2008 Isuzu I-370 LS Extended Cab Pickup Performance & Efficiency Standard Features
3,653 cc 3.7 liters in-line 5 front engine with 95.5 mm bore, 102.0 mm stroke, 10.1 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder LLR
Unleaded fuel 87
Multi-point injection fuel system
19.6 gallon main unleaded fuel tank 16.3
Power: 180 kW , 242 HP SAE @ 5,600 rpm; 242 ft lb , 305 Nm @ 4,600 rpm
2008 Isuzu I-370 LS Extended Cab Pickup Handling, Ride & Braking Standard Features -
Four-wheel ABS
3.730:1 axle ratio
Rear differential lock
Two disc brakes including two ventilated discs
Electronic traction control
Immobilizer
Fullsize under body spare wheel
Torsion beam front suspension semi-independent with stabilizer bar and coil springs, beam rear suspension rigid with leaf springs
2008 Isuzu I-370 LS Extended Cab Pickup Exterior & Aerodynamics Standard Features -
Body side molding
Part-painted front bumpers, chrome rear bumpers
Chrome/bright trim on bumpers
Day time running lights
Driver and passenger power black door mirrors
External dimensions: overall length (inches): 207.1, overall width (inches): 67.6, overall height (inches): 67.9, ground clearance (inches): 7.6, wheelbase (inches): 125.9 and curb to curb turning circle (feet): 44.3
Front fog lights
Complex surface lens halogen bulb headlights
Luxury trim alloy look on dashboard
Metallic paint
Straight side pickup bed
Fixed rear window
Rear platform step
Tinted glass on cabin, rear and side
Weights: gross vehicle weight rating (lbs) 5,300, curb weight (lbs) 3,740, gross trailer weight braked (lbs) 4,000 and max payload (lbs) 1,560
Windshield wipers with variable intermittent wipe
2008 Isuzu I-370 LS Extended Cab Pickup Interior Standard Features -
12v power outlet: front and 2
Air conditioning
Fixed mast antenna
Peripheral anti-theft protection
RDS audio system with AM/FM and CD player CD player reads MP3
Automatic drive indicator on dashboard
Cargo area dimensions: length (inches): 61.1, front width (inches): 57.2, width between arches (inches): 42.6 and height (inches): 18.6
Cargo area light
Rear tailgate cargo doors
Clock
Full dashboard console, partial floor console with covered storage box
Delayed/fade courtesy lights
Cruise control
Front seats and rear seats cup holders fixed
Door ajar warning
Door pockets/bins for driver seat and passenger seat
Floor covering: carpet in passenger compartment
Floor mats
Driver front airbag with multi-stage deployment, passenger front airbag with occupant sensors and multi-stage deployment
Bucket driver and passenger seat
Height adjustable 3-point reel front seat belts on driver seat and passenger seat
Front seat center armrest
Two head restraints on front seats and rear seats
Headlight control with dusk sensor
Illuminated entry system
Internal dimensions: front headroom (inches): 39.6, rear headroom (inches): 38.3, front hip room (inches): 53.3, rear hip room (inches): 52.9, front leg room (inches): 42.2, rear leg room (inches): 34.8, front shoulder room (inches): 57.1 and rear shoulder room (inches): 57.1
Low tire pressure indicator
Remote power locks speed sensing
Power steering
Front power windows with one one-touch, rear power windows
3-point reel rear seat belts on driver side and passenger side
Three asymmetrical split bench front facing rear seats with zero adjustments
Rear view mirror
Front and rear side curtain airbag
Front seat back storage
Upgraded cloth/velour seat upholstery with additional upgraded cloth/velour
Seating: five seats
Service interval indicator
Six speaker(s) manufacturer's own
Leather covered steering wheel with tilt adjustment
Tachometer
Passenger vanity mirror
Ventilation system
http://www.motortrend.com/cars/2008/isuzu/i_370/specifications/index.html#ixzz0lNjkyu73
Unleaded fuel 87
Four-wheel ABS
3.730:1 axle ratio
Immobilizer
Body side molding
Front fog lights
Metallic paint
Fixed rear window
Rear platform step
Air conditioning
Fixed mast antenna
Cargo area light
Clock
Cruise control
Door ajar warning
Floor mats
Power steering
Rear view mirror
Seating: five seats
Tachometer
Ventilation system
