Tài Liệu - Video Hướng Dẫn Sử Dụng Dynamic Designer Motion
Bình luận: 5Lượt xem: 2,681
BKMetalx
Bộ bài giảng, file thực hành, ví dụ hướng dẫn sử dụng bộ công cụ Dynamic Design Motion
Dynamic Designer Motion is a subset of Motion Professional. Motion is designed for designers and engineers who want to verify the performance aspects of mechanisms including those containing cams, gears, latches, belts, and/or chains. You will verify mechanism motion through animations, interference detection, and XY plots of basic engineering data. If you are interested in modeling a wide range of forces (e.g. friction, dampers, etc.) or plotting force-related engineering data (e.g. reaction loads, power consumption, etc.), you should consider Motion Professional.
Link:
http://www.mediafire.com/?uxd4prpzti1ff8f
