Tất cả từ viết tắt liên quan đến ôtô
V
Vin
Bình luận: 1Lượt xem: 6,967
Vin
A/C Air Conditioning
A/D ANALOG/DIGITAL
A/T Automatic Transmission/Transaxle
AAP Auxiliary Accelerator Pump
AAV MAL. INTERNAL ECU ERROR
AB Air Bleed
ABCV Air Bleed control valve
ABD GERMAN LANGUAGE OF THE ABS
ABDC After Bottom Dead Center
ABRS Air Bag Restraint System
ABS Anti-Lock brake System
ABS SRI ANTI BRAEKE SYSTEM SERVICE REMINDER INDICATOR
AC Alternating Current
ACC A/C Clutch Compressor
ACCS A/C Cycling Switch
ACCUM Accumulator
ACCY Accessory
ACT Air Charge Temperature Sensor
ACV Thermactor Air control Valve
ADD ADDITION
ADJ Adjust or Adjustale
ADU AIR BAG DIAGNOSTIC UNIT
ADV Advance
AFS Air flow Sensor
AGR ERROR INTERNAL ECU ERROR
AI air injection
AIR or A.I.R air injection reactor
AIS air injection system
ALCL assembly line communications link
ALDL assembly line diagnostic link
ALT. alternator or altitude
AMP. ampere
ARC automatic ride control
ASCD automatic speed control device
ASCS air suction control solenoid
ASD auto shutdown
ASDM air bag system diagnostic module
ASR GERMAN LANGUAGE OF THE TCS(TRACTION CONTROL SYSTEM)
ASSY. assembly
ASV air suction valve
ATC automatic temperature control
ATDC after top dead center
ATF automatic transmission fluid
ATS air temperature sensor
AUTO. automatic
AUX. auxilliary
AVG. average
AXOD automatic transaxle overdrive
B/P backpressure
BAC by-pass air control
BAP barometric absolute pressure sensor
Baro. barometric
Batt. battery
BBDC before bottom dead center
Bbl barrel(Example: 4-Bbi.)
BCM body control module
BDC bottom dead center
BHP brake horsepower
BLK black
blst. ballast
BLU blue
blwr. blower
BMAP barometric & manifold absolute pressure sensor
BOO brake on-off switch
BP barometric pressure sensor
BPS barometric pressure sensor
BPT BELT PRETENSIONOR
BRN brown
BTDC before top dead center
BTRA NAME OF ECU MAKER
BTU british thermal unit
BVSV bimetallic vacuum swiching valve
BYUN NOT NECESSARY
C celsius(degrees)
C(3) I computer controlled coil ignition
C(4) Computer controlled catalytic converter
C/S CHECK/SUM
Calif. cclifornia
CAN CONTROLLERAREA NETWORK
CANP canister purge solenoid
CARB california air resour ces board
Carb. carburetor
CAS CRANKSHAFT ANGLE SENSOR
CAT catalytic converter
CB circuit breaker
CBD closed bowl distributor
CBVV carburetor bowl vent valve
cc cubic centimeter
CCC computer command control
CCD computer controlled dwell
CCM central control module
CCO converter clutch override
CCOT cycling clutch orifice tube
CCW counterclockwise
CDI capacitor discharge ignition
CEC computerized engine control
CESERVO GESERVO(DIESEL FUEL CONTRON SYSTEM)
CFI central fuel injection
Chrg. charging
CID cubic inch displacement
CID cylinder ldentification sensor
Circ. circuit
CIS continuous injection system
CIS-E continuous injection system-electronic
CKT circuit
CLR clear
CNG compressed natural gas
Cntrl. control
CO carbon monoxide
CO2 carbon dioxide
Comp. compressor or compartment
Conn. connector
Cont. continued
Conv. convertible or converter
CP canister purge
CPA connector position assurance
CPS crank position sensor
REGNTR REGENERATOR
CSD AIRBAG ECU INTERNAL MEMORY
CTS coolant temperature sensor
Cu. In. cubic inch
CV check valve or constant velocity
CVC constant vacuum control
CVT CONTINUOUSLY VARIABLE TRANSMISSION
CW clockwise
CYL or Cyl. cylinder
Cyl. cylinder
D drive
DBC dual bed catalyst
DC direct current or discharge
DCCSV DAMPER CLUTCH CONTROL SOLENOID VALVE
DDD dual diaphragm distrivutor
DDS DIESEL DIAGNOSTIC SYSTEM
Def. defogger or defroster
Def. defrost
Defog. defogger
DERM diagnostic energy reserve module
DFI digital fuel injection
DI/EI/DIS NOT NECESSARY
Diag. diagnostic
DIC driver information center
DIS direct ignition system
Dist. distributor or distribution
DISTR distributor
DK BLU dark blue
DK GRN dark green
DME digital motor electronics(motronic system)
DOHC double overhead cam
DOT department of transportation
DP dashpot
Dr. door
DRB-II diagnostic readout box
DTP DIFFERENTIAL FUEL TANK PRESSURE
DVOM digital volt/ohm meter(see VOM)
EAC electric assist choke
EACV electric air control valve
EBCM electronic brake control module
ECA electronic control assembly
ECAT LECTRONIC CONTROL AUTO TRANSMISSION
ECM electronic control module
ECS LECTRONIC CONTROL SUSPENSION
ECT engine coolant temperature sensor
ECU electronic control unit or engine control unit
EDF electric drive fan relay assembly
EDIS electronic distributorless ignition system
EEC electronic engine control
EECS evaporative emission control system
EEPROM electronically erasable PROM
EFE early fuel evaporation
EFI electronic fuel injection
EGO exhaust gas oxygen sensor(see HEGO)
EGR exhaust gas recirculation system
EGRC EGR control solenoid or system
EGRV EGR vent solenoid or system
EGU4 NOT NECESSARY
ELC ELECTRONIC LOCK-UP CONTROL
ELC ELECTRONIC LINK CONNECTOR
Elect. Electronic
ELECTRONICAL DASHPOT ECM CONTROLS THIS FUNCTION IN ORDER TO REDUCE THE SHOCK AT IDLING BY MEANS OF INTRODUCING ADDITIONAL AIT QUANTITY.
EM EMISSION
EMR emission maintenance reminder module
Eng. Engine
ENGINE 3.0/3.5 ETS ELECTRONID TROTTLE SYSTEM
ENGINE REV(F) FINE
EPR EXHAUST PRESSURE REGULATOR
ESA electronic spark advance
ESC electronic spark control
EST Electronic spark timing
EST ERROR EST IS IGNITION CIRCUIT
ETACS ELECTROIC TIME & ALARM CONTROL SYSTEM
ETR Emergency tensioning retractor
ETS ELECTROIC THROTTLE CONTROL SYSTEM
EVAP Fuel evaporative system
EVIC Electronic vehicle information center
EVO Electronic variable orifice
EVP EGR valve position sensor
EVR EGR valve regulator
EVRV Electronic vacuum regulator valve
Exc. Except
F Fahrenheit(degrees)
F/B Fuse block
F/P OPERATING STATE FUEL PUMP
FBC Feedback carburetor
FCV FUEL CUT VALVE
FCVC FUEL CUT VALVE CONTROLLER
Fed. Federal
FI Fuel injector or fuel injection
FICD Fast idle control device
FIPL Fuel injector pump lever
FP Fuel pump
FPM Fuel pump monitor
FPR-VSV Fuel pressure regulator vacuum switching valve
FR FRONT REAR
FRA GERMAN LANUAGE OF THE FUEL INJECTION ADAPTATION VALUE AT PART LOAD STATUS
FRP FUEL RAIL POSITION
Ft. Lbs. Foot pounds
FTS FUEL TEMPERATURE SENSOR
FULL LOAD INHIBIT INHIBITION
FVTS FUEL VAPOR TEMPERATURE SENSOR
FWD Front wheel drive
G grams
Ga. Gauge
Gals. Gallons
GE GE(FUEL CONTROL ACTUATOR )
GND of GRND Ground
Gov. Governor
G-P/U ACCELOEROMETER
GRN Green
GRY Gray
GS1
G-SENSOR GRAVITY
H/D Heavy duty
HAC High altitude compensation
HC Hydrocarbons
HCU HYDRAULIC CONTROL UNIT
Headlt. Headlight
HEDF High speed electro drive fan relay or circuit
HEGO Heated exhaust gas oxygen sensor
HEGOG HEGO ground circuit
HEI High energy ignition
Hg Mercury
Hgt. Height
HIVEC HYUNDAI INTELLIGENCE VEHICLE SYSTEM
HLDT Headlight
HO High output
HP High performance
HSC High swirl combustion
HSO High specific output
HTR Heater
Htr. Heater
HVAC Heating
Hz Hetz(Cycles per second)
I.D. Inside diameter
I/C INTER COOLER
IAC Idle air control
IACV Idle air control valve
IC Integrated circuit
ID Identification
E/L ELECTRONIC LOAD
ATX AUTO TRANSAXLE
IDM Ignition diagnostic monitor
IGN Ignition system or circuit
ILC Idle load compensator
In. Inches
In. Hg Inches of mercury
INCH Lbs. Inch pounds
INFL REST Inflatable restraint
INJ Injection or Injector
IP Instrument panel
IP0 ADU INTERNAL PART
IPC Instrument panel cluster
ISA Idle speed actuator
ISC Idle speed control
ISS Idle stop solenoid
ISU NTELLIGENT SWICHING UNIT
IT SERVO IT SERVO(DIESEL INJECTION TIMING SYSTEM)
ITS Idle tracking switch
ITT TYPE NAME OF ABS ECU MAKER
IVSV Idle vacuum switching valve
J/B Junction block
k/ohms 1000 ohms(kilo as in k/ohms)
KAM Keep alive memory
KAPWR Keep alive power
KAT ERROR INTERNAL ECU ERROR
kg Kilograms(weight)
kg/cm2 Kilograms per square centimeter
KM/H Kilometers per hour
KOEO Key on engine off
KOER Key on engine running
KS Knock sensor
L Liter(S)
L/B CONDITION LEAN BURN
L/D Light duty
LAN OCAL AREA NETWORK
Lbs. Pounds
LCD Liquid crystal display
LED Light emitting diode
LH Left hand
LOS Limited operation strategy
LPG LIQUIFIED PETROLEUM GAS
LSAB MODULE SHORT LEFT SIDE AIRBAG
LT BLU Light blue
LT GRN Light green
Lt(s). Light(S)
Lugg. Luggage
LUS Lock-up solenoid
M.EGR V/V FAULT EXHAUST GAS RECIRCULATION
M/T Manual transaxle or transmission
mA Milliamps
MA or MAF Mass airflow
MA PFI Mass air sequential port fuel injection system
MAF Mass air flow sensor
MAFS Mass airflow sneosor
Man. Manual
MAP manifold absolute pressure sensor
MAT manifold air temperature
MCU Microproceesor control unit
MCV Mixture control valve
Mech. Mechanical
Mem. Memory
MEM-CAL Memory calibration chip
MES MEMORY ERASE SIGNAL(2PIN CONNECTOR) - HONDA AIR BAG
mfd. Microfarads
MFI MULTI-PORT FUEL INJECTION
MIL Malfunction indicator light
MLP Manual lever position
mm Millimeters
MPFI Multi point fuel injection
MPH Miles per hour
MPI Multi-point(Fuel) injection
Mtr. Motor
MUL MULTIPLICATION
mV Millivolts
N.m Newton-meter
NA Not available
NAG AME OF ECU MAKER
NC VALVE NORMAL CLOSED VALVE(OUTLET VALVE)
NDS Neutral drive switch
NGS Neutral gear switch
No. Number
Nos. Numbers
Nox Oxides of nitrogen
NP NOT NECESSARY(PUMP SPEED UNIT)
NPS Neutral pressure switch
NUT NOT NECESSARY
O Oxygen
O.D. Outside diameter
O/S Oversize
O2 Oxygen
OC Oxidation catalyst
OCC Output circuit check
OD Overdrive
ODO Odometer
ODSV OVERDRIVE SOLENOID VALVE
OHC Overhead camshaft
Opt. Option or optional
ORG Orange
OSC Output state check
OUTPUT SPEED SNR CIRT INMT FAULT INTERMITTENCE
oz. Ounce
P Park
P/BPT PASSENGER BELT PRETENSIONER
P/C Printed circuit
P/N Park/Neutral
P/S Power steering
P/SIDE ACC SENSOR WIRE BAD ACCELERATION
PASSENGER SDM SIG SENSING AND DIAGNOSTIC MODULE(AIRBAG CONTROL UNIT)
PAV Pulse air valve
PCM Power train control module
PCS Purge control solenoid
PCSDM Passenger compartment sensor/Diagnostic module
PC-SOL Purge control solenoid
PCSV PRESSUR CONTROL SLENOID VALVE
PCV Positive crankcase ventilation
PCV PRESSUER CONTROL VALVE
PFE Pressure feedback EGR sensor or circuit
PFI port fuel injection(see MA SEFI)
PGM-CARB Programmed carburetor
PGM-FI Programmed fuel injection
PIP Profile ignition pickup
Pkg. Package
PNK Pink
PPD PASSENGER PRESENCE DETECTION
PPL Purple
PPS PEDAL POSITION SENSOR
Press. Pressure feedback EGR sensor or circuit
PRNDL Park reverse Neutral drive low
Prog. Programmed or programmable
PROM Programmable read-only memory
PSH ADU INTERNAL PART
psi Pounds per square inch
PSL ADU INTERNAL PART
PSPS Power steering pressure switch
PTC Positive temperature codfficient
PTO Power take-off
Pts. pints
PWR GND Power ground circuit
PWR TR CONNECTOR BAD POWER TRANS
Pwr. Power
Q ADJUSTMENT A KIND OF RESISTOR/ECM RECEIVES THIS SIGNAL FROM ADJUSTING RESISTOR AND CONTROL THE AMOUNT OF INJECTION QUANTITY TO CORRECT FUEL INJECTION DEVIATION
Qts. Quarts
R/F VDC VALVE VEHICLE DYNAMIC CONTROL SYSTEM
RABS Rear anti-lock brake system
RAC Remote accessory control
RAM Random access memory
RAP Retained accessory power
REAR WHL SPD SNSR SIG FAST CHG REAR WHEEL SPEED SENSOR SIGNAL FAST CHANGE
Recirc. Recirculate or recirculation
RED Red
REDSV RED SOLENOID VALVE
Reg. Regulator
RH Right hand
Rly. Relay
ROM Read only memory
RPM Revolutions per minute
R-S A/B MODULE OPEN RIGHT SIDE
RSAB MODULE SHORT RIGHT SIDE AIRBAG
RVB Rear vacuum break
RWAL Rear wheel anti-lock brake
RWD Rear wheel drive
SAB SIDE AIRBAG
SAFING SENSOR SAFING SENSOR PREVENTS AIRBAG EXPLOSION UNITENTIONALLY BY OUTSIDE EFFECT SUCH AS EMC INTERFACE.
SAS SPEED ADJUST SCREW
SAT SEMI AUTO TRANSMISSION
SAW Spark angle word
SBC Single bed converter
SBE FUNCTION ERR SBE => AIRBAG ECU INTERNAL MEMORY
SBEC Single board engine controlller
SC Super charged
SCC Spark control computer
SCS SYSTEM CONTROL SOKET(2PIN CONNECTOR) - HONDA AIR BAG
SCSV SHIFT CCONTROL SOLENOID VALVE
SDM Supplemental restraint system diagnostic module
SDU SRS diagnostic unit
Sen. Or Sens. Sensor
SES Service engine soon
SFI Sequential(port) fuel injection
SIG RTN signal return circuit
SIL Shift indicator light
SIR Supplemental inflatable restraint
SIS F.(LEFT),CORRUPTED MSG/SHROT INTERNAL ECU ERROR
SLS ERROR INTERNAL ECU ERROR
SMEC Single module engine controller
SOHC Single overhead cam
SOL or Sol. solenoid
Sol. solenoid
SPFI Sequential port fuel injection
SPK Spark control
SPOUT Spark output signal
Sprchg. Supercharged
SRS Supplemental restraint sytem(air bag)
SRSCM-SRI SUPPLEMETAL RESTRAIN SYSTEM CONTROL MODLE-SERVICE REMINDER INDICATOR
SS SAFING SENSOR
SS 3/4-4/3 Shift solenoid circuit
SSI Solid state ignition
STAR Self-test automatic readout
STI Self test input circuit
STO Self-test output
Strg. Steering
SUB-02 Sub oxygen sensor
Susp. Suspension
Sw. Switch
Sys. System
T.V. Throttle valve
TAB Thermactor air by-pass
TAC Termostatic air cleaner
TAC THROTTLE ACTUATOR CONTROL
TAD Thermactor air diver ter
TAN Tan
TARGET INJETCION VOL VOLTAGE
TB TURBO/SUPER CHARGER BOOST
TBD ENGINE NAME(1,800CC ENGINE)
TBI Throttle body injection
TC TORQUE CONVERTER
TCC Torque converter clutch
TCCM TRANSMISION CASE CONTROL MODUL
TCCS Toyota computer control system
TCCU TRANSMISION CASE CONTROL UNIT
TCL TRACTION CONTROL LAMP
TCM TRANSMISION CONTROL MODUL
TCS TRACTION CONTROL SYSTEM
TCV TIMER CONTROL VALVE(DISEL INJECTION TIMING CONTROL VALVE)
TDC Top dead center
TDCL Total diagnostic communication link
Temp. Temperature
TEV MAL. INTERNAL ECU ERROR
TFI Thick film ignition system
TGS Top gear switch(cancels SIL in top gear)
THERMAC Thermostatic air cleaner
THS Transmission hydraulic switch
TOD TORQUE ON DEMAND
TORQ CVTR CLUTCH CRCT-OFF FIXED TORQUE CONVERTOR
TP/TPS Throttle position sensor
TPI Tuned port injection
TPS Throttle position sensor/switch
TRA GERMAN LANUAGE OF THE FUEL INJECTION ADAPTATION VALUE AT IDLE STATUS
Trans. Transaxle/transmission
TRANS.CON.SPARK ADV. TRANSAXLE CONTORL SPARK ADVANCE
TS Temperature sensor
TSB Technical service bulletin
TTS Transmission temperature switch
TV Thermovalve
TWC Three-way catalyst
UDSV UNDERDRIVE SOLENOID VALVE
V Valve
Vac. Vacuum
VAF Vane air flow sensor or circuit
VAPS Variable assist power steering
VAT Vane air temperature
VATS Vehicle anti-theft system
VBATT Vehicle battery voltage
VCC Viscous converter clutch
VDC EHICLE DYNAMIC CONTROL SYSTEM
VGT ARIABLE GEOME-TRY TURBO CHARGER
VICS VARIABLE INERTIA CONTROL SYSTEM
VIN Vehicle identification number
VIO Violet
VLR Volt loop reserve
VM Vacuum modulator
VM Vane meter
Volt. Voltage
VOM Volt-ohmmeter(analog)
VPWR Vehicle power supply voltage(10-14volts)
VREF Voltage reference(ECA supplied reference voltage)
VRV Vacuum regulator valve
VSC Vheicle speed control sensor or signal
VSS Vehicle speed sensor or signal
VSV Vacuum switching valve
W,E,P MODE SW FAULT WINTER, ECONOMY, POWER
W/ With
W/GATE WASTE GATE
W/O Without
WAC WOT A/C cut-off switch or circuit
WAC Wide open throttle A/C switch
WHT White
WOT Wide open throttle
YEL Yellow
