Em cần xin thông số kích thước cơ cấu phối khí động cơ 2AR-FE ạ!
Bình luận: 9Lượt xem: 1,312
hieu250499
Dạ em đang cần kich thước của: trục cam, con đội, lò xo xupáp, xupáp và ống dẫn hướng.
Càng chi tiết càng tốt ạ! Em đội ơn Bác nhiều
nếu có Bác gửi vào email: hihieu0168@gmail.com giùm em ạ
Crankshaft backlash Standard 0.05 to 0.20 mm (0.00197 to 0.00787 in.)
Maximum 0.20 mm (0.00787 in.)
Camshaft Maximum circle runout 0.03 mm (0.00118 in.)
Journal diameter No. 1 journal 34.449 to 34.465 mm (1.35626 to 1.35689 in.)
Other journals 22.959 to 22.975 mm (0.90390 to 0.90453 in.)
Cam lobe height Standard Intake 44.163 to 44.305 mm (1.73870 to 1.74429 in.)
Exhaust 44.144 to 44.286 mm (1.73795 to 1.74354 in.)
Minimum Intake 44.013 mm (1.73280 in.)
Exhaust 43.996 mm (1.73213 in.)
Chain sub-assembly Maximum chain elongation 137.7 mm (5.42 in.)
Crankshaft timing sprocket Minimum sprocket diameter (with chain) 59.94 mm (2.36 in.)
Chain tensioner slipper Maximum depth 1.0 mm (0.0394 in.)
No. 1 chain vibration damper Maximum depth 1.0 mm (0.0394 in.)
Timing chain guide Maximum depth 1.0 mm (0.0394 in.)
No. 1 balance shaft Thrust clearance Standard 0.05 to 0.09 mm (0.00197 to 0.00354 in.)
Maximum 0.09 mm (0.00354 in.)
No. 2 balance shaft Thrust clearance Standard 0.05 to 0.09 mm (0.00197 to 0.00354 in.)
Balance shaft backlash Standard 0.04 to 0.17 mm (0.00157 to 0.00669 in.)
Maximum 0.17 mm (0.00669 in.)
Cylinder head bolt Measurement point 106 mm (4.17 in.)
Standard diameter 10.85 to 11.00 mm (0.427 to 0.433 in.)
Minimum diameter 10.6 mm (0.417 in.)
Exhaust manifold converter sub-assembly Maximum warpage 0.7 mm (0.0276 in.)
Stiffening crankcase ring pin Protrusion height 4.3 to 5.3 mm (0.169 to 0.209 in.)
Camshaft bearing cap setting ring pin Protrusion height 2.7 to 3.3 mm (0.106 to 0.130 in.)
Camshaft housing straight pin Protrusion height 5.0 to 7.0 mm (0.197 to 0.276 in.)
No. 1 camshaft bearing Dimension A - B or B - A 0 to 0.7 mm (0 to 0.0276 in.)
No. 2 camshaft bearing Standard distance 1.15 to 1.85 mm (0.0453 to 0.0728 in.)
hieu250499
Mà bác ơi! Em đang cần thông số kích thước ( chiều dài, bán kính, bề dày) để vẽ bản 2D ấy ạ! Bác có không cho em xin với ạ! Làm phiền Bác quá :(
Distance404
Bác đang làm tiểu luận à? Bác có cần 100% chính xác không? Nếu không cần mà chỉ cần tham khảo để vẽ cad thôi thì mình gửi bác 2 link này để bác xem tham khảo thử
https://grabcad.com/library/toyota-2jz-gte-engine-1
https://grabcad.com/library/toyota-1-6-engine-to-assemble
