Product Details for 2001 Cd 125T Product Details for 2002 Cd 125T
Dimensions Dimensions
Seat height 730 mm (28.7 inches) Seat height 730 mm (28.7 inches)
Wheelbase 1280 mm (50.4 inches) Wheelbase 1280 mm (50.4 inches)
Fuel capacity - reserve 10 l (2.6 gallon US) Fuel capacity - reserve 10 l (2.6 gallon US)
Dry weight 133 kg (293.2 pounds) Dry weight 133 kg (293.2 pounds)
General General
Category Cruiser Category Cruiser
Model Cd 125T Model Cd 125T
ENGINE ENGINE
Type 124 cc, air cooled, 2 - cylinders in line, 4-stroke Type 124 cc, air cooled, 2 - cylinders in line, 4-stroke
Power 11 hp (8.2 kW) @ 9000 rpm Power 11 hp (8.2 kW) @ 9000 rpm
Bore x stroke (mm) 44 mm x 41 mm Bore x stroke (mm) 44 mm x 41 mm
Valves 2 valves per cylinder Valves 2 valves per cylinder
Torque 9.8 Nm (7.2 ft. lbs) @ 6500 rpm Torque 9.8 Nm (7.2 ft. lbs) @ 6500 rpm
TRANSMISSION TRANSMISSION
Gearbox 5 Speed Gearbox 5 Speed
Final drive Chain Final drive Chain
WHEELS WHEELS
Front tyre 235/70-15 Front tyre 3.00-17
Back tyre 3.00-17 Back tyre 3.00-17
Nói chung là 2001 và 2002 giống nhau, còn theo nguồn tư trang
http://www.fixya.com/motorcycles/p98...a_cd_125t_2002
thì chỉ khác mỗi phần chữ đỏ em đã đánh dấu các bác ạh
General General
ENGINE ENGINE
WHEELS WHEELS
