Service manual của một số dòng xe nâng của hãng TCM Nhật Bản
N
Bình luận: 5Lượt xem: 6,900
nhienbbs
Đây là tài liệu sửa chữa một số dòng xe nâng của hãng TCM Nhật Bản:
No. SEF-0F7BE
FORKLIFT TRUCK
TCM CORPORATION
FHG15T3
FHG18T3
FG20T3
FHG20T3
FG25T3
FHG25T3
FG30T3
FHG30T3
FG35T3S
FHD15T3
FHD18T3
FD20T3
FHD20T3A
FD25T3
FHD25T3A
FD30T3
FHD30T3A
FD35T3S
SERVICE MANUAL
SERVICE MANUAL FG20T3 – FG30T3, FHG15T3 – FHG30T3, FG35T3S
FD20T3 – FD30T3, FHD15T3, FHD20T3A – FHD30T3A, FD35T3S No. SEF-0F7BE
- 1 -
1. ENGINE
1. ENGINE
Gasoline and LPG engine
Truck Model
Item
Name K21 K25
Type 4-cycle, water-cooled, in-line, overhead valve type gasoline engine
No. of cylinders – Bore x stroke 4 – 89 x 83.0 4 – 89 x 100
mm [in.] 4 – [3.50 x 3.27] 4 – [3.50 x 3.94]
Total displacement cc [in.3] 2065 [126] 2488 [151.8]
Compression ratio
GAS: 8.7
LPG (Exclusive): 9.3 9.2
Dual fuel: 8.7
Performance
Rated speed rpm 2700
Rated output kW {PS} [HP]
GAS (Exclusive and Dual): 38.7 {52.6} [51.9] 44.7 {60.8} [59.9]
LPG (Exclusive): 40.0 {54.3} [53.7] 44.6 {60.7} [59.8]
LPG (Dual): 39.8 {54.1} [53.4] 44.4 {60.4} [59.4]
Max. torque
N-m {kgf-m} [lbs-ft]/rpm
GAS (Exclusive and Dual): 148 {15.1} [109.2]/2000 174 {17.7} [128.4]/1600
LPG (Exclusive): 151 {15.4} [111.4]/2000 185 {18.4} [136.5]/1600
LPG (Dual): 150 {15.3} [110.6]/2000 183 {18.7} [135.0]/1600
Full-load rated fuel consumption
g/kW-h {g/PS-h}/rpm
GAS (Exclusive and Dual): 303 {223}/1600 302 {222}/1600
LPG (Exclusive): 230 {169}/2000 215 {158}/1600
LPG (Dual): 235 {173}/2000 223 {164}/1600
No-load minimum speed rpm 700 rpm (off the truck)
Weight kg [lbs]
GAS: 151 [333] 152 [335]
LPG (Exclusive): 151 [333] 152 [335]
Dual fuel: 152 [335] 153 [337]
Dimensions mm [in.] 719.4 x 568 x 726 [28.3 x 22.4 x 28.6]
Ignition order 1-3-4-2
Rotational direction Clockwise when viewed from the fan
5. STEERING SYSTEM
- 80 -
The returning oil from the power cylinder flows, passing through the cylinder port R, groove in the
valve housing, oil hole in the sleeve, groove in the spool, oil hole in the sleeve, and groove in
the valve housing, back to the oil tank.
(c) When steering wheel is turned clockwise
As the steering wheel is turned clockwise, the
grooves in the spool shift to the right in relation to the
oil holes and grooves in the sleeve so that oil holes
in the spool get out of line with holes in the sleeve.
The oil that has flowed into groove thus far begins
to flow into oil hole in the sleeve and then flows
through grooves and in the spool, oil hole in
the sleeve, and oil passage in the valve housing to
the hydraulic motor. The hydraulic motor thus rotates in
the clockwise direction and the oil discharged from the
hydraulic motor flows through oil hole in the sleeve,
groove in the spool, and oil hole in the sleeve to
the cylinder port R in the housing and thus actuates the
power cylinder.
passing through the cylinder port L, groove in the
oil hole in the sleeve and groove in the housing
(2) Relationship between the rotating speed and operating force of the steering wheel
The force required to operate the orbitrol is basically a valve operating force (the force required to
compress the centering spring: 2.9 N-m {0.3 kgf-m} [2.14 lbf-ft]). That is, there is no mechanical linkage
between the steering wheel and the tires, and thus the operating force of the steering wheel remains
constant regardless of the rotating speed of the steering wheel. The discharge of oil from the orbitrol
rotor to the steering cylinder is 96 cc/revolution.
(3) Neutral feedback of orbitrol
The neutral feedback function of the orbitrol is performed by the valve switching over the oil passages
according to the reaction force of the centering spring. (If the steering wheel is turned and then released
with the engine turned off, it will automatically return to the straight-ahead position.) Should the neutral
feedback not function properly, the steering wheel might turn by itself when the operator does not turn it.
Tile: Service manual của một số dòng xe nâng của hãng TCM Nhật Bản
Language: English
Format: PDF
