Superchargers
L
Bình luận: 0Lượt xem: 1,207
localhost
Link download
[HIDE]http://www.mediafire.com/?nmm3ajmmzyz[/HIDE]
Common Terms ............................................................................................... 2
Charge-Air-Cooler ..................................................................................................................................................2
Boost ......................................................................................................................................................................2
Blow Through System............................................................................................................................................2
Draw Through System ...........................................................................................................................................2
Centrifugal..............................................................................................................................................................2
Positive Displacement............................................................................................................................................2
Water Injection .......................................................................................................................................................2
Under / Overdriven.................................................................................................................................................2
Adiabatic Efficiency................................................................................................................................................2
Volumetric Efficiency..............................................................................................................................................3
Mechanical Efficiency.............................................................................................................................................3
Density Ratio..........................................................................................................................................................3
Pressure Ratio .......................................................................................................................................................3
Common Types of Superchargers....................................................................... 4
Roots (The Popular GMC) .....................................................................................................................................4
Centrifugal..............................................................................................................................................................4
Screw .....................................................................................................................................................................4
Vane.......................................................................................................................................................................5
Axial Flow...............................................................................................................................................................5
Wankel Rotary........................................................................................................................................................6
Other Types Of Compressors ................................................................................................................................6
Camshafts for Positive Displacement Superchargers ........................................... 7
Supercharger's Compared to Nitrous .....................................................................................................................7
Cylinder Heads.......................................................................................................................................................7
Intake Valve Timing................................................................................................................................................7
Exhaust Valve Timing ............................................................................................................................................7
Valve Overlap.........................................................................................................................................................7
Summing It Up .......................................................................................................................................................7
Camshafts For Centrifugal Blowers.................................................................... 9
Positive Displacement Vs. Centrifugal Compressors .............................................................................................9
Choosing a Camshaft.............................................................................................................................................9
Summing It Up. ......................................................................................................................................................9
Modifying Holley Carburetors for Draw Through Blowers ..................................... 10
Before You Start...................................................................................................................................................10
Accelerator Pumps...............................................................................................................................................10
Idle Feed Restrictions ..........................................................................................................................................10
Power Valves .......................................................................................................................................................10
Primary Main Jetting ............................................................................................................................................10
Secondary Main Jetting .......................................................................................................................................10
Power Valve Channel Restrictions.......................................................................................................................11
Vacuum Secondary Tuning..................................................................................................................................11
Modifying AFB Carburetors for Draw Through Blowers........................................ 12
Before You Start...................................................................................................................................................12
Accelerator Pumps...............................................................................................................................................12
Idle Fuel Jets........................................................................................................................................................12
Metering Rods......................................................................................................................................................12
Main Jetting..........................................................................................................................................................12
Secondary Air Doors .............................................................
