Sau đó tiến hành các bước gài chìa mới như sau:
So, what do you need in order to program PATS using FORScan:
1. Extended license (
http://forscan.org/forum/viewtopic.php?f=5&t=836)
2. At least one valid ignition key (master key) that is known by PATS, except the case when all keys are erased from the PATS memory
Let's review a use case for the following scenario: a vehicle supports coded access. PATS knows 2 master keys, but the owner has only 1 of them. The owner wants to erase the lost key from the PATS memory and program new one (for this purpose a blank key is purchased). There is no way to delete a single key, only all known keys can be erased. So the user has to perform the operation in 2 steps: remove all keys known by PATS and program the old key and the new key. Here we go:
- Run the procedure. We see that PATS knows 2 keys:
- Select the Ignition Keys Erase option. FORScan will read outcode and suggest you to generate an incode using the built-in generator:
You can accept and generate incode using built-in generator, or refuse and use an external incode generator. In this case FORScan will show you the outcode and ask to enter the incode:
You can use an external service, for example autokeyprog.com to generate the incode:
If incode is accepted by PATS and if everything is OK, FORScan will request confirmation on the Erase operation. If confirmed, the operation is executed and user is returned back to the main menu. User should see now zero keys known by PATS.
It is important to do not Exit from the menu, otherwise the security access will be lost, and user will have to obtain the coded/timed access again.
- Now, user should program 2 keys. For this purpose the Ignition Key Programming option must be used. User will be suggested to program the key:
- User should follow the instruction displayed by FORScan, so turn the ignition key to OFF, then back to ON and click OK. FORScan will confirm the operation and ask to turn on/off again.
It is important to leave the programmed key in the ignition lock, because number of known keys is non-zero and FORScan will look for a master key.
- program the second key in the same way, except that when FORScan asks to insert new key, the first key has to be removed and the second key has to be inserted.
- When returned back to the main menu, user should see 2 known keys again. But this time these 2 keys are in hands.
Note: some models for Australian and American markets have no stand-alone Ignition Key programming function. The function is available in the PATS menu but PATS doesn't support it. So on these models it is not possible to add a key to th PATS memory. The only way is to use Erase and Program keys function (added in FORScan v2.2.5). This function erases all keys and switches PATS to a special learning mode. In this mode user can program 2 keys one by one.
We also recommend to read this article to study Module Initialization procedure and use cases:
http://forscan.org/forum/viewtopic.php?f=6&t=1500
WARNING:
Experience shows that 90% of problems with using this function are caused by blank key problems (not-original/china clone, incompatible transponder etc). Consdering this experiene, it must be counted that the Erase function is potentially dangerous, because
engine will not start until you program at least 2 keys. So it is
STRONGLY RECOMMENDED to check the blank keys (and correct work of the program with your specific vehicle) before executing the Erase function. Just programm it as the 3rd key and if it has been programmed successfully and engine runs using this key, you may execute the Erase function.
