Tài liệu Biến tần Rich Electric EI-550 Series
E
Bình luận: 0Lượt xem: 1,181
Escape
Features
  • High-Torque Output
    • High-torque output for 150% torque/1Hz
    • Precise control over a wide speed range
    • IGBT braking unit built-in and optional braking resistor to enable the large braking torque.
  • Multiple Functions
    • 16 multi-speed settings, UP/DOWN selection, jog command…etc.
    • PID control, energy savings control, speed search, auto restarting
    • Full-range automatic torque boost, slip compensation, stall prevention, over/under torque detection, DC injection braking….etc.
    • Remote speed reference: 0~10VDC, 4~20MA. 0~20MA, analog input, multifunctional input and output terminal, analog output monitor, NPN and PNP input signal switch.
    • Copy Keypad function
    • RS422/RS485 serial communication port, MODBUS message format
  • Broad Application
    • Transporting Machine
      • Conveyer
      • Lifting
      • Elevator
    • Public Equipment
      • Industrial Laundry
      • Car Washing Machine
      • Running Machine
    • Flow Machine
      • Fan
      • Pump
      • Blower
    • Food Processing Machine
      • Grinder
      • Mixer
      • Stirrer
    • Printing Textile Machine
      • Printing Machine
      • Textile Machine
      • Dyer
    • Air Conditioning
      • Freezer
      • Air Conditioner
      • Air Compressor
Applications
  • Coating
  • Shaker Conveyor
  • Luggage Scanner Conveyor
  • High Speed Depalletizer
  • Multiple Motor Operation
  • Combination Motor Starter Interconnection
  • Glass Container
  • Snack Food Package Collator
  • Textile Facility Rebuild
  • Carpet Fiber Winder
  • EtherNet/IP CM092/CM093 Option with AB Controllogix / Compactlogix Programmable Controllers
  • Commissioning the CM092/CM093 EtherNet/IP Option Kit with the Rockwell BOOTP/DHCP Server
Link download: http://www.mediafire.com/?t8p7bpj2rkhnv3y
