MICROCAT Ford Europe 10.2009 Multilanguage
ot2
ot2
Bình luận: 2Lượt xem: 2,229
ot2
MICROCAT Ford Europe 10.2009 Multilanguage | 1.53GB
Electronic parts catalog for Ford's European assembly. Provides information on passenger and light commercial vehicles.
Year: 2009
Version: 10.2009 (2.1.7.13)
Platform: PC, Windows
Compatibility with Vista: compatible with the x86 (32), is incompatible with x64
Language: multi-language
With the full installation (program + data) takes about 4,3 GB. Rolling back the date is not required (working without a rollback to February 2011). Completely redesigned distribution, simply run setup.exe and specify the installation path. Tablets not needed. Whereas previously there were previous versions MICROCAT Ford, do not forget to remove them before installing, otherwise there may be problems with the definition of the actual database directory (when you run the program enumerates all logical drives (except for Z:) and looking for a folder FEU_DATA, as well as zero-length file in mc1234 root directory). This network was established to work - just put FEU_Data mc1234 and the windows share folder and assign the network drive letter. When installed on a client places uncheck "Data".
Detailed instructions for network installation
Suppose we have 3 computers: two workstations (FC1, FC2) and server (S1). At C1 create a folder, for example, MCSHARE and make it a network share ( "rassharivaem" in computer parlance). Set mikrokat at C1 and then copy the file and FEU_Data 1234 network share. On the FC1 and FC2 assign resources \ \ C1 \ MCSHARE network drive letter (except for Z:), for example, X: When you install mikrokata in one of the windows will be prompted to select components - "Program" and "Data". With "data" remove a tick and put only the program on a local hard disk. After this program for FC1 and FC2 are working at the same time, almost without taking up space on your hard disk, data is stored on the server.
Or in other words, there are only two workstations - FC1 and FC2. At FC1 put mikrokat entirely on a local drive, for example, C:, and also makes the disks available on a network resource. On PC2 assign the same resource, the letter and put only the program, as in the first example.
Extras. Information: If you are having problems starting to remove them, please read! readme.txt or! readme_eng.txt (english version). The program has upgraded the data in the middle of the month (Midmonth update) from October 2009
Download from uploading
[HIDE]http://uploading.com/files/6a9f1c3e/Ford_E..._10.part01.rar/
http://uploading.com/files/am9f3d31/Ford_E..._10.part02.rar/
http://uploading.com/files/9f29254f/Ford_E..._10.part03.rar/
http://uploading.com/files/f9m2fbbb/Ford_E..._10.part04.rar/
http://uploading.com/files/277e9df6/Ford_E..._10.part05.rar/
http://uploading.com/files/2ebf156c/Ford_E..._10.part06.rar/
http://uploading.com/files/147c8d69/Ford_E..._10.part07.rar/
http://uploading.com/files/aa2a2e2b/Ford_E..._10.part08.rar/
http://uploading.com/files/5a2ed119/Ford_E..._10.part09.rar/
http://uploading.com/files/bbb521b8/Ford_E..._10.part10.rar/
http://uploading.com/files/3fdb13a4/Ford_E..._10.part11.rar/
http://uploading.com/files/1dba5ba3/Ford_E..._10.part12.rar/
http://uploading.com/files/me4f8211/Ford_E..._10.part13.rar/
http://uploading.com/files/3fm36b6b/Ford_E..._10.part14.rar/
http://uploading.com/files/57d9bb76/Ford_E..._10.part15.rar/
http://uploading.com/files/8c4ab577/Ford_E..._10.part16.rar/[/HIDE]
Mirror hotfile
[HIDE]http://hotfile.com/dl/18008868/5d18358/For...t_10.part01.rar
http://hotfile.com/dl/18008988/c7190c4/For...t_10.part02.rar
http://hotfile.com/dl/18008996/6048076/For...t_10.part03.rar
http://hotfile.com/dl/18008999/84e1a3b/For...t_10.part04.rar
http://hotfile.com/dl/18009005/2b66452/For...t_10.part05.rar
http://hotfile.com/dl/18009021/348176d/For...t_10.part06.rar
http://hotfile.com/dl/18009022/0120482/For...t_10.part07.rar
http://hotfile.com/dl/18009028/76facc0/For...t_10.part08.rar
http://hotfile.com/dl/18008718/6b7206e/For...t_10.part09.rar
http://hotfile.com/dl/18008720/0b1c9be/For...t_10.part10.rar
http://hotfile.com/dl/18008713/f621639/For...t_10.part11.rar
http://hotfile.com/dl/18008717/a959b26/For...t_10.part12.rar
http://hotfile.com/dl/18008714/a4b461d/For...t_10.part13.rar
http://hotfile.com/dl/18008719/03f60a4/For...t_10.part14.rar
http://hotfile.com/dl/18008715/254eb23/For...t_10.part15.rar
http://hotfile.com/dl/18008716/309008a/For...t_10.part16.rar[/HIDE]
Mirror rapidshare
[HIDE]http://rapidshare.com/files/309206994/Ford...t_10.part01.rar
http://rapidshare.com/files/309207006/Ford...t_10.part02.rar
http://rapidshare.com/files/309207066/Ford...t_10.part03.rar
http://rapidshare.com/files/309205663/Ford...t_10.part04.rar
http://rapidshare.com/files/309205447/Ford...t_10.part05.rar
http://rapidshare.com/files/309205806/Ford...t_10.part06.rar
http://rapidshare.com/files/309205824/Ford...t_10.part07.rar
http://rapidshare.com/files/309205539/Ford...t_10.part08.rar
http://rapidshare.com/files/309205526/Ford...t_10.part09.rar
http://rapidshare.com/files/309205673/Ford...t_10.part10.rar
http://rapidshare.com/files/309205764/Ford...t_10.part11.rar
http://rapidshare.com/files/309206629/Ford...t_10.part12.rar
http://rapidshare.com/files/309206720/Ford...t_10.part13.rar
http://rapidshare.com/files/309206854/Ford...t_10.part14.rar
http://rapidshare.com/files/309206836/Ford...t_10.part15.rar
http://rapidshare.com/files/309206439/Ford...t_10.part16.rar[/HIDE]
