test
SECTION 1. THE AUTOMOBILE INDUSTRY
Chapter 1 Introduction to the Automobile
Chapter 2 Automotive Careers and Technician Certification
SECTION 2. SHOP PROCEDURES, SAFETY, TOOLS, AND EQUIPMENT
Chapter 3 Shop Safety
Chapter 4 Shop Management, Service Records, and Parts
Chapter 5 Locating Service Information and Specifications
Chapter 6 Measuring Tools and Systems
Chapter 7 Hardware, Fasteners, Drills, and Thread Repair
Chapter 8 Shop Tools
Chapter 9 General Shop Equipment
Chapter 10 Cleaning Equipment and Methods
Chapter 11 Lifting Equipment and Air Compressors
SECTION 3. VEHICLE INSPECTION (Lubrication/Safety Check)
Chapter 12 Engine Lubrication
Chapter 13 Underhood and Body Inspection (Car on Ground)
Chapter 14 Undercar Inspection and Service
SECTION 4. ENGINE OPERATION AND SERVICE
Chapter 15 Introduction to the Engine
Chapter 16 Engine Classifications and Advanced Transportation Technologies
Chapter 17 Engine Size and Measurements
Chapter 18 Engine Upper End
Chapter 19 Engine Lower End and Lubrication System Theory
SECTION 5. COOLING SYSTEM, BELTS, HOSES, AND PLUMBING
Chapter 20 Cooling System Theory
Chapter 21 Cooling System Service
Chapter 22 Automotive Belts
Chapter 23 Automotive Hoses
Chapter 24 Automotive Plumbing: Tubing and Pipe
SECTION 6. ELECTRICAL SYSTEM THEORY AND SERVICE
Chapter 25 Basic Electrical System Theory and Repairs
Chapter 26 Battery Fundamentals
Chapter 27 Battery Service
Chapter 28 Starting System Fundamentals
Chapter 29 Starting System Service
Chapter 30 Charging System Fundamentals
Chapter 31 Charging System Service
Chapter 32 Lighting and Wiring Fundamentals
Chapter 33 Lighting and Wiring Service
Chapter 34 Safety, Security, Comfort Systems, and Electrical Accessories
SECTION 7. HEATING AND AIR CONDITIONING
Chapter 35 Heating and Air Conditioning Fundamentals
Chapter 36 Heating and Air Conditioning Service
SECTION 8. ENGINE PERFORMANCE DIAGNOSIS: THEORY AND SERVICE
Chapter 37 Ignition System Fundamentals
Chapter 38 Ignition System Service
Chapter 39 Fuels and Alternative Fuels
Chapter 40 Fuel System Fundamentals
Chapter 41 Fuel System Service
Chapter 42 Intake and Exhaust Systems, Turbochargers and Superchargers
Chapter 43 Emission Control System Fundamentals
Chapter 44 Emission Control System Service
Chapter 45 Electronics and Computer Systems Fundamentals
Chapter 46 Electronics and Computer Systems Service
Chapter 47 Advanced Emissions and On-board Diagnostics (ODB)
Chapter 48 Diagnosing Engine Performance Problems
SECTION 9. AUTOMOTIVE ENGINE SERVICE AND REPAIR
Chapter 49 Diagnosing Engine Mechanical Problems
Chapter 50 Engine Removal and Disassembly
Chapter 51 Engine Sealing, Gaskets, Fastener Torque
Chapter 52 Engine Diagnosis and Service: Cylinder Head and Valvetrain
Chapter 53 Engine Diagnosis and Service: Block, Crankshaft, Bearings, and Lubrication System
Chapter 54 Engine Diagnosis and Service: Piston, Piston Rings, Connecting Rod, Engine Balancing
Chapter 55 Ordering Parts, Short and Long Blocks, Engine Assembly
Chapter 56 Engine Installation, Break in, and In-Chassis Repairs
SECTION 10. BRAKES AND TIRES
Chapter 57 Brake Fundamentals
Chapter 58 Brakes Service
Chapter 59 Anti-lock Brakes - Traction and Stability Control
Chapter 60 Bearings, Seals, and Greases
Chapter 61 Tire and Wheel Theory
Chapter 62 Tire and Wheel Service
SECTION 11. SUSPENSION, STEERING, ALIGNMENT
Chapter 63 Suspension Fundamentals
Chapter 64 Suspension System Service
Chapter 65 Steering Fundamentals
Chapter 66 Steering Service
Chapter 67 Wheel Alignment Fundamentals
Chapter 68 Wheel Alignment Service
SECTION 12. DRIVE TRAIN
Chapter 69 Clutch Fundamentals
Chapter 70 Clutch Diagnosis and Service
Chapter 71 Manual Transmission Fundamentals
Chapter 72 Manual Transmission Diagnosis and Service
Chapter 73 Automatic Transmission Fundamentals
Chapter 74 Automatic Transmission Diagnosis and Service
Chapter 75 Driveline Operation
Chapter 76 Driveline Diagnosis and Service
Chapter 77 Front Wheel Drive (Transaxle and CV Joints) Fundamentals
Chapter 78 Front Wheel Drive (Transaxle and CV Joints) Service
Chapter 79 Driveline Vibration
Tài liệu đào tạo bảo dưỡng sửa chữa ô tô.
Tất cả đều định dạng .PPT.
Download Now
[O-H] Automotive Service Inspection, Maintenance, Repair, 3rd Edition.txt 0361 bytes · Xem: 74
