text file! Charted are displacement, velocity, acceleration, pressure angle, cam shaft torque, radius of curvature, contact stress and normal force.
"I really like your software package... Cams have never been so much fun to design. Software like this is a consultants dream. Thank you very much. " Michael Asher, Sr. Mechanical Engineer, MagneVu
Link:
Geartrax:
http://www.mediafire.com/?ntjyk2jmnf0
Camtrax:
http://www.mediafire.com/?dmmzg024ndy
Hướng dẫn cài đặt [Bản 2006 - 2007]
- Với geartrax2006 và 2007, không cần chạy file ***** nào hết, có cách sau:
Bật Geartrax lên, nó đòi đăng ký, tại ô nhập thứ nhất, có 4 lựa chọn( bấm mũi tên trải xuống bên phải là thấy ngay): Use the SolidWorks serial number, Create a serial number for this computer to work with the SNL (GTSW#), Use a AKS HASP (for GearTrax station HASP users only), Use a AKS NetHASP (for GearTrax network license users only). Chọn cái thứ hai.
- Tại ô nhập thứ 2, nhập vào "0000 0000" ( tám số không, sau 4 số có dấu cách ở giữa). Bấm OK, rồi Accept là được. Chớ nên chọn Registration, 749 USD một bản, uống trà đá mấy năm mới hết.
cu ti ti
Minh cai roi , nhung minh xai Solidwork 2010 , khi chay geartrax 2009 va camtrax 2009 thi solidworks 2010 bao la khong the chay eartrax 2009 , vay bac co geartrax va camtrax 2010 thi cho minh xin . cam on nhieu
khoadongluc
Nothing Is Impossible
Camnetics GearTrax v2010 180.642
Camnetics GearTrax v2010 180.642 | 10 MB
Camnetics GearTrax™ provides the designer with an easy to use tool for creating solid models of drive components. Create spur, helical, straight bevel and involute splines with true involute tooth profiles. GearTrax™ is intuitively easy to use for the designer with limited gear experience yet powerful enough for the gear expert. The animation window shows the spur/helical gear mesh which updates as the data is changed. It is extremely useful in understanding how changes to the gear parameters reflects on the gear mesh. GearTrax™ is more than a library program. Each part model is created with it's specific requirements just as a designer would, but rather than taking hours or days, the part is created in seconds. GearTrax creates solid models of spur and helical gears, bevel gears, worm gears, involute splines, timing belt pulleys, chain sprockets and V-belt pulleys. GearTrax™ also integrates with Excel to create data sheets.
Features:
• Intuitive and simple, yet powerful!
• Diametral and Module pitches
• International standards supported
• Plastic gear standards
• True involute tooth profiles
• Automatic addendum modification
• User control of all gear properties
• Mounting hubs and counter bores
• ANSI and BS metric keyway options
• Very affordable
Point and Click to Create:
• Spur and Helical Gears
• Internal Gear Sets
• Bevel Gear Sets
• Worm Gears
• Involute Splines
• Timing Belt Pulleys
• Chain Sprockets
• V-Belt Pulleys
• 100's of Mounting Styles
Hotfile.com: One click file hosting
b1u3eyes.Camnetics.GearTrax.rar - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
cu ti ti
Cam on minh da dơnload duoc camtrax 2010 roi. khoadongluc oi ! cho minh hoi cach be track camtrax 2010 khi minh mo keygen ra thi no la keygen 2008 , khong phai keygen2010 , xin khoadongluc chi minh cach be track camtrax 2010 , minh cai soliwork 2010 so se rial number la : 0001 0001 0736 0361 JK3Q HDJ3
xin ban huong dan cu the mot chut . Cam on rat nhieu
