Làm sao để tắt cảnh báo "Service Vehicle soon" trên xe Chevrolet Colorado 2016?
Bình luận: 7Lượt xem: 5,662
quytruong1990
Bác kiểm tra bằng máy xem có lỗi gì ko ạ ! có khả năng báo thay dầu bảo dưỡng bác thử làm theo manual này xem sao :
To reset the engine oil life system:
1. Display the OIL LIFE REMAINING on the Driver Information System (DIC). See Driver Information Center (DIC) (Base Level) 0 122 or Driver Information Center (DIC) (Uplevel) 0 125.
2. Press and hold SET/CLR for several seconds. The oil life will change to 100%. The oil life system can also be reset as follows:
1. Turn the ignition to ON/RUN with the engine off.
2. Display OIL LIFE REMAINING on the DIC.
3. Fully press the accelerator pedal slowly three times within five seconds. If the display shows 100%, the system is reset.
