Solidworks Tutorial By Magnitude Engineering Solutions-QUASAR
Bình luận: 0Lượt xem: 2,306
haianh.mechanical
http://www.magnitudeengsol.com/SolidWorksTutorial.php
Learn the basic and advanced features of SolidWorks step by step with the SolidWorks Tutorial DVD by Magnitude Engineering Solutions. The DVD plays instantly on your computer and comes with its own menu and media player so there is no instillation required. Just insert the DVD and choose what lesson you want from the menu. You're able to play, pause, rewind or fast forward at anytime giving you the flexibility to learn at your own individual pace. These tutorials are made by industry professionals who are Certified SolidWorks users and will give you the tools to learn and master SolidWorks quickly and easily. This SolidWorks Tutorial is applicable to all versions of SolidWorks and comes with everything listed below.
This is the most complete and comprehensive tutorial available. It is perfect for beginners as well as advanced SolidWorks users. These are the tutorials included on the DVD.
1. Format 66. PhotoWorks Scene 131. 3D Sketch
2. Extrude Boss/Base 67. PhotoWorks Lighting 132. Sketch Relations
3. Extrude Cut 68. PhotoWorks Rendering Wizard 133. Horizontal Sketch Relation
4. Revolved Base 69. Multiple Assembly Configurations 134. Vertical Sketch Relation
5. Revolved Cut 70. Split Line 135. Collinear Sketch Relation
6. Swept Base 71. Linear Pattern Assembly 136. Perpendicular Sketch Relation
7. Basic Extrude Loft 72. Circular Pattern Assembly 137. Parallel Sketch Relation
8. Multiple Extrude Loft 73. Envelope 138. Equal Sketch Relation
9. Advanced Extrude Loft 74. Interference Detection 139. Fix Sketch Relation
10. Filet Constant Radius 75. Smooth Edge Bolt 140. Midpoint Sketch Relation
11. Filet Variable Radius 76. Grass Scenery 141. Coincident Sketch Relation
12. Filet Face 77. Tree Scenery 142. Tangent Sketch Relation
13. Filet Full Round 78. Leather PhotoWorks Pattern 143, Edit Sketch Relation
14. Filet FiletXpert 79. Grass Hill Scenery 144. Manual Sketch Editing
15. Chamfer Angle Distance 80. Tire and Rim Intro 145. Coating and Plating Calculation
16. Chamfer Distance and Distance 81. Rim Design 146. Center of Gravity
17. Chamfer Vertex 82. Tire Design 147. Optimize Sketch COG
18. Rib 83. Tire Texture 148. Optimize Part COG
19. Shell 84. Dish Design 149. Calculations and Equations
20. Draft Neutral Plane 85. Bolt Pattern 150. Sweep Cut
21. Draft Parting Line 86. Rim and Dish Material 151. Basic Loft Cut
22. Draft Step Draft 87. Tire and Rim Assembly 152. Multiple Lofts Cut
23. Hole Wizard 88. Five Star Rim 153. Advance Loft Cut
24. Linear Pattern 89. Six Spoke Rim 154. Simple Hole
25. Draft DraftXpert 90. Directional Rim 155. Scale Part
26. Circular Pattern 91. Rim Modification 156. Dome Feature
27. Mirror Sketch 92. One Piece Rim 157. Freeform Feature
28. Mirror Feature 93. Rim Logo 158. Shape Feature
29. Mirror Body 94. Applying Rims to a Car Image Intro 159. Point Deform
30. Thread 95. Select Car image for Rims 160. Deform Curve to Curve
31. Views 96. Insert New Rims on Vehicle Image 161. Multiple Deform Curve to Curve
32. Apply Colour 97. Substitute Rims 162 Surface Push Deform
33. Apply Texture 98. Offset Sketch 163. Surface Push Selected Body
34. Apply Material 99. Scale Sketch 164. Flex intro
35. COSMOSXpress 100. Trim Sketch 165. Flex Bending
36. COSMOSXpress AVI and eDrawings 101. Extend Sketch 166. Twisting Flex
37. COSMOSXpress Report 102. Split Sketch Entities 167. Tapering Flex
38. Optical Properties 103. Jog Line 168. Stretching Flex
39. Create eDrawings 104. Construction Geometry 169. Boolean Intro
40. Annotation in eDrawings 105. Move Sketch 170. Solid Bodies
41. eDrawings Animation 106. Rotate Sketch 171. Boolean Bodies
42. Solid Assembly 107. Copy Sketch 172. Move Solid Bodies
43. Flexible Assembly 108. Linear Pattern 173. Combine Add
44. Exploded View 109. Circular Pattern 174. Combine Add Relevance
45. Create Drawings 110. Edit Linear Pattern 175. Combine Subtract
46. Drawings Annotation 111. Edit Circular Pattern 176. Combine Subtract Application
47. Drawing Views 112. Filet Sketch 177. Combine Common
48. Bill of Materials 113. Chamfer Sketch 178. Combine Common Application
49. Custom Drawings Template 114. Parallelogram 179. Split Bodies
50. Custom Parts Template 115. Polygon sketch 180. Delete Solid Bodies
51. Design Table 116. Ellipse Sketch 181. Sketch Blocks
52. AVI Animator 117. Partial Ellipse Sketch 182. Traction Wheel
53. Telescopic Parts Assembly 118. Parabola Sketch 183. Traction Wheel on Edge
54. Ball Bearings Parts and Assembly 119. Spline Definition 184. Sketch Belt and Chain
55. Image Capturing 120. Spline Sketch 185. Assembly Belt and Chain
56. Simulation 121. Spline On Surface 186. Spell checker
57. Spline Boomerang 122. Construction Points 187. Exporting Parts and Assemblies
58. Utilize Multiple Windows Parts 123. Sketch Plane 188. Exporting STEP
59. Utilize Multiple Windows Assembly 124. Convert Entities 189. Exporting IGES
60. Spring/Coil 125. Face Curves 190. Exporting STL
61. Injection Moulding 126. Measure Tool 191. Layering Parts
62. Advanced Sketching 127. Mass Properties 192. Hot Keys
63. Engrave Text 128. Insert Equations 193. Multiple View Windows
64. PhotoWorks Material 129. Part Statistics 194. Time Dependencies
65. PhotoWorks Insert Decal Image 130. Deviation Analysis
http://www.fileserve.com/file/295KzTU
http://www.fileserve.com/file/R7nJjwX
http://www.fileserve.com/file/cfRKsnK
http://www.fileserve.com/file/swTCaej
http://www.fileserve.com/file/8jRUwVD
http://www.fileserve.com/file/c68V36M
http://www.fileserve.com/file/F8JS7U4
