C-Class (W203) Technical Service Bulletins
V
Vin
Bình luận: 25Lượt xem: 7,947
Vin
2004 C240 Sedan
Service Bulletins
TSB Number & Issue Date TSB Title
P-27_55-50A FEB 05 A/T - Harsh Engagement/Buzzing Noises
P-83_30-74A FEB 05 A/C - Musty/Moldy Odors
P-82_10-398A JAN 05 Lighting - License Plate Bulbs Burned Out
P-54_21-133 JAN 05 Lighting - Trunk/Cargo Light Inoperative
P-54_21-121 JAN 05 Lighting - Brake/Park Lamps Flicker With Engine ON
P-30_30-61 DEC 04 Cruise Control Inoperative
P-82_10-419 DEC 04 Lighting - Condensation in Headlamps
P-54_21-124 DEC 04 Lighting - Headlamps/IP Lamps Flicker
P-54_21-126 DEC 04 Power Locks - Central Locking System Inoperative
P-32_25-19 DEC 04 Suspension - Shock/Strut Replacement Guidelins
P-18_00-17C DEC 04 Engine - Approved Engine Oils (Addition)
P-82_70-346B NOV 04 Cell Phone - Inoperative/Locks-Up
P-15_40-54 NOV 04 Charging System - Insufficient Charging
P-54_21-119 OCT 04 Lighting - Tail/Brake Lamps ON Continuously
P-27_00-47A OCT 04 A/T - 722.6 Oil Leaks From Electrical Connection
P-88_30-36 OCT 04 Body - Scraping Noise From Transmission Tunnel Area
P-77_10-24 OCT 04 Body - Sliding Roof Water Leaks/Rattles
S-07_61-38F OCT 04 Engine/Transmission Controls - SCN Coding
P-82_30-399 OCT 04 Windshield - Blistering Near Rain/Light Sensor
P-82_10-376 SEP 04 Lighting - Xenon/Bi-Xenon Headlamps Not Functioning
P-82_62-391 SEP 04 Audio System - Comes ON at Maximum Volume
P-27_60-44 SEP 04 A/T - Implausible Downshifts
P-82_30-366 SEP 04 Wipers/Washers - Wipers Chatter/Noisy After Blade Change
P-82_20-370 SEP 04 Lighting - Dome Lamp Won't Come On
P-33_15-15 AUG 04 Steering/Suspension - Torque Strut Replacement Parts
P-82_00-260A AUG 04 Audio System - CD's Won't Play or Eject
P-68_20-29 AUG 04 Interior - Console/Armrest Lid Rubbing Noise
P-83_00-70 AUG 04 A/C - Inoperative/Codes Set/AC OFF Lamp Illuminated
P-91_60-65B JUL 04 SRS - Warning Lamp ON/DTC's B1035/B1037/B103B/B1039
P-77_20-26 JUL 04 Body - Sliding Roof Excess Lift Control Feature
P-54_10-116 JUL 04 Electrical/Battery - Solar Charging Panel Installation
P-68_50-24 JUN 04 Interior - Sunblind Chafe Guard/Loose
P-91_60-74 MAY 04 SRS - Coding Unnecessary
P-83_40-71 APR 04 Climate Control - Heating and Cooling Set-Points
P-46_20-16 APR 04 Steering - Leaks at Line/Rack Housing Connection
P-33_10-11 APR 04 Suspension - Rumbling Noise Driving Over Rough Roads
P-82_60-303 MAR 04 Audio System - Satellite Radio Installation
S-07_61-039A MAR 04 Engine Controls - DTC Trouble Shooting
P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
P-33_15-10 FEB 04 Steering/Suspension - Alignment Requirements
P-82_00-228B FEB 04 Audio System - Mutes Randomly
S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-47_10-27 JAN 04 Fuel System - Fuel Filler Cap Hard to Remove/Install
P-82_30-316 DEC 03 Wipers/Washers - Erratic Intermittent Wipe Explanation
S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
P-82_30-279B NOV 03 Wipers/Washers- Poor Wiper Performance
S-54_21-101 OCT 03 Engine Controls - ECM Flash Process Change
P-82_60-292 SEP 03 Audio System - Volume Knob Damaged
P-18_20-22 SEP 03 Engine - New Oil Filter Requirements
P-82_85-288 SEP 03 COMAND(R) System - Unable to Enter New Destination
P-82_70-284 AUG 03 Cell Phone - Voice Activated Cell Phone Installation
P-82_85-264 JUL 03 Navigation System - Inoperative/Erroneous Guidance
Vin
2004 C240 Wagon
Service Bulletins
__________________
Vin
2004 C320 4Matic Sedan
Service Bulletins
Vin
2004 C320 4Matic Wagon
Service Bulletins
__________________
Vin
2004 C320 CL
Safety Recalls
2003120006 JAN 04 Recall - Seat Belt Buckle Replacement
Service Bulletins
P-77_20-27A MAR 05 Body - Panorama Sliding Roof Noises
benj04
2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
2001 C240 Sedan
General Recalls
2000110005 DEC 00 Campaign - Accelerator Pedal Value Sensor, Failure
Service Bulletins
P-72_29-39A JAN 05 Body - Front Power Window Motor Locks Up When Closing
P-72_00-33 SEP 04 Body - Front/Rear Window Knocking Noise When Operated
P-18_00-20 DEC 03 Engine - Oil Sludging Damage/Class Action Settlement
T-18_00-21 DEC 03 Engine - Oil Sludging/Consumption Diagnosis & Repair
P-62_00-06 SEP 03 Body - Water Leaks Into Front Footwells
P-80_57-24 SEP 03 Drive Authorization System (DAS) - Component Diagnosis
P-32_20-17A JUL 03 Suspension - Front End Knock/Rumble on Rough Roads
P-07_07-34 JUL 03 Engine Controls - MIL ON/Multiple DTC's Set
P-14_30-15 JUL 03 Emissions - MIL ON/DTC P2003 Stored in Memory
P-82_10-195C JUL 03 Lighting - Front Turn Signals Inoperative
P-20_10-23 MAY 03 Cooling System - Water Pump Leakage
P-82_70-222 MAR 03 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-67_00-09 MAR 03 Body - Windshield/Rear Glass Body Seam Corrosion
P-80_57-20 FEB 03 Audio System - RF Interference Explanation
P-46_20-10 FEB 03 Steering Rack - Connector Leaks
P-82_10-217 JAN 03 Lighting - Parking/Tail Lamp Bulbs Inoperative
P-32_25-13 JAN 03 Suspension - Rumbling Noise From Rear Axle Area
P-83_55-65 DEC 02 A/C - Compressor Cycles Frequently
P-82_85-210 NOV 02 Navigation/GPS System - Various Malfunctions
P-82_62-169B OCT 02 Audio System - Various CD Player Malfunctions
P-26_50-01 SEP 02 M/T - Assembly Precautions/Recommendations
P-82_85-198 JUL 02 COMAND(R) System - No Sound/Whistling
P-91_60-53 JUL 02 SRS System - SRS Lamp ON/DTC's B1058/B2DB0
P-18_40-18A JUL 02 Engine Controls - 'Engine Oil Level Above Max' Displayed
P-82_95-164A JUL 02 Keyless Entry - Tele Aid(R) Remote Unlocking Inoperative
P-68_20-14 MAY 02 Interior - Front Cup Holder Broken
P-32_20-10 APR 02 Suspension - Rear Axle Noise
P-80_35-16 APR 02 Interior - Seat Memory Key Assignment
P-47_10-25 APR 02 Instruments - Erratic Fuel Gauge Operation
2001100003 MAR 02 Campaign - ESP Module Ground Connection Inspection
P-47_10-24 FEB 02 Fuel System - Fuel Sender Identification
P-07_60-16 JAN 02 Engine Controls - Rough Idle/Hesitation/DTC's Set
P-83_30-58 JAN 02 Automatic Temperature Control - Inoperative
P-82_85-182 DEC 01 COMAND(R) System - Various Malfunctions
P-82_85-181 NOV 01 COMAND(R) System - Does Not Respond to Voice Controls
P-83_00-57 NOV 01 A/C - Windshield Fogging in Center
P-47_20-20 NOV 01 Fuel System - Replacement Fuel Pump Adapter Harness
P-80_30-13 NOV 01 Smart Key(R) - Download Time
P-82_64-175 OCT 01 Audio System - CD Changer Static/Interference
P-47_20-17 OCT 01 Fuel System - Hard Start After Fuel Filter Replacement
P-27_60-34 OCT 01 Brakes - Fault Code P2000 Explanation
P-40_10-33A OCT 01 Tires - Approved Winter/Summer Tires
P-82_62-168 SEP 01 Audio System - Poor AM/FM Band Reception
P-82_62-165 SEP 01 Audio System - Popping/Thumping From Speakers
P-82_85-170 SEP 01 COMAND(R) System - Incorrect ETA Calculation Displayed
P-82_85-171 SEP 01 COMAND(R) System - Instrument Display Not Centered
P-32_25-07 SEP 01 Suspension - Front Axle Thumping Noise on Rough Roads
P-80_57-12 AUG 01 Smart Key(R) - Intermittently Inoperative
P-80_57-11 AUG 01 Ignition System - Electronic Ignition Switch Replacement
P-91_10-50A AUG 01 Interior - Noises From Front Seat Tilt Mechanism
P-07_65-14 AUG 01 Engine Controls - Rough Idle After Coming to a Stop
P-91_10-51 AUG 01 Interior - Front Seat Head Restraint Rattles
P-77_20-14 AUG 01 Body - Panorama Roof Panel Won't Open or Move
P-88_50-24 AUG 01 Body - Trunk Lid Will Not Open
P-91_60-48 AUG 01 Air Bag System - Side Impact Sensor Replacement
P-47_30-15 AUG 01 Emissions - OBD Shut-Off Valve Clicking Noises
P-68_10-12 AUG 01 Body - Noises From Right A-Pillar Area
P-62_10-02 AUG 01 Body/Cooling System - Upper Radiator Mount Bolts Break
P-47_25-14 AUG 01 Emissions - Evaporative Purge Valve Ticking Noise
P-72_10-21 JUL 01 Body - Door Hinge Check Noise
P-30_20-06 JUL 01 Fuel System - Accelerator Pedal Squeaks
P-82_64-138B JUN 01 Cellular Phone - Voice Recognition System Installation
P-54_10-053 MAY 01 Battery - New `Fleece' Battery Technology
S-00_00-072 MAY 01 Emission/VIN Label - Availability
S-58_091A MAY 01 Special Tool - Universal Valve Spring Tool
S-05_010A MAY 01 Tools - Universal Valve Spring Tool
S-58_20-93B APR 01 Fender/Interior/Fascia Cover - Availability
S-58_00-118 MAR 01 Engine Oil - Approved Evacuation Equipment
S-00_40-071 FEB 01 Synthetic Oil Recommendations - For FFS Vehicles
S-40_10-036 FEB 01 Tires - Maintenance & Inspection
S-60_004A DEC 00 Body/Frame - Dedicated Straightening Equipment
S-58_094A DEC 00 Chassis/Frame - Dedicated Frame Straightener
S-60_00-012 DEC 00 Special Tool - M20 Resistance Welder
S-58_30-103A DEC 00 Special Tool - Resistance Spot Welder
S-58_30-115 DEC 00 Special Tool - Resistance Welder
S-60_00-008A DEC 00 Special Tool - Spot Welder
S-40_10-034 DEC 00 Tires - High Performance Tire Storage
P-91_60-46 OCT 00 Rear Door Airbag - Deactivation/Activation
P-40_10-033 SEP 00 Tires/Snow Chains - Factory Approved Specifications
S-82_70-136 AUG 00 Timeport Portable Telephone Programming
P-58_40-113 JUN 00 Tools - Dedicated Frame Straightening Equipment
P-60_10-11 JUN 00 Tools - Frame Straightening Equipment
Why is not link for download doc
