Xích xe Hitachi UH25-7
Bình luận: 0Lượt xem: 653
hailualaimay
CÁC BÁC CHO EM HỎI NHỜ CHÚT,,LÀ TÌNH HÌNH EM CÓ CON HITACHI UH25-7,,,NÓ BỊ HƯ MẮC XÍCH,,NHƯNG MỘT SỐ BẠN NGHỀ XEM XE THÌ BẢO CÁI XÍCH NÀY KHÔNG PHẢI CỦA NÓ (RẤT NHẠY TRẬT XÍCH),,VỚI LẠI KHI MUA LẠI NGƯỜI TA CŨNG CÓ CẮT BỚT MẮC XÍCH,,,GIỜ EM KHÔNG BÍT NÓ NGUYÊN BẢN CÓ BAO NHIÊU MẮC XÍCH NỮA,,,XIN CÁC BÁC MÁCH GIÚP CHO,VÌ GIỜ ĐI MUA THÌ CŨNG PHẢI BIẾT LIỆU CÓ PHẢI XÍCH CỦA NÓ KHÔNG ĐỂ LÀM MẨU NỮA,EM NHÌN 4 CON BULON ĐÍNH BẢN XÍCH VÀO MẮC XÍCH VỊ TRÍ ĐỀU NHAU CẢ 4 LỔ NHƯ HÌNH VUÔNG,,VÌ HÌNH NHƯ CÓ LOẠI VỊ TRÍ HAI CON TRÊN DÀI HƠN HAI CON DƯỚI ( TẤT LÀ NỐI LẠI 4 CON SẼ CHO RA HÌNH THANG ẤY),,CÓ 2 CHIẾC Ở GẦN THÌ EM ĐẾN XEM MẪU THÌ NÓ ĐỘ XÍCH XE KHÁC QUA,....THẾ MỚI ĐẮNG...CẢM ƠN CÁC BÁC
