Cụ thương thì thương cho chót ạ. Em nó là cứ bị nhảy qua nhảy lại giữa 2 số. 1 lúc mới chịu dừng. Cụ có hình vẽ hay thang thuốc nào hốt dup nhà cháu với ạE 1. ⇒ movement of gear shifting cylinder during the closing phase of the clutch.
E 2 ⇒ clutch remained open.
E 3 ⇒ clutch remained closed.
E 4 ⇒ gear shifting cylinder does not move.
E 5 ⇒ gear shifting cylinder moves, but it does not select the speed chosen.
E 6 ⇒ movement of the gear shifting cylinder is monitored during the initial phase of the shifting.
E 7 ⇒ movement of the shifting cylinder too fast.
E 8 ⇒ movement of the shifting cylinder during the opening phase of the clutch.
