ELSA 3.61 Seat 02/2009
V
Bình luận: 0Lượt xem: 1,302
vothanhtam19
Information base for the diagnosis and repair of motor vehicles Concern Seat. Contains description of technology of repair, auto maintenance, diagnosis of various vehicle systems, electrical circuits, body works, the rules of time for work performed, etc.
Year: 2009
Version: 02.2009
Language: All available
Extras. Information: This archive contains all the necessary components for installation: 3.6 setup, 3.61 update, base Seat 02.2009, serial numbers, key generator and installation instructions. All components are in an easy to install and does not require an additional program.
Install info:
1. Set AcrobatReader.
2. Set ElsaWin 3.6 folder ELSA 3.6 Setup (take the number of sn.txt - at the end of the installation use the keygen for the response code).
3. Install update 3.61 from the folder, ELSA 3.61 Update.
4. Set SWGviewer folder ELSA 3.6 Setup.
5. Set the base folder VW ELSA 3.6 VW 02.2009.
6. If there are other bases - they just set.
Installation is complete!
Then run ElsaWin Administration (username / password: admin / admin) and create user (s).
Running - the label ElsaWin
hidden text
For those who use ELSA in a client-server and a server uses no server OSes such as XP Professional, must remember that beyond the number of 10 pieces simultaneously connected clients will get all subsequent denial when you connect. This limitation is due to the architecture XP Professional (in 2003 server, this number is 32 and over). Therefore, those who are faced with a problem I can advise to download a patch Windows LanServer Connectionlimit patch, solves this problem. To see the current value of this restriction, at the command prompt, type net config server and in the "Maximum number of users" will be your value. In XP Pro it equals 10.
Download Links :
HotFile:
hotfile.com ELSA_3.61_Seat_02.2009r.part01.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part02.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part03.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part04.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part05.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part06.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part07.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part08.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part09.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part10.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part11.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part12.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part13.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part14.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part15.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part16.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part17.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part18.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part19.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part20.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part21.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part22.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part23.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part24.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part25.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part26.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part27.rar.html
hotfile.com ELSA_3.61_Seat_02.2009r.part28.rar.html
RapidShare:
rapidshare.com ELSA_3.61_Seat_02.2009r.part01.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part02.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part03.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part04.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part05.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part06.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part07.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part08.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part09.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part10.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part11.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part12.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part13.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part14.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part15.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part16.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part17.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part18.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part19.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part20.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part21.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part22.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part23.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part24.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part25.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part26.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part27.rar
rapidshare.com ELSA_3.61_Seat_02.2009r.part28.rar
