thehienoto
Cần xem lại chút bạn ạ:single best indicator... nên dịch là thông số đơn biểu thị rõ nhất cho chất lượng tia phun(chất lượng phun).bác xem em dịch đoạn dưới này có đúng không:
The SMD may not, in fact, be the single best indicator of the spray quality required for the GDI engine, as a very small percentage of large droplets is enough to degrade the engine UBHC emissions even though the SMD may be quite small. Each 50 μm fuel droplet in a spray having a SMD of 25 ~m not only has eight times the fuel mass of the mean droplet, but will remain as liquid long after the 25 μm drop has evaporated. In fact, when all of the 25 μm droplets are evaporated, the original 50 μm droplets will still have a diameter of 47 μm. An injector that delivers a well-atomized spray, but which has a wide spread in the drop-size distribution may require an even smaller SMD than quoted above to operate satisfactorily in a GDI engine combustion system. This spread may be quantified by the parameter of DV90-DV 10. It is conjectured by the authors th~.t DV90 may be a parameter that is superior to SMD (D32) in correlating the UBHC emissions of different fuel sprays in GDI combustion systems. When examining the result in Fig. 5(c) which shows a comparison of the droplet size distributions between swirl-type and hole-type high pressure fuel injectors [60], it is clear that even though the difference in the mean droplet size (SMD) between the sprays from these two injectors is only 4 μm, the hole type nozzle produces a wider droplet-size distribution having many larger droplets that are theorized to be responsible for the observed increase in the UBHC emissions. It should be noted that the use of finer atomization may or may not reduce the UBHC emissions, depending upon the incylinder turbulence level, due to small pockets of very lean fuel-air mixtures [75-77,348]. A strong turbulence level in the combustion chamber is required to enhance the fuel-air mixing process by eliminating small pockets of very lean mixture. An important point to consider is that the increased droplet drag that is associated with finer atomization reduces the spray penetration, which can degrade air utilization.
Đường kính của hạt có thể là không,trên thực tế là chỉ số chất lượng phun tốt chất cho động cơ GDI,bởi vì với một phần trăm rất nhỏ các hạt nhiên liệu nhỏ này cũng đủ để giảm lượng khí thải mặc dù kích thước hạt khá nhỏ. Mỗi 50 μm hạt nhiên liệu trong một tia phun có đường kính trung bình của hạt là 25 μm không phải chỉ có tám lần khối lượng nhiên liệu của hạt, nhưng vẫn là chất lỏng sau khi 25 μm hạt đã bốc hơi. Trong thực tế, khi tất cả 25μm bốc hơi, trong 50 μm hạt vẫn sẽ có một đường kính 47 μm. Một vòi phun cung cấp sự phun sương tốt, nhưng có sự mở rộng trong sự phân bố kích thước hạt có thể cần SMD nhỏ hơn so với yêu cầu quá trình cháy động cơ GDI tối hơn.sự phân bố(mở rộng) này được định lượng bằng các tham số DV90-DV10. Khi kiểm tra các kết quả hình. 5 (c) trong đó cho thấy sự so sánh của các kích thước hạt giữa kiểu xoáy và lỗ phun áp suất nhiên liệu cao [60], rõ ràng là mặc dù sự khác biệt trong kích thướchạt trung bình (SMD) giữa các loại kim phun chỉ có 4 μm, vòi phun kiểu lỗ tạo ra một qui mô phân bố hạt rộng hơn có nhiều hạt hơn nên việc tạo ra khí thải nhiều hơn.cần lưu ý rằng việc phun sương tốt hơn có thể có hoặc không giảm được lượng khí thải UBHC,điều này còn phụ thuộc vào mức độ dòng xoáy trong xi lanh,vì các túi khí nhỏ của hỗn hợp hòa khí nghèo(due to small pockets of very lean fuel-air mixtures [75-77,348]).mức độ dòng xoáy càng mạnh trong buồng đốt thì việc hòa trộn hỗn hợp càng tốt hơnlà cần thiết bằng cách loại bỏ các túi nhỏ của hỗn hợp nghèo(smaller pocket). Một điểm quan trọng cần xem xét là lực kéo hạt sẽ giúp phun sương tốt hơn, làm giảm sự xâm nhập phun, có thể làm giảm việc sử dụng không khí.
Each 50 μm fuel droplet in a spray having a SMD of 25 ~m not only has eight times the fuel mass of the mean droplet, but will remain as liquid long after the 25 μm drop has evaporated:
Nên dịch là: Mỗi một hạt nhiên liệu 50μm trong tia phun có đường kính hạt trung bình là 25μm không chỉ có khối lượng gấp 8 lần khối lượng các hạt chính(hạt chủ yếu) mà còn ở trạng thái lỏng khi hạt nhiên 2525μm đã hóa hơi.
Bạn xem lại trật tự từ chút.
