Một số chữ viết tắt trong hệ thống điện - điện tử ô tô
khoadongluc
Bình luận: 1Lượt xem: 3,223
khoadongluc
Nothing Is Impossible
A Amps, amperage amperes or C or I
AC Alternating Current
C Current or Amps or Intensity
C° Celsius
DC Direct Current
DPDT Double Pole, Double Throw
E Volts or V or electromotive force or U
EMF Electromotive Force or volts or
V or E
F Farads
F° Fahrenheit
Hz Hertz
I Intensity or current flow or A or C
k Kilo or one thousand
LED Light Emitting Diode
M Mega or one Million
m Milli or one thousandth
NC Normally Closed
NO Normally Open
NPN Negative, Positive, Negative
Orbit Shell
P Power or watts
PNP Positive, Negative, Positive
PTC Positive Thermal Coefficient
R Resistance, or ohms, or 
Shell Orbit
SPDT Single Pole, Double Throw
SPST Single Pole, Single Throw
U Units is voltage
V Volts, or voltage or electromotive force or U
W Watts
µ micro or one millionth
 Omega, or ohms, or R
