Thay dầu Lexus RX350
otolangson
Bình luận: 23Lượt xem: 15,054
TunhanDo
Fluid Types
Engine Oil Type:
Grade .................... ILSAC
Viscosity .................... *SAE 0W-20
*If SAE 0W-20 is not available, SAE 5W-20 may be used. However, it must be replaced with SAE 0W-20 at the next oil change.
Capacities
Oil Capacity (Drain & Refill)
With filter .................... 6.4 U.S. qts (6.1 L)
Without filter .................... 6.0 U.S. qts (5.7 L)
Resetting Engine Oil Maintenance Data
Perform the following procedure:
1. Display the trip meter "A", then turn the "ENGINE STAR STOP" switch off.
2. While pressing the "ODO/TRIP" button, turn the "ENGINE START STOP" switch to ON mode.
3. Keep the "ODO/TRIP" button pressed for about 5 seconds. The resetting procedure is complete when "000000" in the trip meter flashes once and the message in the multi-information display disappears.
quocdat_pl89
Cụ ấy đưa mỗi cái tên dòng xe Lexus mà chả biết nói rõ cụ thể là xe gì thì trả lời kiểu gì,bác ý tham gia từ 2013 thì cái đơn giản như vậy phải nắm được chứ
