Camry 2007 bệnh lạ
Bình luận: 6Lượt xem: 971
vantrung178
xe này của bác dự là cơ cấu khóa cửa có vấn đề(tôi xem mạch cả 4 cơ cấu khóa cửa đều được đấu song song với nhau như vậy bị hộp điều khiển khó có thể xảy ra)
TunhanDo
Remote lock cửa thì cả 4 cửa đều khoá, khi mở thì chỉ mở đc cửa tài, 3 cửa kia mở lúc được lúc ko. Vậy là hư hộp khiển hả các bác?
System Outline
Door lock control (Lock and unlock) and panic control (Theft alarm and flash) is performed by remote control, without the ignition key inserted in the door key cylinder, using low power electrical waves emitted by a transmitter.
1. Wireless Door Lock or Unlock Normal Operation
With the ignition key not inserted into the ignition key cylinder (Unlock warning SW off) and all the doors completely closed, when the lock or unlock button (Transmitter) is pushed, the door control receiver receives the electrical waves from the transmitter, and sends a signal to the main body ECU, causing it to operate.
As a result, the main body ECU judges whether the door is locked or unlocked based on the signal from the door lock motor and door unlock detection SW, and sends a signal to switch the condition from lock to unlock or vice versa, causing the door lock motor to operate.
2. Visual Confirmation of Lock or Unlock
If all doors indicate that they are locked after the lock command, turn signal light will flash once. If any door indicates that it is open after the unlock command, turn signal light will flash twice.
3. Buzzer Sound Function
If all doors indicate that they are locked after the lock command, the keyless buzzer goes on once. If any door indicates that it is open after the unlock command, the keyless buzzer goes on twice.
4. Illuminated Entry Function
When the main body ECU detects the unlock state after the unlock operation has been made, it turns on the lights, such as the ignition key cylinder light and interior light for approx. 15 sec. If all the doors are locked during this operation, lighting is cancelled and the lights immediately fade out.
5. Wireless Door Unlock Operation
Pushing the unlock button (Transmitter) once, driver's door is unlocked. Furthermore, pushing the button again within 3 seconds, the other doors are unlocked.
6. Automatic Lock Operation
With the ignition key not inserted into the ignition key cylinder (Unlock warning SW off) and all the doors completely closed, after pushing the button (Transmitter) to unlock all the doors, if a door is not opened within 30 seconds, all the doors will be automatically relocked.
7. Wireless Control Stop Function
If a door is open (Door courtesy SW on), a signal is input from the door courtesy SW to the main body ECU stopping wireless door lock or unlock.
If the ignition key is in the ignition key cylinder (Unlock warning SW on), the unlock warning SW inputs a signal to the main body ECU stopping wireless door lock or unlock.
8. Repeat Function
If the door lock or unlock condition does not change after wireless door lock or unlock operation, 2 seconds later, the main body ECU sends current again to the door lock motor.
9. Remote Panic Operation
Panic will function when doors are locked or unlocked, open or closed. When the panic button (Transmitter) is pushed once, theft alarm and horn sounds and turn signal light, headlights and taillight flash. Then, the panic or the unlock button (Transmitter) is pushed once more, sounding and flashing will stop. Panic will not function when ignition key is in ignition key cylinder.
Bác trên giải thích rồi bác ơi, nhấn unlock 1 lần thì chỉ cửa tài mở, nhấn thêm lần nữa trong 3s sẽ mở all cửa. Chắc xe zin nó vậy em ko biết
Tất nhiên là tôi biết tính năng đó. Nhưng nếu là tính năng thì không thể "chập chờn" như bác đã nói
