SolidCAM v.2010 SP0.0 English (2010)
SolidCAM - CAD / CAM system developed by a new generation of Israeli firm SolidCAM Ltd. This system is a complete solution for automating the production of metal. Using a wide range of proposed strategies SolidCAM turning, milling, turning and milling and spark erosion machining process engineer can in a short time to prepare the necessary set of CNC machining products.
Functionality SolidCAM 2010
Support for 64bit computing due to the availability of a special version for SW 64bit
2.5-axis milling
SolidCAM provides high efficiency and accuracy of the 2,5-axis machining of parts. Supports different strategies for handling items such as contour, sampling (including islands) and a slot, as well as various types of processing holes: drilling, reaming, threading, etc. The system has a wide range of features 2,5-axis machining of analytic surfaces.
3-axis milling
SolidCAM provides a wide range of tools that can be effectively used for treatment of products with complex geometry (dies, molds) and prismatic parts. As the geometry for 3-axis machining using three-dimensional surface or solid model. The system supports various types of strategies for roughing and finishing, such as raster processing with the specified or automatically determined by the angle of the raster processing of equidistant, projection processing, handling at the waterline, etc.
In addition to the listed options 2,5 - and 3-axis machining, SolidCAM provides tools to identify and refine areas not treated in previous transitions. You can create a database of standard processes. Once created, a parameterized process can be reused in the future, which significantly reduces the pre-production, improves the reliability of the developed programs, unifies the style of technological development, guarantees the use of only the optimal processing technology and ensures the independence of the production of human factors. No zarezany guaranteed availability of funds control and visualization of machining.
Multiaxial Processing
SolidCAM provides various means of creating the control programs of the multi-processing of 4 - and 5-axis machining centers. The model is set in a user-plane processing, after which the system automatically calculates all necessary parameters of displacement and rotation for zero details. As a result, significantly reduces set-closing time of transition and increases accuracy.
Turning and turning and milling
SolidCAM has lots of features to automate the creation of control programs for turning and turning and milling. SolidCAM supports various types of tool that allows you to efficiently produce a longitudinal turning, facing, grooving processing, etc. In addition, SolidCAM automatically perform rough and finish machining of complex contours. Support rotating tool allows you to perform milling and drilling transitions on machining centers.
Spark Processing
The proposed set of strategies SolidCAM Wire spark processing allows processing of external and internal contours of constant and variable slopes. The possibility of 4-axis machining. A special algorithm to prevent the fall of the treated material. SolidCAM provides user controls physical processing parameters on the entire trajectory of the wire.
For more information on opportunities SolidCAM 2010 can be found in Whats_New_in_SolidCAM2010.pdf or website developer.
System requirements:
preset SolidWorks 2007-2010 32bit & 64bit
Year: 2010
Version: 2010 SP0 English
Developer: SolidCAM Ltd
Platform: Windows
Compatibility with Vista: complete
Language: English only
Medicine: Present (by SSQ)
DOWNLOAD
http://hotfile.com/dl/40623937/ccfbdfb/SolidCAM_2010_SP0_Eng.part01.rar.html
http://hotfile.com/dl/40623999/7643e39/SolidCAM_2010_SP0_Eng.part02.rar.html
http://hotfile.com/dl/40624071/3f31b84/SolidCAM_2010_SP0_Eng.part03.rar.html
http://hotfile.com/dl/40624234/4a8a445/SolidCAM_2010_SP0_Eng.part04.rar.html
http://hotfile.com/dl/40624310/58f08b6/SolidCAM_2010_SP0_Eng.part05.rar.html
http://hotfile.com/dl/40624377/c8a8324/SolidCAM_2010_SP0_Eng.part06.rar.html
http://hotfile.com/dl/40624445/1df667c/SolidCAM_2010_SP0_Eng.part07.rar.html
http://hotfile.com/dl/40624503/a93747b/SolidCAM_2010_SP0_Eng.part08.rar.html
http://hotfile.com/dl/40624571/615f573/SolidCAM_2010_SP0_Eng.part09.rar.html
http://hotfile.com/dl/40624632/441e3f9/SolidCAM_2010_SP0_Eng.part10.rar.html
http://hotfile.com/dl/40624688/0cb69da/SolidCAM_2010_SP0_Eng.part11.rar.html
http://hotfile.com/dl/40624716/7c0377d/SolidCAM_2010_SP0_Eng.part12.rar.html
