danilko
TecDoc Catalog 4Q.2013 Multilanguage (5xDVD) | 37,7 GB
The TecDoc Catalog 4Q.2013 is a flexible information systems, which allows you several personal settings to ease your daily work. TecDoc supplies the free vehicle spare parts market with current and comprehensive data for identifying and ordering parts – for both, PC as well as CV – directly from the databases of the cooperating automotive aftermarket manufacturers in a standardised catalogue form. You are only a few clicks away from the right part! Accurate identification of the right spare part! Quick customer service thanks to reliable part identification!
TecDoc Catalog is an electronic parts catalogues from standardised data records original data of parts manufacturers on DVD
* more than 2,892,000 articles
* over 1,500,000 illustrations
* more than 45,000 PC types
* 36,000 real existing CV types
* with technical additional information
* updated every 3 months
* multilanguage: 23 languages
The Information System TecDoc is the information source for the vehicle repair market with the original data of the parts manufacturers. Founded in 1994 by companies of the automotive aftermarket industry and the German Association for Spare parts (GVA), TecDoc Informations System GmbH has established itself as the leading supplier of electronic spare parts information on the European market.
Data search can be filtered by the following criteria (from the TecDoc manual):
1. General:
- Engine Code: the engine code
- Engine Type: then engine type
2. by Model Year (from/to):
- the engine was/is constructed during this period
- Engine Number: the engine number as defined by TecDoc
3. by Technical Data:
- Output in kW: engine output in kW
- Output in HP: engine output in HP
- Capacity (technical): engine capacity in technical terms
- Cylinder: number of cylinders
- Valves: number of valves
- Torque in Nm: the maximum torque
- Compression: the engine compression
- Bore: engine cylinder bore
- Stroke: piston stroke of the engine
- Main Bearings: the number of crankshaft main bearings
- Engine Block Design: the engine block design, i.e. straight or V
- Fuel Type: the required fuel type
- Charging: the type of charging, i.e. turbo- or supercharger
- Cylinder Head Design: the cylinder head design, i.e. OHC or OHV
- Engine Control: the type of engine control, i.e. timing belt or chain
- Valve Control: the type of valve control
- Cooling Type: the type of engine cooling, i.e. water or air
Program Name: TecDoc 4Q.2013
Program Type: Electronic Catalog
Release: 2013
Version: 4Q2013
Developer: Parts Info LLC
Homepage: http://www.tecdoc.net
Interface Language: Multilingual
Platform/OS: Windows 2000/XP/vista/win7
Crack/SN: Present (TXT-Manual & Patches 2013)
File Format: iSO (5xDVD)
File Size: 37,7 GB
Install notes: The treatment procedure steps described in TXT-files in the archives with a Patches! When installing on Win 7 (only if the program does not start!) In the properties of a shortcut on the desktop - to set the "compatibility with XP.SP3"
Add. Info: In the archive "0_TecDoc.2013_All.Cracks.rar": Crack (the programm working up to 2015Y) + Patch for Enable/UnLock Technical Data.
Links:
http://extabit.com/file/28cakstpyy05j/TecDoc.4Q2013_All.DL.LINKs.txt
~or~
http://www.filefactory.com/file/181aiai64x61/TecDoc.4Q2013_All.Direct.LINKs.txt
