link downloda
[HIDE]http://www.mediafire.com/?2ndjnzmnkyv[/HIDE]
Common Terms ............................................................................................... 2
Adiabatic Efficiency................................................................................................................................................2
Pressure Ratio .......................................................................................................................................................2
Density Ratio..........................................................................................................................................................2
Turbine ...................................................................................................................................................................2
A/R Ratio................................................................................................................................................................2
Charge-Air-Cooler ..................................................................................................................................................2
Boost ......................................................................................................................................................................2
Waste Gate ............................................................................................................................................................2
Turbo Lag...............................................................................................................................................................3
Boost Threshold.....................................................................................................................................................3
Turbo Cool down....................................................................................................................................................3
Selecting a Turbocharger Compressor................................................................ 4
Engine Air Flow Requirements ...............................................................................................................................4
Pressure Ratio .......................................................................................................................................................4
Temperature Rise ..................................................................................................................................................4
Adiabatic Efficiency................................................................................................................................................5
Density Ratio..........................................................................................................................................................5
Compressor Inlet Airflow........................................................................................................................................5
Camshafts for Turbocharged Engines ................................................................. 6
Pressure Differential...............................................................................................................................................6
Valve Overlap.........................................................................................................................................................6
Valve Lift ................................................................................................................................................................7
Roller Camshafts....................................................................................................................................................7
Turbocharger Exploded View.............................................................................. 8
Turbocharger Troubleshooting Chart .................................................................. 9
