MÃ LÕI 63 TRÊN DETROIT 12.L 2004 CẦN GIÚP ĐỞ.
L
Bình luận: 2Lượt xem: 994
TÌNH HÌNH LÀ XE E CÓ BÁO LỖI 63....NHƯNG E CHƯA HIỂU TỪ:BỘ TRUYỀN ĐỘNG PWM LÀ GÌ? XIN CẢM ƠN ANH E TRƯỚC:(
Cụ xem cái này:
PWM trên xem tại gắc nối vào hộp đen nhé
nguyenhoangha
thím xem hộ em cái này!
DESCRIPTION OF FLASH CODE 63
Flash Code 63 indicates that the pulse width modulation (PWM) output(s) used is either shorted to battery positive or open-circuited.
SAE J1587 EQUIVALENT CODE FOR FLASH CODE 63
The SAE J1587 equivalent code for Flash Code 63 is s 057/3, or s 057/4, or s 058/3, or s 058/4.
Flash Code SID FMI Description
63 s 57 0 PWM #1 (V 52) above normal range
63 s 57 1 PWM #1 (V 52) below normal range
63 s 57 3 PWM #1 (V 52) short to battery
63 s 57 4 PWM #1 (V 52) open circuit
63 s 57 7 PWM #1 (V 52) mechanical system failure
63 s 58 0 PWM #2 (V 46) above normal range
63 s 58 0 PWM #2 (V 46) below normal range
63 s 58 3 PWM #2 (V 46) short to battery
63 s 58 4 PWM #2 (V 46) open circuit
63 s 58 7 PWM #2 (V 46) mechanical system failure
63 s 59 0 PWM #3 (E 01) above normal range
63 s 59 1 PWM #3 (E 01) below normal range
63 s 59 3 PWM #3 (E 01) short to battery
63 s 59 4 PWM #3 (E 01) open circuit
63 s 59 7 PWM #3 (E 01) mechanical system failure
63 s 60 0 PWM #4 (E 04) above normal range
63 s 60 1 PWM #4 (E 04) below normal range
63 s 60 3 PWM #4 (E 04) short to battery
63 s 60 4 PWM #4 (E 04) open circuit
63 s 60 7 PWM #4 (E 04) mechanical system failure
63 s 267 0 PWM #5 (E 08) above normal range
63 s 267 1 PWM #5 (E 08) below normal range
63 s 267 3 PWM #5 (E 08) short to battery
63 s 267 4 PWM #5 (E 08) open circuit
63 s 267 7 PWM #5 (E 08) mechanical system failure
63 s 268 0 PWM #6 (E 11) above normal range
63 s 268 1 PWM #6 (E 11) below normal range
63 s 268 3 PWM #6 (E 11) short to battery
63 s 268 4 PWM #6 (E 11) open circuit
63 s 268 7 PWM #6 (E 11) mechanical system failure
Copyright © Detroit Diesel Corporation 2004 - All information subject to change without notification
