linhautonet
Chương trình này rất thuận tiện và dễ sử dụng.Cho phép bạn để xác định năm và tháng sản xuất của xe
Toyota EPC 2010
dung lượng khoảng 5Gb
1. Chạy SETUP.EXE từ đĩa gốc TOYOTA INSTALL EPC3
nguyên văn đoạn hướng dẫn bằng tiếng anh
Instruction without images
1. Run SETUP.EXE from the root disk TOYOTA INSTALL EPC3
2. Click NEXT
3. Click on any hard drive you awake to install a shell and the data and click NEXT
4. Click NEXT
5. Click NEXT
6. Click NEXT
7. Click FINISH
8. Click Start - Programs - TOYOTA EPC SYSTEM - TOYOTA EPC SYSTEM
9. From the main menu, select Setup Menu
10. Select Data Configurator
11. Select desired region (eg Europe) and in front of each disc (A1, A2, B1, etc.) indicate the type of installation (copy to HDD or to work with the CD), the data source and the letter of HDD, which you must copy the data. </span>In the Sales Area Code to insert the code - 99999. Press F10. This operation is needed for each region separately.
12. Click OK
1913. Press F2
14. From the main menu, select Data Setup
15. One by one, choose the appropriate region and select all the drives you mentioned in paragraph 11, and then press F10
16. Click OK
17. As the sign up will appear with the requirement to insert one or another disk. Insert the correct drive and click OK.
18. At the end of copying, press OK
19. Press F2
20. From the main menu, select Setup Menu
21. Click Lexus Dealer Check
22. In the Password box, Drive a code written on the disk A1, and press the F8 key
23. If the red circle to the left of the inscription You are now regarded as a Lexus dealer was blue - then everything is in order. Tap the F2 key to return to the main menu - the program now fully ready to work.
[HIDE]http://rapidshare.com/files/386542060/Toyota_EPC.part01.rar
http://rapidshare.com/files/386542082/Toyota_EPC.part02.rar
http://rapidshare.com/files/386542109/Toyota_EPC.part03.rar
http://rapidshare.com/files/386542107/Toyota_EPC.part04.rar
http://rapidshare.com/files/386542189/Toyota_EPC.part05.rar
http://rapidshare.com/files/386542161/Toyota_EPC.part06.rar
http://rapidshare.com/files/386542078/Toyota_EPC.part07.rar
http://rapidshare.com/files/386542179/Toyota_EPC.part08.rar
http://rapidshare.com/files/386542170/Toyota_EPC.part09.rar
http://rapidshare.com/files/386542177/Toyota_EPC.part10.rar
http://rapidshare.com/files/386542627/Toyota_EPC.part11.rar
http://rapidshare.com/files/386542540/Toyota_EPC.part12.rar
http://rapidshare.com/files/386542579/Toyota_EPC.part13.rar
http://rapidshare.com/files/386542760/Toyota_EPC.part14.rar
http://rapidshare.com/files/386542681/Toyota_EPC.part15.rar
http://rapidshare.com/files/386564724/Toyota_EPC.part16.rar
http://rapidshare.com/files/386564666/Toyota_EPC.part17.rar
http://rapidshare.com/files/386564660/Toyota_EPC.part18.rar
http://rapidshare.com/files/386564743/Toyota_EPC.part19.rar
http://rapidshare.com/files/386564708/Toyota_EPC.part20.rar
http://rapidshare.com/files/386564723/Toyota_EPC.part21.rar
http://rapidshare.com/files/386564726/Toyota_EPC.part22.rar
http://rapidshare.com/files/386564710/Toyota_EPC.part23.rar
http://rapidshare.com/files/386564715/Toyota_EPC.part24.rar
http://rapidshare.com/files/386564712/Toyota_EPC.part25.rar
http://rapidshare.com/files/386565045/Toyota_EPC.part26.rar
http://rapidshare.com/files/386565033/Toyota_EPC.part27.rar
http://rapidshare.com/files/386565121/Toyota_EPC.part28.rar
http://rapidshare.com/files/386565058/Toyota_EPC.part29.rar
http://rapidshare.com/files/386565087/Toyota_EPC.part30.rar
http://rapidshare.com/files/386566905/Toyota_EPC.part31.rar
http://rapidshare.com/files/386566765/Toyota_EPC.part32.rar
http://rapidshare.com/files/386566806/Toyota_EPC.part33.rar
http://rapidshare.com/files/386566801/Toyota_EPC.part34.rar
http://rapidshare.com/files/386566751/Toyota_EPC.part35.rar
http://rapidshare.com/files/386566837/Toyota_EPC.part36.rar
http://rapidshare.com/files/386566802/Toyota_EPC.part37.rar
http://rapidshare.com/files/386566884/Toyota_EPC.part38.rar
http://rapidshare.com/files/386566732/Toyota_EPC.part39.rar
http://rapidshare.com/files/386566790/Toyota_EPC.part40.rar
http://rapidshare.com/files/386567313/Toyota_EPC.part41.rar
http://rapidshare.com/files/386567478/Toyota_EPC.part42.rar
http://rapidshare.com/files/386567342/Toyota_EPC.part43.rar
http://rapidshare.com/files/386567373/Toyota_EPC.part44.rar
http://rapidshare.com/files/386567356/Toyota_EPC.part45.rar
http://rapidshare.com/files/386567350/Toyota_EPC.part46.rar
http://rapidshare.com/files/386567384/Toyota_EPC.part47.rar
http://rapidshare.com/files/386567429/Toyota_EPC.part48.rar
http://rapidshare.com/files/386567400/Toyota_EPC.part49.rar
http://rapidshare.com/files/386567435/Toyota_EPC.part50.rar
http://rapidshare.com/files/386567727/Toyota_EPC.part51.rar[/HIDE]
Toyota EPC 2010
XP, VISTA
XP, VISTA dung lượng khoảng 5Gb
2.
Click NEXT 3.
Nhắp chuột vào bất kỳ ổ cứng nào mà bạn muốn chứa dử liệu sau đó click NEXT 4.
Click NEXT 5.
Click NEXT 6.
Click NEXT 7.
Click FINISH 8.
Click vào Start - Programs - TOYOTA EPC SYSTEM - TOYOTA EPC SYSTEM 9.
Từ menu chính, chọn Menu Setup10.
Chọn Cấu hình 11.
Chọn khu vực (ví dụ như Châu Á) và ở phía trước của mỗi đĩa (A1, A2, B1, vv) là loại cài đặt (bản sao cho HDD hoặc để làm việc với đĩa CD), nguồn dữ liệu và thư mục của HDD, mà bạn câầnn sao chép dữ liệu. 12.
Click OK 13
Nhấn F2 14.
Từ menu chính, chọn Data Setup 15.
Từng người một,bước 11, và sau đó bấm phím F10 16.
Click OK 17.
Khi đăng ký sẽ xuất hiện với các yêu cầu để chèn một hoặc một đĩa khác.Chèn đúng ổ đĩa và nhấn OK. 18.
Khi kết thúc việc sao chép, bấm OK 19.
Nhấn F2 nguyên văn đoạn hướng dẫn bằng tiếng anh
2. Click NEXT
4. Click NEXT
5. Click NEXT
6. Click NEXT
7. Click FINISH
12. Click OK
1913. Press F2
16. Click OK
19. Press F2
