[O-H] Advanced Engine Performance Diagnosis, 5E James D. Halderman
test
Bình luận: 3Lượt xem: 2,114
test
Table of Contents
Chapter 1 The Diagnostic Process
Chapter 2 CAN and Network Communications
Chapter 3 On-Board Diagnosis
Chapter 4 Global OBD II and Mode $06
Chapter 5 Circuit Testers and Digital Meters
Chapter 6 Oscilloscopes and Graphing Multimeters
Chapter 7 Starting and Charging System Diagnosis
Chapter 8 Ignition System Operation
Chapter 9 Ignition System Diagnosis
Chapter 10 Gasoline, Alternative Fuels and Diesel Fuels
Chapter 11 Temperature Sensors
Chapter 12 Throttle Position (TP) Sensors
Chapter 13 MAP/BARO Sensors
Chapter 14 Mass Air Flow (MAF) Sensors
Chapter 15 Oxygen Sensors
Chapter 16 Wide-Band Oxygen Sensors
Chapter 17 Fuel Trim Diagnosis
Chapter 18 Fuel Pumps, Lines, and Filters
Chapter 19 Fuel Injection Components and Operation
Chapter 20 Gasoline Direct Injection Systems
Chapter 21 Electronic Throttle Control Systems
Chapter 22 Fuel Injection System Diagnosis and Service
Chapter 23 Vehicle Emission Standards and Testing
Chapter 24 Emission Control System Devices, Operation, and Diagnosis
Chapter 25 Engine Condition Diagnosis
Chapter 26 In-Vehicle Engine Service
Chapter 27 Symptom-Based Diagnosis
Bài giảng kỹ thuật chẩn đoán động cơ rất hay và đẳng cấp của James D. Halderman.
Tất cả đều định dạng .PPT, link Mediafre.
