Phần mềm Autodata 3.45
N
Bình luận: 47Lượt xem: 24,633
IvanOoze
chưa chèn key nhé bác
Làm đúng y chang như thế này mà không được :
3) Open "Keygen" folder and Run "GetUid-x86" or "GetUid-x64" as Administrator (<<< this is important) depending on your OS (32 or 64 bit)
4) Now because you have your UID number you can run "keygen.cmd" and paste/enter it to generate "license.reg" registry file (it's important to NOT enter first 2 digits which are probably 64, enter ONLY last 8 digits)
(in case your UID is 6400000000 you must restart/reboot your PC and go back to step 3 because that UID is NOT proper and valid)
5) Run new generated registry file named "license.reg"
6) Start Emulator as Administrator (<<< this is important) from Start menu or from installed directory which is probably something like C:\Program Files\nodongle.biz\AuDaS0 and there is a file named "ndStart.cmd" or "ndRestart.cmd"
7) Open "Autodata 3.45" from desktop shortcut or ofcourse C:\ADCDA2\ADBCD.exe
(Any kind of errors related to NOT successfully registered .reg files? Just register them manually from "RegSettings" folder as described at the beginning of this text (before all this steps))
8) Enjoy!
