tinhnguyen3688
Khách
Ford ECAT 2012-02
Dung lượng: 5.73G
Auto Parts Catalog Ford (Ford) contains a catalog of parts for all models of Ford cars, jeeps, light commercial, produced for the European market.
The "online catalog of spare parts FORD" provides the most complete composition of units and vehicles are not only taking into account the features of models, but also changes within the kitting. This makes it possible to select a qualified Ford parts except the wrong orders.
Using the Ford ECat dealer program significantly increases the efficiency of daily work of specialists in repair, car maintenance, managers of organizations that sell avotozapchastyami Ford.
Electronic parts catalog Ford Ecat - a system for identifying and sending orders for parts and services, intended for all European dealers Ford. This system provides functions to access advanced search and content, and also connects to the DMS and other systems Ford.
FordEcat comes to DVD and installed from DVD.
There are different installation procedures for different types of installation:
• The first installation
• install a different version FordEcat to replace an already installed version of
• re-install the same version FordEcat over an installed program.
FordEcat integrated with other information systems and systems management of Ford, which allows to use all of its properties on the vehicle configuration and retrieval of information and subsequently use the results to another application. In addition, the data stored in FordEcat can be copied and moved to set up other programs FordEcat.
Extras. Information: Installation runs through the start.exe
Further, on the machine where the set start IExplorer (IMPORTANT! Other browsers may not work!) 6.0 - 8.0, to drive http://localhost:8080/Ford
Login: Admin
Password: sa
Also, when you first start will need to allow an ActiveX control called ISOView. IE security settings should be standard for all areas!
Year / Date: 2012-02
Version: 0C1HJ
Language: Multilingual
Medicine: Present
Dung lượng: 5.73G
Login: Admin
Password: sa
Version: 0C1HJ
Medicine: Present
