Xin tài liệu ford ranger 2012+
huyhungst
Bình luận: 14Lượt xem: 2,943
huyhungst
Cái này 2009 . Not same rồi cụ ơi ..!
[MERGETIME="1399604622"][/MERGETIME]
Trước mắt cụ cần phần nào em gửi cho. Vì nó chia nhỏ ra từng phần, nên tải về rất mất công.
Cụ cứ upload lên . E muốn nhìn tổng quan một tí ạ ! Thanks
[MERGETIME="1399604629"][/MERGETIME]
[MERGETIME="1399604636"][/MERGETIME]
[MERGETIME="1399604655"][/MERGETIME]
[MERGETIME="1399604657"][/MERGETIME]
lasonf
Rất tiếc em ko có file pdf toàn bộ. Đây là mục lục của nó, bác cần cái nào thì em lấy cho:
2011 - 2013 Ranger
Wiring Diagrams
Driveline
205-02 Rear Drive Axle/Differential
Electronic Locking Differential (ELD) Solenoid
Brake System
206-05 Parking Brake and Actuation
Parking Brake Warning Indicator Switch
206-06 Hydraulic Brake Actuation
Low Brake Fluid Warning Indicator Switch
Low Brake Fluid Warning Indicator Switch - A
206-09A Anti-Lock Control
Anti-Lock Control
Anti-Lock Brake System (ABS) Module
Front Wheel Speed Sensor LH
Front Wheel Speed Sensor RH
Rear Wheel Speed Sensor LH
Rear Wheel Speed Sensor RH
206-09B Anti-Lock Control - Stability Assist
Steering Wheel Rotation Sensor
Stability Assist/Traction Control Switch
206-09C Anti-Lock Brake System (ABS) and Stability Control
Steering System
211-05 Steering Column Switches
Hazard Flasher Switch
Ignition Switch
Steering Column Multifunction Switch
Steering Column Multifunction Switch - A
Engine
303-03 Engine Cooling
Cooling Fan Motor
303-04A Fuel Charging and Controls
Fuel Injector 1 - A
Fuel Injector 2 - A
Fuel Injector 3 - A
Fuel Injector 4 - A
303-04B Fuel Charging and Controls
Fuel Injector 1
Fuel Injector 2
Fuel Injector 3
Fuel Injector 4
Fuel Metering Valve
303-04C Fuel Charging and Controls
Fuel Injector 1
Fuel Injector 2
Fuel Injector 3
Fuel Injector 4
Fuel Injector 5
Fuel Metering Valve
303-04D Fuel Charging and Controls - Turbocharger
Turbocharger Variable Vane Actuator
Wastegate Position Sensor
303-06A Starting System
Starting System
Starter Motor - A
Starter Motor - B
303-06B Starting System
Starting System - Vehicles With: 5-Speed Manual Transmission - MT75/6-Speed Manual Transmission - MT82
Starting System - Vehicles With: 6-Speed Automatic Transmission - 6R80, LHD 4WD/LHD RWD
Starting System - Vehicles With: 6-Speed Automatic Transmission - 6R80, RHD 4WD/RHD RWD
Starter Motor - A
Starter Motor - B
303-07A Engine Ignition
Ignition Coil-On-Plug 1
Ignition Coil-On-Plug 2
Ignition Coil-On-Plug 3
Ignition Coil-On-Plug 4
303-07B Glow Plug System
Glow Plug 1
Glow Plug 2
Glow Plug 3
Glow Plug 4
Glow Plug Module
Glow Plug Module - B
303-07C Glow Plug System
Glow Plug 1
Glow Plug 2
Glow Plug 3
Glow Plug 4
Glow Plug 5
Glow Plug Module - A
Glow Plug Module - C
303-08 Engine Emission Control
Exhaust Gas Recirculation (EGR) Valve
303-13 Evaporative Emissions
Evaporative Emission Canister Purge Valve
303-14A Electronic Engine Controls
Engine Control
Engine Control - Compressed Natural Gas (CNG)/Ethanol/Liquefied Petroleum Gas (LPG)
Accelerator Pedal Position (APP) Sensor
Brake Pedal Position (BPP) Switch
Clutch Pedal Position (CPP) Switch
Vehicle Speed Sensor 1 (VSS1)
Catalyst Monitor Sensor
Crankshaft Position (CKP) Sensor
Engine Coolant Temperature (ECT) Sensor - A
Engine Oil Pressure (EOP) Switch
Heated Oxygen Sensor (HO2S)
Intake Camshaft Position (CMP) Sensor
Intake Variable Camshaft Timing (VCT) Oil Control Solenoid
Knock Sensor (KS)
Manifold Absolute Pressure and Temperature (MAPT) Sensor
Powertrain Control Module (PCM) - A
Powertrain Control Module (PCM) - B
Powertrain Control Module (PCM) - C
Power Steering Pressure (PSP) Switch
Throttle Control Unit
303-14B Electronic Engine Controls
Engine Control - 2.2L Duratorq-TDCi (88kW/120PS) - Puma
Engine Control - 2.2L Duratorq-TDCi (110kW/150PS) - Puma/2.2L Duratorq-TDCi (88kW/120PS) - Puma/2.2L Duratorq-TDCi (96kW/130PS) - Puma, Vehicles With: 5-Speed Manual Transmission - MT75/6-Speed Manual Transmission - MT82
Engine Control - 2.2L Duratorq-TDCi (110kW/150PS) - Puma/2.2L Duratorq-TDCi (88kW/120PS) - Puma/2.2L Duratorq-TDCi (96kW/130PS) - Puma, Vehicles With: 6-Speed Automatic Transmission - 6R80
Engine Control - 2.2L Duratorq-TDCi (110kW/150PS) - Puma, Vehicles With: 6-Speed Automatic Transmission - 6R80, Emission Requirements: DGA Emissions
Engine Control - 3.2L Duratorq-TDCi (148kW/200PS) - Puma, Vehicles With: 6-Speed Manual Transmission - MT82
Engine Control - 3.2L Duratorq-TDCi (148kW/200PS) - Puma, Vehicles With: 6-Speed Automatic Transmission - 6R80
Engine Control - 3.2L Duratorq-TDCi (148kW/200PS) - Puma, Vehicles With: 6-Speed Automatic Transmission - 6R80, Emission Requirements: DGA Emissions
Crankshaft Position (CKP) Sensor - A
Diesel Particulate Filter (DPF) Differential Pressure Sensor
Engine Oil Pressure (EOP) Switch - A
Exhaust Gas Temperature Sensor
Fuel Rail Temperature Sensor
Fuel Temperature Sensor
Intake Air Temperature (IAT) Sensor
Intake Camshaft Position (CMP) Sensor - A
Manifold Absolute Pressure (MAP) Sensor
Mass Air Flow and Temperature (MAFT) Sensor
Post DPF Exhaust Gas Temperature Sensor
Pre DPF Exhaust Gas Temperature Sensor
Throttle Control Unit - A
Wastegate Control Solenoid
307-01 Automatic Transmission
Automatic Transmission - LHD 4WD/LHD RWD
Automatic Transmission - RHD 4WD/RHD RWD
Transmission Control Module (TCM)
Transmission Control Unit Solenoids
307-05 Automatic Transmission External Controls
Transmission Control Switch (TCS)
Manual Transmission, Clutch and Transfer Case
308-07 Four-Wheel Drive Systems
Four-Wheel Drive Systems - 2.5L Duratec-HE (122kW/165PS) - MI4, Vehicles With: Electronic Locking Differential (ELD)
Four-Wheel Drive Systems - 2.5L Duratec-HE (122kW/165PS) - MI4, Vehicles Without: Electronic Locking Differential (ELD)
Four-Wheel Drive Systems - 2.2L Duratorq-TDCi (110kW/150PS) - Puma/2.2L Duratorq-TDCi (88kW/120PS) - Puma/2.2L Duratorq-TDCi (96kW/130PS) - Puma/3.2L Duratorq-TDCi (148kW/200PS) - Puma, Vehicles With: Electronic Locking Differential (ELD)
Four-Wheel Drive Systems - 2.2L Duratorq-TDCi (110kW/150PS) - Puma/2.2L Duratorq-TDCi (88kW/120PS) - Puma/2.2L Duratorq-TDCi (96kW/130PS) - Puma/3.2L Duratorq-TDCi (148kW/200PS) - Puma, Vehicles Without: Electronic Locking Differential (ELD)
Mode Select Switch (MSS)
Transfer Case Shift Motor
Exhaust System
309-00 Exhaust System
Fuel Vaporizer System Glow Plug
Fuel Vaporizer System Fuel Pump
Fuel System - General Information
310-00A Fuel System - General Information
Fuel Supply
310-00B Fuel System - General Information
Fuel Supply
310-01A Fuel Tank and Lines
Fuel Pump and Sender Unit
Fuel Level Sensor - A
Inertia Fuel Shutoff (IFS) Switch
310-01B Fuel Tank and Lines
Water-in-Fuel Sensor
310-03 Speed Control
Speed Control
Climate Control System
412-01 Climate Control
Climate Control - LHD 4WD/LHD RWD, Vehicles Without: Air Conditioning
Climate Control - RHD 4WD/RHD RWD, Vehicles Without: Air Conditioning
Climate Control - 2.5L Duratec-HE (122kW/165PS) - MI4, LHD 4WD/LHD RWD, Vehicles With: Manual Temperature Control
Climate Control - 2.5L Duratec-HE (122kW/165PS) - MI4, RHD 4WD/RHD RWD, Vehicles With: Manual Temperature Control
Climate Control - 2.5L Duratec-HE (122kW/165PS) - MI4, LHD 4WD/LHD RWD, Vehicles With: Dual Automatic Temperature Control
Climate Control - 2.5L Duratec-HE (122kW/165PS) - MI4, RHD 4WD/RHD RWD, Vehicles With: Dual Automatic Temperature Control
Climate Control - 2.2L Duratorq-TDCi (110kW/150PS) - Puma/2.2L Duratorq-TDCi (88kW/120PS) - Puma/2.2L Duratorq-TDCi (96kW/130PS) - Puma/3.2L Duratorq-TDCi (148kW/200PS) - Puma, LHD 4WD/LHD RWD, Vehicles With: Manual Temperature Control
Climate Control - 2.2L Duratorq-TDCi (110kW/150PS) - Puma/2.2L Duratorq-TDCi (88kW/120PS) - Puma/2.2L Duratorq-TDCi (96kW/130PS) - Puma/3.2L Duratorq-TDCi (148kW/200PS) - Puma, RHD 4WD/RHD RWD, Vehicles With: Manual Temperature Control
Climate Control - 2.2L Duratorq-TDCi (110kW/150PS) - Puma/2.2L Duratorq-TDCi (88kW/120PS) - Puma/2.2L Duratorq-TDCi (96kW/130PS) - Puma/3.2L Duratorq-TDCi (148kW/200PS) - Puma, LHD 4WD/LHD RWD, Vehicles With: Dual Automatic Temperature Control
Climate Control - 2.2L Duratorq-TDCi (110kW/150PS) - Puma/2.2L Duratorq-TDCi (88kW/120PS) - Puma/2.2L Duratorq-TDCi (96kW/130PS) - Puma/3.2L Duratorq-TDCi (148kW/200PS) - Puma, RHD 4WD/RHD RWD, Vehicles With: Dual Automatic Temperature Control
Air Conditioning (A/C) Dual Pressure Switch
Air Conditioning (A/C) Pressure Transducer
Ambient Air Temperature Sensor
Blower Motor
Blower Motor Control Module
Blower Motor Resistor
Heating, Ventilation and Air Conditioning (HVAC) Control Module
Heating, Ventilation and Air Conditioning (HVAC) Control Module - A
Heating, Ventilation and Air Conditioning (HVAC) Control Module - B
Air Conditioning (A/C) Clutch and Air Conditioning (A/C) Clutch Field Coil
Air Distribution Door Actuator
Air Distribution Door Actuator - A
Evaporator Temperature Sensor
Evaporator Temperature Sensor - A
Air Inlet Door Actuator
Air Inlet Door Actuator - A
Sunload Sensor
Temperature Door Actuator
Temperature Door Actuator LH
Temperature Door Actuator RH
Instrumentation and Warning Systems
413-01 Instrument Panel Cluster (IPC)
Instrument Panel Cluster (IPC) - LHD 4WD/LHD RWD
Instrument Panel Cluster (IPC) - RHD 4WD/RHD RWD
413-06 Horn
Horn
Horn
Horn - A
413-08 Information and Message Center
Message Center - LHD 4WD/LHD RWD
Message Center - RHD 4WD/RHD RWD
Information Center Module (ICM)
Information Center Module (ICM) - A
Information Center Module (ICM) - B
Information Center Module (ICM) - C
Information Center Module (ICM) - D
Information Center Module (ICM) - E
Information Center Module (ICM) - F
Information Center Module (ICM) - G
Information Center Module (ICM) - H
413-09 Warning Chimes
Low Washer Fluid Warning Indicator Switch
413-13 Parking Aid
Parking Aid - LHD 4WD/LHD RWD, Vehicles With: Parking Aid Camera
Parking Aid - LHD 4WD/LHD RWD, Vehicles Without: Parking Aid Camera
Parking Aid - RHD 4WD/RHD RWD, Vehicles With: Parking Aid Camera
Parking Aid - RHD 4WD/RHD RWD, Vehicles Without: Parking Aid Camera
Parking Assist Control Module (PAM)
Parking Assist Control Module (PAM) - A
Rear Inner Parking Aid Sensor LH/Center
Rear Inner Parking Aid Sensor RH
Rear Outer Parking Aid Sensor LH
Rear Outer Parking Aid Sensor RH
Rear Parking Aid Camera
413-17 Tachograph
Tachograph
Battery and Charging System
414-01 Battery, Mounting and Cables
Battery - A
Battery - C
Battery Monitoring Sensor
414-02 Generator and Regulator
Charging System - 2.5L Duratec-HE (122kW/165PS) - MI4
Charging System - 2.2L Duratorq-TDCi (110kW/150PS) - Puma/2.2L Duratorq-TDCi (88kW/120PS) - Puma/2.2L Duratorq-TDCi (96kW/130PS) - Puma
Charging System - 3.2L Duratorq-TDCi (148kW/200PS) - Puma
Generator
Generator - A
Information and Entertainment Systems
415-00 Information and Entertainment System - General Information
Accessory Protocol Interface Module (APIM) - A
Accessory Protocol Interface Module (APIM) - B
415-01 Information and Entertainment System
Audio System - Single Cab, LHD 4WD/LHD RWD, Vehicles With: Single DIN Standard Audio Unit
Audio System - Single Cab, RHD 4WD/RHD RWD, Vehicles With: Single DIN Standard Audio Unit
Audio System - Double Cab, LHD 4WD/LHD RWD, Vehicles With: Single DIN Standard Audio Unit
Audio System - Double Cab, RHD 4WD/RHD RWD, Vehicles With: Single DIN Standard Audio Unit
Audio System - Super Cab, LHD 4WD/LHD RWD, Vehicles With: Single DIN Standard Audio Unit
Audio System - Super Cab, RHD 4WD/RHD RWD, Vehicles With: Single DIN Standard Audio Unit
Audio System - Single Cab, LHD 4WD/LHD RWD, Vehicles With: Bluetooth and Voice Control
Audio System - Single Cab, LHD 4WD/LHD RWD, Vehicles Without: Bluetooth and Voice Control
Audio System - Double Cab, LHD 4WD/LHD RWD, Vehicles With: Bluetooth and Voice Control
Audio System - Double Cab, LHD 4WD/LHD RWD, Vehicles Without: Bluetooth and Voice Control
Audio System - Super Cab, LHD 4WD/LHD RWD, Vehicles With: Bluetooth and Voice Control
Audio System - Super Cab, LHD 4WD/LHD RWD, Vehicles Without: Bluetooth and Voice Control
Audio System - Single Cab, RHD 4WD/RHD RWD, Vehicles With: Bluetooth and Voice Control
Audio System - Single Cab, RHD 4WD/RHD RWD, Vehicles Without: Bluetooth and Voice Control
Audio System - Double Cab, RHD 4WD/RHD RWD, Vehicles With: Bluetooth and Voice Control
Audio System - Double Cab, RHD 4WD/RHD RWD, Vehicles Without: Bluetooth and Voice Control
Audio System - Super Cab, RHD 4WD/RHD RWD, Vehicles With: Bluetooth and Voice Control
Audio System - Super Cab, RHD 4WD/RHD RWD, Vehicles Without: Bluetooth and Voice Control
Audio Input Socket
Audio Unit
Audio Unit - A
Audio Unit - J
Cellular Phone Microphone
Speech Recognition Module (SPRM) - A
Speech Recognition Module (SPRM) - B
Front Door Speaker LH
Front Door Speaker RH
Front Door Tweeter Speaker LH
Front Door Tweeter Speaker RH
Front Controls Interface Module (FCIM)
Information and Entertainment Unit
Information and Entertainment Unit - A
Information and Entertainment Unit - B
Information and Entertainment Unit - D
Information and Entertainment Unit - F
Information and Entertainment Unit - K
Noise Suppression Capacitor
Rear Door Speaker LH
Rear Door Speaker RH
Audio Unit - B
Information and Entertainment Unit - E
Information and Entertainment Unit - J
Universal Serial Bus (USB) Module
Universal Serial Bus (USB) Module - A
Lighting
417-01 Exterior Lighting
Autolamps - LHD 4WD/LHD RWD
Autolamps - RHD 4WD/RHD RWD
Exterior Lighting - LHD 4WD/LHD RWD
Exterior Lighting - RHD 4WD/RHD RWD
Fog Lamps - LHD 4WD/LHD RWD
Fog Lamps - RHD 4WD/RHD RWD
Headlamp Leveling
Trailer Socket - LHD 4WD/LHD RWD
Trailer Socket - RHD 4WD/RHD RWD
Turn Signal and Hazard Lamps - LHD 4WD/LHD RWD
Turn Signal and Hazard Lamps - RHD 4WD/RHD RWD
Front Fog Lamp LH
Front Fog Lamp RH
Front Side Marker Lamp LH
Front Side Marker Lamp RH
Headlamp Assembly LH
Headlamp Assembly RH
Headlamp Control Module
Headlamp Control Module - A
Headlamp Leveling Switch
High Mounted Stoplamp
License Plate Lamp
License Plate Lamp - A
Parking Lamp LH
Parking Lamp RH
Rear Lamp Assembly LH
Rear Lamp Assembly RH
Reversing Lamp Switch
Side Turn Signal Lamp LH
Side Turn Signal Lamp RH
Stoplamp Switch
Trailer Socket
Trailer Socket - A
Trailer Socket - B
Trailer Socket - C
Trailer Socket - D
Trailer Socket - E
Trailer Socket - F
Trailer Socket - G
Trailer Socket - H
Trailer Socket - J
Trailer Module
Trailer Module - A
Trailer Module - B
417-02 Interior Lighting
Courtesy and Demand Lighting - Double Cab, LHD 4WD/LHD RWD
Courtesy and Demand Lighting - Double Cab, RHD 4WD/RHD RWD
Courtesy and Demand Lighting - Single Cab, LHD 4WD/LHD RWD
Courtesy and Demand Lighting - Single Cab, RHD 4WD/RHD RWD
Courtesy and Demand Lighting - Super Cab, LHD 4WD/LHD RWD
Courtesy and Demand Lighting - Super Cab, RHD 4WD/RHD RWD
Instrument Panel Cluster (IPC) and Panel Illumination - LHD 4WD/LHD RWD
Instrument Panel Cluster (IPC) and Panel Illumination - RHD 4WD/RHD RWD
Footwell Lamp LH
Footwell Lamp RH
Front Door Trim Panel Ambient Lighting Lamp LH
Front Door Trim Panel Ambient Lighting Lamp RH
Glove Compartment Lamp
Interior Front Door Handle Ambient Lighting Lamp LH
Interior Front Door Handle Ambient Lighting Lamp RH
Overhead Ambient Lighting Lamp
Overhead Ambient Lighting Lamp - A
Overhead Ambient Lighting Lamp - B
Rear Interior Lamp
Rear Interior Lamp - A
417-04 Daytime Running Lamps (DRL)
Daytime Running Lamp LH
Daytime Running Lamp RH
Electrical Distribution
418-00 Module Communications Network
Communications Network - High-Speed (HS) Controller Area Network (CAN) Bus - Vehicles With: 5-Speed Manual Transmission - MT75/6-Speed Manual Transmission - MT82
Communications Network - High-Speed (HS) Controller Area Network (CAN) Bus - Vehicles With: 6-Speed Automatic Transmission - 6R80
Communications Network - Local Interconnect Network (LIN) Bus - 2.5L Duratec-HE (122kW/165PS) - MI4, LHD 4WD/LHD RWD
Communications Network - Local Interconnect Network (LIN) Bus - 2.5L Duratec-HE (122kW/165PS) - MI4, RHD 4WD/RHD RWD
Communications Network - Local Interconnect Network (LIN) Bus - 2.2L Duratorq-TDCi (110kW/150PS) - Puma/2.2L Duratorq-TDCi (88kW/120PS) - Puma/2.2L Duratorq-TDCi (96kW/130PS) - Puma/3.2L Duratorq-TDCi (148kW/200PS) - Puma, LHD 4WD/LHD RWD
Communications Network - Local Interconnect Network (LIN) Bus - 2.2L Duratorq-TDCi (110kW/150PS) - Puma/2.2L Duratorq-TDCi (88kW/120PS) - Puma/2.2L Duratorq-TDCi (96kW/130PS) - Puma/3.2L Duratorq-TDCi (148kW/200PS) - Puma, RHD 4WD/RHD RWD
Communications Network - Mid-Speed (MS) Controller Area Network (CAN) Bus
Communications Network - Multimedia (MM) Controller Area Network (CAN) Bus
Diagnostics
Central Junction Box (CJB) - A
Central Junction Box (CJB) - B
Central Junction Box (CJB) - C
Central Junction Box (CJB) - D
Central Junction Box (CJB) - E
Central Junction Box (CJB) - F
Central Junction Box (CJB) - G
Central Junction Box (CJB) - H
Data Link Connector (DLC)
Engine Junction Box (EJB)
Engine Junction Box (EJB) - A
Electronic Feature Group
419-01A Perimeter Anti-Theft Alarm
Anti-Theft Alarm System - Double Cab, LHD 4WD/LHD RWD
Anti-Theft Alarm System - Double Cab, RHD 4WD/RHD RWD
Anti-Theft Alarm System - Single Cab, LHD 4WD/LHD RWD
Anti-Theft Alarm System - Single Cab, RHD 4WD/RHD RWD
Anti-Theft Alarm System - Super Cab, LHD 4WD/LHD RWD
Anti-Theft Alarm System - Super Cab, RHD 4WD/RHD RWD
Anti-Theft Alarm Horn
Anti-Theft Alarm Horn with Integral Battery
Anti-Theft Alarm Module
Hood Switch
Intrusion Sensor
419-01B Passive Anti-Theft System (PATS)
Passive Anti-Theft System (PATS) Transceiver
419-03 Cruise Control
Cruise Control Switch
419-10 Multifunction Electronic Modules
Driver Door Module (DDM)
Driver Door Module (DDM) - A
Passenger Door Module (PDM)
Passenger Door Module (PDM) - A
Rear Door Module (RDM) LH
Rear Door Module (RDM) RH
Body and Paint
501-09 Rear View Mirrors
Auto-Dimming Interior Mirror
Power Exterior Mirrors - LHD 4WD/LHD RWD
Power Exterior Mirrors - RHD 4WD/RHD RWD
Exterior Mirror Control Switch
Exterior Mirror LH
Exterior Mirror RH
501-10 Seating
Heated Seats - LHD 4WD/LHD RWD
Heated Seats - RHD 4WD/RHD RWD
Power Seats - LHD 4WD/LHD RWD
Power Seats - RHD 4WD/RHD RWD
501-11 Glass, Frames and Mechanisms
Heated Windshield and Rear Window - LHD 4WD/LHD RWD
Heated Windshield and Rear Window - RHD 4WD/RHD RWD
Power Windows - LHD 4WD/LHD RWD, Vehicles With: Door Module
Power Windows - LHD 4WD/LHD RWD, Vehicles Without: Door Module
Power Windows - RHD 4WD/RHD RWD, Vehicles With: Door Module
Power Windows - RHD 4WD/RHD RWD, Vehicles Without: Door Module
Driver Door Window Control Switch
Driver Door Window Control Switch - A
Driver Door Window Control Switch - B
Driver Door Window Regulator Motor
Driver Door Window Regulator Motor - A
Heated Rear Window Element
Heated Rear Window Element - A
Heated Windshield Element LH
Heated Windshield Element RH
Passenger Door Window Control Switch
Passenger Door Window Control Switch - A
Passenger Door Window Regulator Motor
Passenger Door Window Regulator Motor - A
Rear Door Window Control Switch LH
Rear Door Window Control Switch LH - A
Rear Door Window Control Switch RH
Rear Door Window Control Switch RH - A
Rear Door Window Regulator Motor LH
Rear Door Window Regulator Motor LH - A
Rear Door Window Regulator Motor RH
Rear Door Window Regulator Motor RH - A
501-12 Instrument Panel and Console
Cigar Lighter
Front Power Outlet Socket
Luggage Compartment Power Outlet Socket
Rear Passenger Power Outlet Socket
Rear Passenger Power Outlet Socket - A
501-14 Handles, Locks, Latches and Entry Systems
Power Door Locks - LHD 4WD/LHD RWD
Power Door Locks - RHD 4WD/RHD RWD
Central Locking Lock/Unlock Switch
Driver Door Latch
Driver Door Latch - A
Fuel Filler Door Latch Motor
Passenger Door Latch - A
Rear Door Latch LH
Rear Door Latch LH - A
Rear Door Latch RH
Rear Door Latch RH - A
Radio Frequency (RF) Receiver
501-16 Wipers and Washers
Wipers and Washers - LHD 4WD/LHD RWD
Wipers and Washers - RHD 4WD/RHD RWD
Rain Sensor
Windshield Washer Pump
Windshield Wiper Motor
Windshield Wiper/Washer Switch
Windshield Wiper/Washer Switch - A
501-20A Safety Belt System
Driver Safety Belt Pretensioner
Passenger Safety Belt Pretensioner
Rear Safety Belt Retractor and Pretensioner
501-20B Supplemental Restraint System
Airbags and Safety Belt Pretensioners - Double Cab, LHD 4WD/LHD RWD, Vehicles With: Passenger Airbag Deactivation Switch
Airbags and Safety Belt Pretensioners - Double Cab, LHD 4WD/LHD RWD, Vehicles Without: Passenger Airbag Deactivation Switch
Airbags and Safety Belt Pretensioners - Double Cab, RHD 4WD/RHD RWD, Vehicles With: Passenger Airbag Deactivation Switch
Airbags and Safety Belt Pretensioners - Double Cab, RHD 4WD/RHD RWD, Vehicles Without: Passenger Airbag Deactivation Switch
Airbags and Safety Belt Pretensioners - Single Cab, LHD 4WD/LHD RWD, Vehicles With: Passenger Airbag Deactivation Switch
Airbags and Safety Belt Pretensioners - Single Cab, LHD 4WD/LHD RWD, Vehicles Without: Passenger Airbag Deactivation Switch
Airbags and Safety Belt Pretensioners - Single Cab, RHD 4WD/RHD RWD, Vehicles With: Passenger Airbag Deactivation Switch
Airbags and Safety Belt Pretensioners - Single Cab, RHD 4WD/RHD RWD, Vehicles Without: Passenger Airbag Deactivation Switch
Airbags and Safety Belt Pretensioners - Super Cab, LHD 4WD/LHD RWD, Vehicles With: Passenger Airbag Deactivation Switch
Airbags and Safety Belt Pretensioners - Super Cab, LHD 4WD/LHD RWD, Vehicles Without: Passenger Airbag Deactivation Switch
Airbags and Safety Belt Pretensioners - Super Cab, RHD 4WD/RHD RWD, Vehicles With: Passenger Airbag Deactivation Switch
Airbags and Safety Belt Pretensioners - Super Cab, RHD 4WD/RHD RWD, Vehicles Without: Passenger Airbag Deactivation Switch
Clockspring
Clockspring - A
Driver Door Side Impact Sensor
Driver Lower Airbag
Driver Side Air Curtain
Front Impact Severity Sensor
Passenger Airbag Deactivation (PAD) Indicator
Passenger Airbag Deactivation (PAD) Switch
Passenger Airbag
Passenger Side Air Curtain
Passenger Door Side Impact Sensor
Restraints Control Module (RCM)
Restraints Control Module (RCM) - A
Side Impact Sensor LH
Side Impact Sensor RH
Wiring Information
700-00 General Information
B-Pillar LH - Single Cab
B-Pillar RH - Single Cab
B-Pillar LH - Super Cab
B-Pillar RH - Super Cab
Central Junction Box (CJB) - LHD
Central Junction Box (CJB) - RHD
Climate Control Assembly - Vehicles With: Dual Automatic Temperature Control, LHD
Climate Control Assembly - Vehicles With: Manual Temperature Control, LHD
Climate Control Assembly - Vehicles With: Air Conditioning, LHD
Climate Control Assembly - Vehicles Without: Air Conditioning, LHD
Climate Control Assembly - Vehicles With: Dual Automatic Temperature Control, RHD
Climate Control Assembly - Vehicles With: Manual Temperature Control, RHD
Climate Control Assembly - Vehicles With: Air Conditioning, RHD
Climate Control Assembly - Vehicles Without: Air Conditioning, RHD
Driver Door Interior View - Double Cab, LHD
Driver Door Interior View - Single Cab/Super Cab, LHD
Driver Door Interior View - Double Cab, RHD
Driver Door Interior View - Single Cab/Super Cab, RHD
Engine Compartment LH View - LHD
Engine Compartment LH View - RHD
Engine Compartment RH View - LHD
Engine Compartment RH View - RHD
Engine LH View - 2.5L Duratec-HE (122kW/165PS) - MI4
Engine RH View - 2.5L Duratec-HE (122kW/165PS) - MI4
Engine LH View - 2.5L Duratec-HE (122kW/165PS) - MI4, Compressed Natural Gas (CNG)/Ethanol/Liquefied Petroleum Gas (LPG)
Engine RH View - 2.5L Duratec-HE (122kW/165PS) - MI4, Compressed Natural Gas (CNG)/Ethanol/Liquefied Petroleum Gas (LPG)
Engine Upper View - 2.5L Duratec-HE (122kW/165PS) - MI4, Compressed Natural Gas (CNG)/Ethanol/Liquefied Petroleum Gas (LPG)
Engine LH View - 2.2L Duratorq-TDCi (110kW/150PS) - Puma/2.2L Duratorq-TDCi (88kW/120PS) - Puma/2.2L Duratorq-TDCi (96kW/130PS) - Puma
Engine RH View - 2.2L Duratorq-TDCi (88kW/120PS) - Puma/2.2L Duratorq-TDCi (96kW/130PS) - Puma
Engine RH View - 2.2L Duratorq-TDCi (110kW/150PS) - Puma
Engine Upper View - 2.2L Duratorq-TDCi (110kW/150PS) - Puma/2.2L Duratorq-TDCi (88kW/120PS) - Puma
Engine LH View - 3.2L Duratorq-TDCi (148kW/200PS) - Puma
Engine RH View - 3.2L Duratorq-TDCi (148kW/200PS) - Puma
Engine Upper View - 3.2L Duratorq-TDCi (148kW/200PS) - Puma
Front Fender LH
Front Fender RH
Front Floor LH View - Single Cab, LHD
Front Floor RH View - Single Cab, LHD
Front Floor LH View - Double Cab, LHD
Front Floor RH View - Double Cab, LHD
Front Floor LH View - Super Cab, LHD
Front Floor RH View - Super Cab, LHD
Front Floor LH View - Single Cab, RHD
Front Floor RH View - Single Cab, RHD
Front Floor LH View - Double Cab, RHD
Front Floor RH View - Double Cab, RHD
Front Floor LH View - Super Cab, RHD
Front Floor RH View - Super Cab, RHD
Fuel Tank
Headliner - Single Cab, LHD
Headliner - Double Cab, LHD
Headliner - Super Cab, LHD
Headliner - Single Cab, RHD
Headliner - Double Cab, RHD
Headliner - Super Cab, RHD
Instrument Panel - LHD
Instrument Panel - RHD
Passenger Door Interior View - Single Cab/Super Cab, LHD
Passenger Door Interior View - Double Cab, RHD
Passenger Door Interior View - Single Cab/Super Cab, RHD
Rear Bumper
Rear Door LH Interior View
Rear Door RH Interior View
Rear Axle
Rear Under Floor View
Steering Column Switches Front View
Steering Column Switches Rear View
Steering Wheel
Transmission LH View - Vehicles With: 5-Speed Manual Transmission - MT75 4x2
Transmission RH View - Vehicles With: 6-Speed Manual Transmission - MT82 4x2
Transmission RH View - Vehicles With: 6-Speed Automatic Transmission - 6R80 4x2
Transmission LH View - Vehicles With: 5-Speed Manual Transmission - MT75 4x4
Transmission RH View - Vehicles With: 6-Speed Manual Transmission (MT82 4x4)
Transmission RH View - Vehicles With: 6-Speed Automatic Transmission - 6R80 4x4
Passenger Door Interior View - Double Cab, LHD 4WD/LHD RWD
700-01 Fuse and Relay Information
Central Junction Box (CJB) - LHD 4WD/LHD RWD
Central Junction Box (CJB) - RHD 4WD/RHD RWD
700-02 Power Distribution
Cigar Lighter and Power Points - LHD 4WD/LHD RWD
Cigar Lighter and Power Points - RHD 4WD/RHD RWD
Power Distribution
700-03 Grounding Strategy
Grounding - LHD
Grounding - RHD
700-04 Electrical Connectors
In-Line Connector 11 - A
In-Line Connector 11 - AA
In-Line Connector 11 - B
In-Line Connector 11 - C
In-Line Connector 11 - D
In-Line Connector 11 - E
In-Line Connector 11 - F
In-Line Connector 13
In-Line Connector 21
In-Line Connector 23
In-Line Connector 25
In-Line Connector 25 - A
In-Line Connector 26
In-Line Connector 26 - A
In-Line Connector 29
In-Line Connector 30
In-Line Connector 31
In-Line Connector 33
In-Line Connector 34
In-Line Connector 34 - A
In-Line Connector 34 - B
In-Line Connector 37
In-Line Connector 37 - A
In-Line Connector 38
In-Line Connector 38 - A
In-Line Connector 44
In-Line Connector 44 - A
In-Line Connector 44 - B
In-Line Connector 44 - C
In-Line Connector 44 - D
In-Line Connector 44 - E
In-Line Connector 44 - F
lasonf
Nó đây cụ anhchangbibibi:
ckd141451B
à cái này mình có, nhưng mình muốn 1 dạng tài liệu kiểu tìm hiểu rõ từng hệ thống. Vd: Headlamps thì có những giắc nối gì, mạch điện ra sao, chẩn đoán hư hỏng và khắc phục như thế nào? Như dạng tài liệu đào tạo cho KTV ấy. ^^
