Thought this could come in handy!
i need to replace my fuse as my cigarette lighter doesnt work.. in finding out what fuse to replace i found i cannot drive my car.. as i have no reversing lights!
Corsa B 1993 - 1997 - 12-2 (in Haynes)
Fuse 1 - 20 Amp - Hazard Warning Lights, Horn, Anti-theft Alarm & Interior Lights
Fuse 2 - 10 Amp - Automatic Transmission
Fuse 3 - 30 Amp - Heated Rear Window
Fuse 4 - 10 Amp - Daytime Driving Lights
Fuse 5 - 10 Amp - Automatic Transmission (Yes again)
Fuse 6 - 10 Amp - Rear Foglights
Fuse 7 - 30 Amp - Air Conditioning
Fuse 8 - 10 Amp - LH Sidelight & Tail-light & Headlight beam adjustment system
Fuse 9 - 20 Amp - Front Foglights
Fuse 10 - 10 Amp - Left Hand (LH) Main Beam
Fuse 11 - 30 Amp - Headlight Washer System
Fuse 12 - 10 Amp - LH Dipped Beam & Headlight Beam Adjustment System
Fuse 13 - 20 Amp - Central Locking System
Fuse 14 - ......... - Not Used
Fuse 15 - 30 Amp - Heater Blower Motor, Radiator Cooling Fan, Air Conditioning System
Fuse 16 - 30 Amp - Windscreen Wipers
Fuse 17 - 10 Amp - Radio, MFD, Instrument Panel, Glovebox Light, Electric External Mirrors
Fuse 18 - 20 Amp - Central Locking System, Reversing Lights, Cigarette Lighter & Automatic Transmission.
Fuse 19 - 20 Amp - Electric Sunroof
Fuse 20 - 30 Amp - Radiator Cooling Fan
Fuse 21 - 15 Amp - Stop Lights & Hazard Warning Lights
Fuse 22 - 10 Amp - Anti-lock Braking System (ABS)
Fuse 23 - 10 Amp - RH Sidelight & Tail light, & Headlight Beam Adjustment System
Fuse 24 - ......... - Not Used
Fuse 25 - 10 Amp - Right Hand (RH) Main Beam
Fuse 26 - 20 Amp - Fuel Injection System
Fuse 27 - 10 Amp - RH Dipped Beam & Headlight Beam Adjustment System
Fuse 28 - 30 Amp - Electric Windows
* - 10 Amp - Anti Theft Alarm
Note: Not all items fitted to all models
*Located in the engine compartment junction box
That took bloody ages, hope it helps some problems
