Mitchell OnDemand 5.8.2.35.portable
test
Bình luận: 12Lượt xem: 4,486
test
Không cần cài đặt, chỉ tải về và sử dụng.
Nếu sử dụng không được thì dùng key điền vào là OK, với điều kiện là ngắt kết nối Internet nhé, mới crack được.
Lấy không được key, thì gửi mình ID, sẽ gửi lại key Repair và Etimator.
Link key và Crack:
Mã:
http://www.filefactory.com/file/18j2kl82tn7l/Key_and_Crack_of_Mitchell_OnDemand_2012.rar
Ví dụ:
ID_ 01114 40667
Repair: HQC9-HFVW-C4T4-HHVJ-F92S-UEQJ
Etima: N2L9-HFVW-C4T4-HAZY-XWPE-7EQJ
Link download data - 200 điểm/DVD:
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-1-a-194046.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-2-a-194047.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-3-a-194048.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-4-a-194050.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-5-a-194051.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-6-a-194065.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-7-a-194066.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-8-a-194067.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-9-a-194068.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-10-a-194069.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-11-a-194124.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-12-a-194125.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-13-a-194126.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-14-a-194127.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-15-a-194128.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-repair-16_end-194129.html
http://www.oto-hui.com/diendan/f454/mitchell-ondemand-v5-8-2-35-q2-2012-estimator-194130.html
phungquochuy
1. link data 16DVD repair và 1 DVD estimator ở đâu bác ơi, vui lòng nhắn cho link nhé,
2. không down được key and crack bác ơi.
nhờ bác chỉ giúp.
email: phungquochuy@gmail.com
cảm ơn.
powercar
Ðề: Mitchell OnDemand 5.8.2.35.portable
Bác test ơi em cài nhưng lại hiện nên lỗi này là sao bác bác chỉ giúp em nha cảm ơn bác trước .
dungtt
nếu cụ đã từng cài onderman của 2012 thì 2013 cũng như thế có cần vì phải có đĩa Etimator mới cài được đâu. như những cách cài điền ID để lấy key thì phải kết nối internet để dịch, đối với onderman dùng mạng vẫn cài được hoàn toàn bình thường. Trong file mà cụ test đưa nên đã có bản crack nằm trong phần fix, các cụ không để file mặc định vào ổ c nữa mà để vào ổ d, sau đó copy file crack nằm trong thư mục fix copy vào thư mục cái là xong. xong đó up dữ liệu là ok chúc các cụ thành công
hanhthuy1990
em chưa cài bản nào cả nên hơi khó bác ạ. trên link bác test đưa lên em chẳng down được. hình như link hỏng rồi thì phải. bác có thể nói rõ hơn cho em được không ạ.
bichbinhthuan
Link key và Crack:
Mã:
Ví dụ:
ID_ 01114 40667
bác cho e xin sdt dc ko :)
