Tiêu Đề : Wiring Diagram VW (Volkswagen) Guide
Ngôn Ngữ: Tiếng Anh
Đinh Dạng: pdf
Dung Lượng : 84 kb
This is pdf file online ebooks download information link about Manual Wiring Diagram VW (Volkswagen) Guide. Book contain detail information about electric wiring diagram, simple owners manual guide, service and repair manual. This is we recomended for you as the owners for this vehicle or you are the mechanic.
How to read wiring diagrams
Ngôn Ngữ: Tiếng Anh
Đinh Dạng: pdf
Dung Lượng : 84 kb
- Relay location number Indicates location on relay panel.
- Arrow Indicates wiring circuit is continued on the previous and/or next page.
- Connection designation – relay control module on relay panel Shows the individual terminals in a multi-point connector.For example: contact 24 on terminal on relay panel.
- Diagram of threaded pin on relay panel White circle shows a detachable connection.
- Fuse designation For example: S228 = Fuse number 28, 15 amps, in fuse holder
- Reference of wire continuation (current track number) Number in frame indicates current track where wire is continued.
- Wire connection designation in wiring harness Location of wire connections are indicated in the legend.
- download for more…..
Download Now
Wiring Diagram VW (Volkswagen) Guide.txt 0326 bytes · Xem: 119
