Volvo Advanced Diagnostics only PTT (88890020)
L
Bình luận: 0Lượt xem: 1,534
localhost
Only tested with original interface volvo 88890020
You can take and replay logfiles
you can read out all serialnumbers, software numbers
you can read out fault codes and delete them
you can make some tests on some ecus to look which in/output is set to what
you can see which ecu sends what
http://www.mediafire.com/?nfqv92cby4vduxu
