Toyota epc (01.2013)
S
Bình luận: 3Lượt xem: 3,150
saymon1987
Submitted electronic parts catalog TOYOTA EPC relevance to 01.2013 for TOYOTA brand vehicles. The catalog contains regions such as: JAPAN, EUROPE, USA, GENERAL. The original distribution.
1. start the SETUP program.EXE FROM Setup FOLDER 2. CLICK NEXT 3. Select the HARD DISK on which YOU WILL INSTALL the WRAPPER and the data and click NEXT 4. CLICK NEXT 5. CLICK NEXT 6. CLICK NEXT 7. CLICK FINISH 8. press start-programs-TOYOTA EPC SYSTEM-TOYOTA EPC SYSTEM 9. in the main menu select Setup Menu 10. Select the Data Configurator 11. PLEASE CHOOSE YOUR REGION (e.g. Europe) and in FRONT of EACH DISC (A1, A2, B1, etc.), SELECT the TYPE of INSTALLATION (COPY to HDD or CD), data source, and the letter of the HDD that you want to COPY the DATA. In The Sales Field, PASTE The CODE Area Code- 55555. Press The F10 Key. THIS OPERATION MUST BE PERFORMED FOR EACH REGION SEPARATELY. 12. click OK 13. press F2 14. in the main menu select Data Setup 15. on the CHOOSE YOUR REGIONS, and select all DRIVES you mentioned in PARAGRAPH 11 and press F10 16. CLICK OK 17. as the COPY WILL SHOOT OUT a plate with the REQUIREMENT to INSERT a disk. INSERT THE APPROPRIATE DISK AND CLICK OK. 18. when COPYING is COMPLETE, CLICK OK 19. press F2 20. in the main menu select Setup Menu 21. CLICK the Lexus Dealer Check 22. In The Password Field, INSERT The CODE YOU WRITE In The Password FILE, And Then Press F8 23. IF a RED CIRCLE to the LEFT of You are now regarded as a Lexus dealer BECAME the BLUE-all right. Press F2 To Return To The Main Menu-The Program Is Now Ready To Use.
Issue: 2013.01
Version: L60 R010
Language: Multilingual
Tablet: Is Present
