Volvo VIDA2011-A Final
W
Bình luận: 0Lượt xem: 1,385
www.maychandoanoto.com
7.42 GB
Original factory software for Volvo vehicles. Replaces old Volvo Vadis. It contains detailed service and repair manuals and electronic spare part catalogues. Also there is a search by VIN number.
1. VIDA (Vehicle Information & Diagnostics for Aftersales) and contains service manuals, electronic parts catalogs, service bulletins, fault tracing and onboard diagnostics. Volvo 1982-2010 models.
2. VOLVO ELECTRONIC WIRING DIAGRAM for all the models 2005-2010
VIDA is compatible with Windows XP Pro.
EWD can run either installed or directly from the DVD so can be used on XP, Vista or Windows 7
Both DVDs are in English
VIDA can be run standalone on the computer as a service/parts manual or can be hooked-up to the car with VCT2000.
DICE or J2534 and used as a diagnosis tool
VCT2000 or DICE are not included in the auction
No internet connection is needed - everything runs from your computer.
These are the DVDs used by the dealers
VIDA is the only comprehensive, single source of service information and specifications available specifically for Volvo. The aim throughout this manual has been simplicity, clarity and completeness, with practical explanations, step-by-step procedures, and accurate specifications. Whether you're a professional or a do-it-yourself owner, this DVD will help you understand, care for, and repair your car. Crystal clear pictures and diagrams with step by step instructions. Bid with confidence - This is the only DVD used by professional technicians to fix you car - not an aftermarket manual.
