2003 - 2008 Toyota Matrix Repair Manual
C
Bình luận: 0Lượt xem: 973
Ctrl+C
Section 01: introduction
01-01 how to use this manual
01-04 identification information
01-05 repair instruction
01-20 vehicle lift and support locations
01-23 how to troubleshoot ecu controlled systems
01-24 how to proceed with troubleshooting ecu controlled systems
01-34 electronic circuit inspection procedure
01-39 term and abbreviations
01-44 glossary of sae and toyota terms
Section 02: preparation
02-01 diagnostics
02-02 engine control system
02-03 fuel
02-04 emission control
02-05 engine mechanical
02-12 exhaust
02-13 cooling
02-14 lubrication
02-15 ignition
02-16 starting and charging
02-17 front suspension
02-18 rear suspension
02-21 tire and wheel
02-22 differential
02-27 drive shaft / propeller shaft
02-32 transfer
02-37 brake
02-39 parking brake
02-40 automatic transmission / transaxle
02-44 manual transmission / transaxle
02-51 clutch
02-52 steering column
02-53 power steering
02-57 heater and air conditioner
02-61 supplemental restraint system
02-63 seat belt
02-64 lighting
02-65 wiper and washer
02-66 audio and visual system
02-68 communication system
02-69 windshield / windowglass / mirror
02-70 instrument panel
02-71 seat
02-72 theft deterrent and door lock
02-73 sliding roof / convertible
02-74 exterior interior trim
02-75 vehicle control system
02-76 cruise control
Section 03: service specifications
03-01 standard bolt - how to determine bolt strength
03-02 standard bolt - specified torque for standard bolts
03-03 standard bolt - how to determine nut strength
03-04 engine control system service data
03-05 engine control system torque specification
03-06 fuel service data
03-07 fuel torque specification
03-08 emission control service data
03-09 engine mechanical service data
03-14 engine mechanical torque specification
03-18 exhaust service data
03-19 exhaust torque specification
03-20 cooling service data
03-21 cooling torque specification
03-22 lubrication service data
03-23 lubrication torque specification
03-24 ignition service data
03-25 ignition torque specification
03-26 starting and charging service data
03-27 starting and charging torque specification
03-28 front suspension service data
03-29 front suspension torque specification
03-30 rear suspension service data
03-31 rear suspension torque specification
03-32 tire and wheel service data
03-33 differential service data
03-35 differential torque specification
03-36 drive shaft / propeller shaft / axle service data
03-37 drive shaft torque specification
03-38 transfer assembly service data
03-41 transfer assembly torque specification
03-42 brake service data
03-43 brake torque specification
03-44 parking brake service data
03-45 parking brake torque specification
03-46 automatic transmission / transaxle service data
03-48 automatic transmission torque specification
03-51 manual transmission service data
03-57 manual transmission torque specification
03-59 clutch service data
03-60 clutch torque specification
03-61 steering column service data
03-62 steering column torque specification
03-63 power steering service data
03-64 power steering torque specification
03-65 heater and air conditioner service data
03-66 heater and air conditioner torque specification
03-67 supplemental restraint system torque specification
03-68 seat belt torque specification
03-69 wiper and washer torque specification
03-70 audio and visual system torque specification
03-71 instrument panel / meter torque specification
03-72 seat torque specification
03-73 sliding roof / convertible service data
03-74 sliding root / convertible torque specification
03-75 engine hood / door torque specification
03-76 exterior / interior trim torque specification
03-77 cruise control service data
03-78 cruise control torque specification
Section 05: diagnostics
sfi system (1zz-fe)
05-001 sfi system (1zz-fe) - how to proceed with troubleshooting
05-004 customer problem analysis check
05-005 pre-check
05-016 diagnostic trouble code chart
05-020 location diagram
05-021 terminals of ecm
05-023 problem symptoms table
05-025 mass air flow circuit malfunction
05-030 mass air flow circuit range/performance problem
05-031 intake air temp circuit malfunction
05-034 engine coolant temp circuit malfunction
05-037 engine coolant temp circuit range/performance problem
05-038 throttle/pedal position sensor/switch A circuit malfunction
05-043 throttle/pedal position sensor/switch A circuit range/performance problem
05-044 insufficient coolant temp for closed loop fuel control
05-049 thermostat malfunction
05-051 heated oxygen sensor circuit malfunction (bank 1 sensor 1)
05-056 heated oxygen sensor slow response (bank 1 sensor 1)
05-060 heated oxygen sensor heater circuit malfunction (bank 1 sensor 1)
05-063 oxygen sensor circuit malfunction (bank 1 sensor 2)
05-064 system too lean (fuel trim) (bank 1) system too rich (fuel trim) (bank 1)
05-068 random/multiple cylinder misfire detected
05-073 knock sensor 1 circuit malfunction (bank 1)
05-076 crankshaft position sensor A circuit malfunction
05-079 camshaft position sensor circuit malfunction
05-081 catalyst system efficency below threshold (bank 1)
05-084 evaporative emission control system malfunction
05-093 evaporative emission control system incorrect purge flow
05-108 evaporative emission control system pressure sensor malfunction
05-110 vehicle speed sensor malfunction
05-112 idle control system malfunction
05-115 igniter circuit malfunction
05-121 crankshaft position sensor circuit malfunction (during engine running)
05-122 vvt sensor/camshaft position sensor circuit range/performance problem (bank1)
05-123 vvt system malfunction (bank 1)
05-128 stop light switch circuit malfunction
05-132 back-up power source circuit malfunction
05-135 ocv circuit malfunction (bank 1)
05-138 park/neutral position switch malfunction
05-139 starter signal circuit
05-144 fuel pump control circuit
05-148 ecm power circuit
sfi system (2zz-ge)
05-153 sfi system (2zz-ge) - how to proceed with troubleshooting
05-156 customer problem analysis check
05-157 pre-check
05-168 diagnostic trouble code chart
05-172 location diagram
05-173 terminals of ecm
05-175 problem symptoms table 2zz
05-177 mass air flow circuit malfunction
05-182 mass air flow circuit range/performance problem
05-183 intake air temp circuit malfunction
05-186 engine coolant temp circuit malfunction
05-189 engine coolant temp circuit range/performance problem
05-190 throttle/pedal position sensor/switch A circuit malfunction
05-195 throttle/pedal position sensor/switch A circuit range/performance problem
05-196 insufficient coolant temp for closed loop fuel control
05-201 thermostat malfunction
05-203 heated oxygen sensor circuit malfunction (bank 1 sensor 1)
05-208 heated oxygen sensor slow response (bank 1 sensor 1)
05-212 heated oxygen sensor heater circuit malfunction (bank 1 sensor 1)
05-215 oxygen sensor circuit malfunction (bank 1 sensor 2)
05-216 system too lean (fuel trim) (bank 1) system too rich (fuel trim) (bank 1)
05-220 random/multiple cylinder misfire detected
05-225 knock sensor 1 circuit malfunction (bank 1)
05-228 crankshaft position sensor A circuit malfunction
05-231 camshaft position sensor circuit malfunction
05-233 catalyst system efficency below threshold (bank 1)
05-236 evaporative emission control system malfunction
05-245 evaporative emission control system incorrect purge flow
05-260 evaporative emission control system pressure sensor malfunction
05-262 vehicle speed sensor malfunction
05-264 idle control system malfunction
05-267 igniter circuit malfunction
05-273 crankshaft position sensor circuit malfunction (during engine running)
05-274 vvt sensor/camshaft position sensor circuit range/performance problem (bank1)
05-275 vvt system malfunction (bank 1)
05-280 stop light switch circuit malfunction
05-284 back-up power source circuit malfunction
05-287 ocv circuit malfunction (bank 1)
05-290 ocv for vvtl circuit malfunction
05-294 ocv for vvtl open malfunction (bank 1)
05-298 park/neutral position switch malfunction
05-299 starter signal circuit
05-304 fuel pump control circuit
05-308 ecm power circuit
Section 10: engine control system
10-02 sfi system (1zz-fe) inspection
10-01 sfi system (1zz-fe) on-vehicle inspection
10-05 throttle body assembly (1zz-fe) components
10-06 throttle body assembly (1zz-fe) removal and installation/disassembly and reassembly
10-12 sfi system (2zz-ge) inspection
10-11 sfi system (2zz-ge) on-vehicle inspection
10-15 throttle body assembly (2zz-ge) components
10-16 throttle body assembly (2zz-ge) removal and installation/disassembly and reassembly
Section 11: fuel system
11-01 precautions
11-05 on-vehicle inspection
11-07 inspection
11-09 fuel injector assy (1zz-fe)
11-10 fuel injector replacement (1zz-fe)
11-14 fuel injector assy (2zz-ge)
11-15 fuel injector replacement (2zz-ge)
11-19 fuel pump assy components
11-21 fuel pump assy removal/install and disassembly and reassembly
11-27 fuel pump assy components (4wd)
11-29 fuel pump assy removal/install and disassembly/reassembly (4wd)
11-35 fuel tank assy components
11-38 fuel tank assy removal/install and disassembly and reassembly
11-47 fuel tank assy components (4wd)
11-51 fuel tank assy removal/install and disassembly/reassembly (4wd)
Section 12: emission control system
12-01 emission control system (1zz-fe) on-vehicle inspection
12-07 charcoal canister assy (1zz-fe)
12-13 emission control system (2zz-ge) on-vehicle inspection
12-18 charcoal canister assy (2zz-ge)
Section 14: engine mechanical
14-001 engine assy (1zz-fe) inspection
14-004 fan and generator v belt (1zz-fe) replacement
14-005 valve clearance (1zz-fe) adjustment
14-016 partial engine assy (1zz-fe) components
14-030 partial engine assy (1zz-fe) replacement
14-052 partial engine assy (1zz-fe) overhaul
14-083 chain sub-assy (1zz-fe) components
14-086 chain sub-assy (1zz-fe) replacement
14-097 camshaft (1zz-fe) components
14-100 camshaft (1zz-fe) replacement
14-112 cylinder head gasket (1zz-fe) components
14-116 cylinder head gasket (1zz-fe) replacement
14-132 timing gear cover oil seal (1zz-fe) replacement
14-134 engine rear oil seal (1zz-fe) replacement
14-137 cylinder head assy (1zz-fe) components
14-138 cylinder head assy (1zz-fe) overhaul
14-150 cylinder block (1zz-fe) components
14-151 cylinder block (1zz-fe) overhaul
14-174 engine assy (2zz-ge) inspection
14-177 fan and generator v belt (2zz-ge) replacement
14-179 valve clearance (2zz-ge) adjustment
14-189 partial engine assy (2zz-ge) components
14-218 partial engine assy (2zz-ge) overhaul
14-201 partial engine assy (2zz-ge) replacement
14-244 chain sub-assy (2zz-ge) components
14-247 chain sub-assy (2zz-ge) replacement
14-259 camshaft (2zz-ge) components
14-262 camshaft (2zz-ge) replacement
14-275 cylinder head gasket (2zz-ge) components
14-279 cylinder head gasket (2zz-ge) replacement
14-296 timing gear cover oil seal (2zz-ge) replacement
14-299 engine rear oil seal (2zz-ge) replacement
14-302 cylinder head assy (2zz-ge) components
14-303 cylinder head assy (2zz-ge) overhaul
14-315 cylinder block (2zz-ge) components
14-316 cylinder block (2zz-ge) overhaul
Section 15: exhaust pipe
15-01 exhaust pipe (1zz-fe) components
15-04 exhause pipe (1zz-fe) removal/install and disassembly/reassmbly
15-08 exhaust pipe (2zz-ge) components
15-09 exhause pipe (2zz-ge) removal/install and disassembly/reassmbly
Section 16: cooling
16-01 cooling system on-vehicle inspection
16-02 cooling system inspection
16-04 cooling fan system on-vehicle inspection
16-05 cooling fan system inspection
16-06 coolant replacement
16-07 water pump assy (1zz-fe) replacement
16-09 water pump assy (1zz-fe) inspection
16-10 water pump assy (2zz-ge) replacement
16-12 water pump assy (2zz-ge) inspection
16-13 thermostat replacement
16-15 radiator assy replacement
Section 17: lubrication
17-01 lubrication system (1zz-fe) on-vehicle inspection
17-03 oil pump assy (1zz-fe) components
17-07 oil pump assy (1zz-fe) replacement
17-08 oil pump assy (1zz-fe) overhaul
17-10 oil filter sub-assy (1zz-fe) replacement
17-12 lubrication system (2zz-ge) on-vehicle inspection
17-14 oil pump assy (2zz-ge) components
17-18 oil pump assy (2zz-ge) replacement
17-19 oil pump assy (2zz-ge) overhaul
17-22 oil filter sub-assy (2zz-ge) replacement
Section 18: ignition
18-01 ignition system (1zz-fe) on-vehicle inspection
18-02 ignition system (1zz-fe) inspection
18-04 ignition system (2zz-ge) on-vehicle inspection
18-05 ignition system (2zz-ge) inspection
Section 19: starting and charging
19-01 starting system inspection
19-03 starter assy replacement
19-04 starter assy components
19-05 starter assy overhaul
19-11 charging system precautions
19-12 charging system on-vehicle inspection
19-15 generator assy replacement
19-16 generator assy components
19-17 generator assy overhaul
Section 26: front suspension
26-01 front suspension system problem symptoms table
26-02 front suspension repair
26-03 front suspension components
26-06 front wheel alignment adjustment
26-10 front shock absorber w/ coil spring overhaul
26-14 front shock absorber w/ coil spring disposal
26-15 front suspension arm sub-assy lower no.1 lh replacement
26-20 lower ball joint assy front lh replacement
26-22 stabilizer bar front replacement
Section 27: rear suspension
27-01 rear suspension system problem symptoms table
27-02 rear suspension components
27-06 rear wheel alignment inspection
27-07 rear wheel alignment (4wd) adjustment
27-11 rear shock absorber w/ coil spring overhaul
27-15 rear shock absorber w/ coil spring disposal
27-16 rear shock absorber w/ coil spring (4wd) overhaul
27-20 rear shock absorber w/ coil spring (4wd) disposal
27-21 rear axle beam assy replacement
27-27 rear suspension arm assy no.1 lh (4wd) replacement
27-32 upper control arm assy (4wd) replacement
27-38 stabilizer bar rear replacement
27-39 stabilizer bar rear (4wd) replacement
Section 28: wheel and tire system
28-01 wheel and tire system inspection
Section 29: differential
29-01 differential system (4wd) precaution
29-02 differential system (4wd) problem symptoms table
29-03 differential (4wd) components
29-07 differential oil (4wd) adjustment
29-08 oil diaphragm seal (4wd) replacement
29-10 rear differential side gear shaft oil seal (4wd) replacement
29-12 differential carrier assy rear (4wd) overhaul
Section 30: drive shaft / propeller shaft
30-01 drive shaft, propeller shaft, axle precautions
30-02 drive shaft, propeller shaft, axle problem symptoms table
30-03 drive shaft, propeller shaft, axle on-vehicle inspection
30-05 propeller w/ center bearing shaft assy (4wd) components
30-06 propeller w/ center bearing shaft assy (4wd) overhaul
30-12 front drive shaft (1zz-fe) components
30-15 front drive shaft (1zz-fe) overhaul
30-30 front drive shaft (2zz-ge) components
30-32 front drive shaft (2zz-ge) overhaul
30-45 rear drive shaft (4wd) components
30-46 rear drive shaft (4wd) overhaul
30-55 front axle hub sub-assy lh components
30-56 front axle hub sub-assy lh replacement
30-61 front axle lh hub bolt replacement
30-62 rear axle hub and bearing assy lh components
30-63 rear axle hub and bearing assy lh replacement
30-65 rear axle carrier sub-assy lh (4wd) components
30-66 rear axle carrier sub-assy lh (4wd) replacement
30-72 rear axle hub bolt replacement
Section 31: transfer
31-01 transfer system (u341f) precaution
31-02 transfer system (u341f) problem symptoms table
31-03 transfer oil (u341f) adjustment
31-04 transfer case rh oil seal (u341f)
31-06 transfer case oil seal (u341f) replacement
31-08 transfer extension housing type t oil seal (u341f)
31-09 transfer assy (u341f) components
31-11 transfer assy (u341f) overhaul
Section 32: brake
32-01 brake system precautions
32-02 brake system problem symptoms table
32-06 brake fluid bleeding
32-08 brake pedal sub-assy adjustment
32-10 brake pedal sub-assy components
32-11 brake pedal sub-assy replacement
32-13 brake master cylinder sub-assy components
32-15 brake master cylinder sub-assy overhaul
32-20 brake booster assy on-vehicle inspection
32-21 brake booster assy components
32-22 brake booster assy replacement
32-26 front brake components
32-27 front brake overhaul
32-32 rear drum brake (1zz-fe(ff)) components
32-33 rear drum brake (1zz-fe(ff)) overhaul
32-40 rear drum brake (1zz-fe(4wd)) components
32-41 rear drum brake (1zz-fe(4wd)) overhaul
32-48 rear disc brake components
32-49 rear disc brake overhaul
32-54 proportioning valve assy on-vehicle inspection
32-55 proportioning valve assy replacement
32-56 brake actuator assy on-vehicle inspection
32-57 brake actuator assy replacement
32-60 speed sensor front lh replacement
32-62 skid control sensor (ff)
32-64 speed sensor rear lh (4wd) replacement
32-67 deceleration sensor (4wd) replacement
Section 33: parking brake
32-01 parking brake problem symptoms table
32-02 parking brake adjustment
32-03 parking brake lever sub-assy components
32-04 parking brake lever sub-assy replacement
32-07 parking brake cable assy no.1 components
32-08 parking brake cable assy no.1 replacement
32-10 parking brake cable assy no.3 (ff) components
32-11 parking brake cable assy no.3 (ff) replacement
32-14 parking brake cable assy no.3 (4wd) components
32-15 parking brake cable assy no.3 (4wd) replacement
32-17 parking brake assy (2zz-ge) components
32-18 parking brake assy (2zz-ge) overhaul
Section 40: automatic transmission
40-01 automatic transaxle assy (atm) precautions
40-02 automatic transaxle fluid (atm) on-vehicle inspection
40-03 park/neutral position switch assy (atm) replacement
40-09 park/neutral position switch assy (atm) adjustment
40-10 automatic transaxle assy (a246e) components
40-12 automatic transaxle assy (a246e) replacement
40-23 automatic transaxle assy (u240e) components
40-25 automatic transaxle assy (u240e) replacement
40-35 automatic transaxle assy (u341f) components
40-36 automatic transaxle assy (u341f) replacement
40-43 torque converter clutch and drive plate (atm) inspection
40-45 speedometer sensor (a246e)
40-46 transmission revolution sensor (u240e) replacement
40-48 transmission revolution sensor (u341f) replacement
40-49 transmission valve body assy (a246e) replacement
40-53 transmission valve body assy (u240e) replacement
40-58 transmission valve body assy (u341f) replacement
40-63 transmission wire (a246e) replacement
40-64 transmission wire (u240e) replacement
40-67 transmission wire (u341f) replacement
40-68 front differential oil seal (a246e) replacement
40-70 front differential oil seal (u240e) replacement
40-72 front differential oil seal (u341f) replacement
40-74 shift lock system (atm) on-vehicle inspection
40-76 floor shift assy (atm) components
40-78 floor shift assy (atm) overhaul
40-87 floor shift assy (atm) adjustment
40-88 shift lock control ecu (atm) inspection
40-89 shift lock solenoid (atm) inspection
40-90 floor shift cable transmission control shift (atm) replacement
40-95 floor shift parking lock cable assy (atm) replacement
Section 41: manual transmission
41-001 manual transaxle system (mtm) problem symptoms table
41-002 manual transaxle oil (mtm) on-vehicle inspection
41-003 front differential oil seal (mtm) replacement
41-005 floor shift lever assy (mtm) components
41-006 floor shift lever assy (mtm) replacement
41-009 floor shift cable transmission control shift (mtm) replacement
41-012 floor shift cable transmission control select (mtm) replacement
41-015 manual transaxle assy (mtm) components
41-017 manual transaxle assy (mtm) replacement
41-026 manual transaxle assy (c59) components
41-029 manual transaxle assy (c59) overhaul
41-063 manual transaxle assy (c60) components
41-066 manual transaxle assy (c60) overhaul
41-101 input shaft assy (c59) components
41-102 input shaft assy (c59) overhaul
41-112 input shaft assy (c60) components
41-113 input shaft assy (c60) overhaul
41-122 output shaft assy (c59) components
41-123 output shaft assy (c59) overhaul
41-134 output shaft assy (c60) components
41-135 output shaft assy (c60) overhaul
41-146 differential case assy (mtm) components
41-147 differential case assy (mtm) overhaul
41-152 shift and select lever shaft assy (c59) components
41-154 shift and select lever shaft assy (c59) overhaul
41-159 shift and select lever shaft assy (c60) components
41-161 shift and select lever shaft assy (c60) overhaul
Section 42: clutch
42-01 clutch system (mtm) problem symptoms table
42-02 clutch pedal sub-assy (mtm) adjustment
42-04 clutch pedal sub-assy (mtm) components
42-05 clutch pedal sub-assy (mtm) replacement
42-09 clutch master cylinder assy (mtm) components
42-10 clutch master cylinder assy (mtm) overhaul
42-14 clutch release cylinder assy (mtm) components
42-15 clutch release cylinder assy (mtm) overhaul
42-17 clutch unit (mtm) components
42-18 clutch unit (mtm) overhaul
42-22 clutch start switch assy (mtm) on-vehicle inspection
42-23 clutch start switch assy (mtm) inspection
42-24 clutch start switch assy (mtm) replacement
Section 50: steering
50-01 steering system precautions
50-02 steering system problem symptoms table
50-03 steering column on-vehicle inspection
50-04 steering system repair
50-06 steering column assy components
50-08 steering column assy overhaul
Section 51: power steering
51-01 power steering system precautions
51-02 power steering system problem symptoms table
51-03 power steering system on-vehicle inspection
51-07 vane pump assy components
51-08 vane pump assy overhaul
51-16 rack and pinion power steering gear assy components
51-22 rack and pinion power steering gear assy overhaul
Section 55: heater and air conditioner
55-01 air conditioning system precautions
55-02 air conditioning system on-vehicle inspection
55-03 air conditioning system inspection
55-06 refrigerant on-vehicle inspection
55-11 refrigerant replacement
55-12 refrigerant line components
55-13 air conditioning control assy overhaul
55-15 air conditioning unit assy components
55-17 air conditioning unit assy overhaul
55-33 cooler compressor assy (2zz-ge) components
55-34 cooler compressor assy (2zz-ge) replacement
55-39 cooler compressor assy (1zz-fe) components
55-40 cooler compressor assy (1zz-fe) replacement
55-45 w/ receiver condenser assy on-vehicle inspection
55-46 w/ receiver condenser assy components
55-47 w/ receiver condenser assy overhaul
Section 60: supplemental restraint
60-01 supplemental restraint system precautions
60-08 supplemental restraint system on-vehicle inspection
60-12 horn button assy components
60-13 horn button assy replacement
60-14 horn button assy disposal
60-21 spiral cable sub-assy components
60-22 spiral cable sub-assy replacement
60-24 instrument panel passenger air bag assy components
60-25 instrument panel passenger air bag assy replacement
60-27 instrument panel passenger air bag assy disposal
60-33 front seat airbag assy rh disposal
60-38 air bag sensor assy center components
60-39 air bag sensor assy center replacement
60-40 air bag front rh sensor components
60-41 air bag front rh sensor replacement
60-42 air bag sensor front lh components
60-43 air bag sensor front lh replacement
60-44 side air bag sensor assy rh components
60-45 side air bag sensor assy rh replacement
60-46 seat position air bag sensor components
60-47 seat position air bag sensor replacement
Section 61: seat belt
61-01 seat belt warning system location
61-02 seat belt warning system problem symptoms table
61-03 seat belt warning system inspection
61-05 front seat belt components
61-08 front seat belt disposal
61-06 front seat belt replacement
61-13 rear seat belt components
61-14 rear seat belt replacement
Section 65: lighting
65-01 lighting system precautions
65-02 lighting system problem symptoms table
65-04 lighting system on-vehicle inspection
65-07 lighting system inspection
65-12 lh headlamp assy components
65-13 lh headlamp assy replacement
65-14 lh headlamp assy adjustment
65-16 fog lamp assy lh replacement
65-17 fog lamp assy lh adjustment
65-18 rear combination lamp assy lh replacement
65-19 license plate lamp assy replacement
65-20 center stop lamp assy replacement
65-21 headlamp dimmer switch assy replacement
Section 66: wiper and washer
66-01 wiper and washer system problem symptom table
66-02 wiper and washer system on-vehicle inspection
66-03 wiper and washer system inspection
66-06 windshield wiper motor assy replacement
66-10 wiper rubber lh replacement
66-11 rear wiper motor assy replacement
66-15 rear wiper rubber replacement
66-17 winshield wiper switch assy replacement
66-18 washer nozzle adjustment
Section 67: audio and visual system
67-01 audio and visual system precautions
67-02 audio and visual system components
67-05 radio receiver assy replacement
67-07 navigation receiver assy replacement
67-08 front no.1 speaker assy replacement
67-10 front no.2 speaker assy replacement
67-11 rear speaker assy replacement
67-13 radio wire sub-assy replacement
67-14 antenna cord sub-assy replacement
67-16 amplifier antenna assy replacement
67-18 roof antenna pole sub-assy replacement
67-19 navigation antenna cord sub-assy replacement
67-20 navigation antenna assy replacement
67-21 disc player changer replacement
67-22 cigarette lighter assy replacement
67-23 power point socket assy replacement
67-24 power point socket assy no.2 replacement
67-25 voltage inverter assy replacement
Section 68: wiring
68-01 power source location
Section 69: communication
69-01 horn system location
69-02 horn system problem symptoms table
69-03 horn system inspection
Section 70: windshield, windowglass, mirror
70-01 power window control system location
70-02 power window control system on-vehicle inspection
70-03 power window control system problem symptoms table
70-04 power window control system inspection
70-09 windshield glass components
70-10 windshield glass replacement
70-15 quarter window assy ln components
70-16 quarter window assy lh replacement
70-20 back door glass components
70-21 back door glass replacement
70-24 window defogger system location
70-25 window defogger system problem symptoms table
70-26 window defogger system inspection
70-27 power mirror control system location
70-28 power mirror control system inspection
70-30 inner rear view mirror assy replacement
70-31 inner rear view mirror assy pre-check
70-33 inner rear view mirror assy inspection
70-34 outer rear view mirror assy lh replacement
70-35 back window stay assy lh replacement
70-36 back window stay assy lh disposal
Section 71: instrument panel/meter
71-01 combination meter problem symptoms table
71-02 combination meter on-vehicle inspection
71-07 intrument panel/meter components
71-09 instrument panel sub-assy lower precautions
71-10 instrument panel sub-assy lower replacement
71-18 combination meter assy overhaul
Section 72: seats
72-01 front seat (driver side) components
72-02 front seat (driver side) overhaul
72-05 front seat (passenger side) components
72-06 front seat (passenger side) overhaul
72-09 rear seat assy components
72-10 rear seat assy overhaul
Section 73: theft deterrent and door lock
73-01 power door lock control system on-vehicle inspection
73-03 power door lock control system inspection
73-09 wireless door lock control system on-vehicle inspection
73-08 wireless door lock control system precaution
73-11 transmitter battery replacement
73-12 door control transmitter registration
73-15 glass hatch opener system on-vehicle inspection
73-16 glass hatch opener system location
73-17 glass hatch opener system inspection
73-18 toyota vehicle intrusion protection system on-vehicle inspection
Section 74: sliding roof/convertible
74-01 sliding roof system location
74-02 sliding roof system on-vehicle inspection
74-03 sliding roof system problem symptoms table
74-04 sliding roof system inspection
74-06 sliding roof components
74-07 sliding roof replacement
Section 75: engine hood/door
75-01 hood adjustment
75-03 front door components
75-05 front door overhaul
75-14 front door adjustment
75-16 rear door components
75-18 rear door overhaul
75-25 rear door adjustment
75-27 back door components
75-28 back door overhaul
75-30 back door adjustment
75-32 back door stay assy lh replacement
75-33 back door stay assy lh disposal
Section 76: exterior/interior trim
76-01 front bumper components
76-02 front bumper replacement
76-04 rear bumper components
76-05 rear bumber replacement
76-07 name plate replacement
76-08 front door belt moulding assy lh
76-09 rear door belt moulding assy lh
76-10 rocker manel moulding lh replacement
76-11 side mudguard sub-assy lh replacement
76-12 roof drip side finsih moulding center lh
76-14 roof headlining assy components
76-17 roof headlining assy replacement
Section 80: vehicle control
80-01 ignition or starter switch assy replacement
80-02 ignition or starter switch assy inspection
Section 82: cruise control
82-01 cruise control system on-vehicle inspection
82-03 cruise control main switch assy replacement
82-04 cruise control ecu assy
82-05 cruise control actuator assy replacement
82-06 clutch switch assy replacement
Section 99: maintenance
99-01 outside vehicle general maintenance
99-02 inside vehicle general maintenance
99-04 under hood general maintenance
99-05 engine on-vehicle inspection
99-06 brake on-vehicle inspection
99-07 chassis on-vehicle inspection
99-08 body on-vehicle inspection
