The Toyota Yaris (sold in different markets as the Toyota Vitz and Toyota Echo) is a line of subcompact cars first launched by Toyota in 1999, designed by Sotiris Kovos. The Yaris is a 3 and 5 door hatchback automobile.
In Europe, the Americas, Australia, New Zealand and South Africa, the Vitz is sold as the Yaris Liftback (or simply Yaris). Up to 2005, the Vitz was known as the Echo Hatchback in Canada, Hong Kong, Australia and New Zealand, with the Toyota Platz sedan being known as the Echo; the first generation Vitz was never sold in the US. Since 2006, the Vitz and Belta are marketed in US/Canada as the Yaris Hatchback and Yaris, respectively. (en.wikipedia.org).
HOW TO USE THIS MANUAL
GENERAL INFORMATION
1. GENERAL DESCRIPTION
(a) This manual is written in accordance with SAE
J2008.
(1) Diagnosis
(2) Removing/Installing, Replacing, Disassembling/
Reassembling, Checking and Adjusting
(3) Final Inspection
(b) The following procedures are omitted from this
manual. However, these procedures must be
performed.
(1) Use a jack or lift to perform operations
(2) Clean all removed parts
(3) Perform a visual check
2. INDEX
(a) An alphabetical INDEX section is provided at the
end of the manual as a reference to help you find
the item to be repaired.
3. PREPARATION
(a) Use of Special Service Tools (SST) and Special
Service Materials (SSM) may be required,
depending on the repair procedure. Be sure to use
SST and SSM when they are required and follow
the working procedure properly. A list of SST and
SSM is in the “Preparation” section of this manual.
4. REPAIR PROCEDURES
(a) A component illustration is placed under the title
where necessary……
Download Now
Owner’s Manual Toyota Yaris 2007.txt 0312 bytes · Xem: 87
