[Vô lăng vàng] Kỳ 1 : RODA
khoadongluc
Bình luận: 4Lượt xem: 1,103
khoadongluc
Nothing Is Impossible
Đây là một số câu hỏi tập dượt 3 kỳ đầu nên anh em sẽ kết quả Vào dưới câu trả lời này nhé ! Chủ đề đầu tiên anh em mình sẽ roda để chuẩn bị bước vào cuộc thi hãy thử xem hka3 năng của mình nhé . Thời gian sẽ bắt đầu từ 24/10 -->> 30/10
Click on the best answer:
1. How many revolutions of the crankshaft are there in a four-stroke cycle?
A: One B: Two C: Four D: It varies with engine speed
2. How many degrees of rotation of the crankshaft are there in a cycle?
A: Four B: 360 C: 720 D: It varies with engine speed
3. How many degrees of crankshaft rotation are there between power strokes in a single cylinder engine?
A: 360 B: 720 C: 180 D: 90
4. How many degrees of crankshaft rotation are there between power strokes in a four cylinder engine?
5. How many degrees of crankshaft rotation are there between power strokes in a V-eight engine?
6. Which engine would run the smoothest?
A: V-eight B: inline six C: inline four D: single
Compression Stroke
7. Which way is the piston going on the compression stroke?
A: Upward B: Downward C: Clockwise D: Counterclockwise
8. So the volume of the cylinder's getting...?
A: Larger B: Smaller C: Stays the same D: I don't know
9. ...and the pressure is getting...?
A: Higher B: Lower C: Stays the same D: I don't know
10. How much pressure is created? (in a normal modern engine)
A: 14.7 PSI B: 500 PSI C: 6000 PSI D: 150 PSI
11. Which valve is open ?
A: Intake B: Exhaust C: Neither D: Compression
12. What happens to the temperature of a gas that's being compressed?
A: It goes down B: It stays the same C: It goes up D: It doesn't matter
13. In a gasoline engine, what happens to the air/fuel mixture if it's temperature gets higher than the flash point of the fuel?
A: It explodes, causing engine damage B: It gives more power
C: It make no difference D: It makes the spark plugs last longer.
Exhaust Stroke
14.Which way is the piston going on the exhaust stroke?
15.So the volume of the cylinder is getting...?
16.... and the pressure is getting...?
A: Higher B: Lower (vacuum) C: Stays the same D: I don't know
17. Which valve is open?
Intake Stroke
18.Which way is the piston going on the intake stroke?
19....and the pressure is getting...?
20.Which valve is open?
21.What is outside the engine forcing the air into the cylinder?
A: Gravity B: Suction C: the valves D: Atmospheric pressure
Power Stroke
23. Which way is the piston going on the power stroke?
24....so the volume of the cylinder is getting?
25.Which valve is open?
A: Intake B: Exhaust C: Neither D: Power
26.What starts the air/fuel mixture burning?
A: Compression B: Power valve C: Spark Plug D: Burning gas
27.What is forcing the piston down?
A: Compression B: Power valve C: Spark plug D: Burning Gas
28.What order do the four strokes go in?
A: Exhaust - Intake - Power - Compression
B: Intake - Compression - Power - Exhaust
C: Power - Power - Intake - Compression
D: Compression - Intake - Exhaust - Power
29.If an engine had a cylinder volume (between TDC and BDC) of 80 cc, and a combustion chamber volume of 10 cc, what is its' compression ratio?
A: 8 : 1 B: 9 : 1 C: 80 : 10 D: 1 : 80
30.Another name for the diameter of the cylinder is the:
A: Bore B: Circumference C: Stroke D: Throw
31.The distance between TDC and BDC is called an engine's:
32.The ____________ is exactly one half of the engines stroke.
phanminhnhat
Học việc
Em xin phép mở hàng:=d>
A: One
C: 720
B: 720
C: 180
D: 90
A: V-eight
Compression Stroke
A: Upward
B: Smaller
A: Higher
A: 14.7 PSI
C: Neither
C: It goes up
Exhaust Stroke
A: Upward
B: Smaller
A: Higher
B: Exhaust
Intake Stroke
B: Downward
A: Larger
B: Lower (vacuum)
A: Intake
Power Stroke
B: Downward
A: Larger
C: Neither
C: Spark Plug
D: Burning Gas
A: 8 : 1
A: Bore
C: Stroke
D: Throw
bikerviet
đây là của em :))
B: Two
C: 720
B: 720
D: 90
A: V-eight
Compression Stroke
A: Upward
B: Smaller
A: Higher
D: 150 PSI
C: Neither
LÀM 11 CÂU TRƯỚC MAI CHIẾN TIẾP :))
vnv811
Em xin được là người...thứ ba:
B: Two
C: 720
B: 720
C: 180
D: 90
A: V-eight
Compression Stroke
A: Upward
B: Smaller
A: Higher
A: 14.7 PSI
C: Neither
C: It goes up
Exhaust Stroke
A: Upward
B: Smaller
B: Lower (vacuum)
B: Exhaust
Intake Stroke
B: Downward
A: Larger
C: Stays the same
A: Intake
Power Stroke
B: Downward
A: Larger
C: Neither
C: Spark Plug
D: Burning Gas
A: 8 : 1
A: Bore
C: Stroke
A: Bore B: Circumference C: Stroke D: Throw[/QUOTE]
caydantinhyeu89
B: Two
C: 720
B: 720
C: 180
D: 90
A: V-eight
e làm đc mấy câu.mai suy nghĩ làm tiếp :d,mong các bác đừng chém.
