Cd Mô Phỏng Hệ Thống Treo, Lái Và Phanh
khoadongluc
Bình luận: 95Lượt xem: 188,225
autobaonguyen
chào mọi người! giúp e dịch ít tài liệu bảo dưỡng hệ thống treo!!
7.10 diagnostics-suspension
7.10.1 systematic testing
if the reported fault is poor handling, proceed as follows
1. inspect all the components of the system you suspect for example. dampers for correct operation and suspension bushes for condition and security. let's assume the fault was one front damper not operating to the required standard.
2. road test again and check for correct operation of the suspension and other systems
7.10.2 test equipment
7.10.2.1 damper tester
the operating principle of a damper tester is shown in figure 7.34, which indicates that the damper is not operating correctly in this case. this is a device that will draw a graph to show the response of the dampers. it may be useful for providing paper evidence of the operating condition but a physical examination is normally adequate.
.10.3 test results
some of the information you may have to get from other source such as data books or a workshop manual is listed in table 7.9
kingcooker
.10.3 test results
bác bí từ nào thì nói từ đó ,rồi bác tự dịch lấy ,post quá trời chữ thế này ai nhìn thấy cũng lười chả dịch cho bác đâu
