Mitchell OnDemand 5.8.2.35 Repair (3Q 2011) - Complete package | 85.3 GB
Mitchell On Demand5 Repair, repair information database contains descriptions of the vehicle technology maintenance and repair, diagnostic manuals, parts catalogs, wiring diagrams, bodywork, repair manual manual and automatic transmissions. Mitchell On Demand5 is one of the best programs for auto repair and serves as an indispensable tool for garages involved in servicing and repairing cars. In the package with all the DVD database, installation CDversion.
Name: Mitchell OnDemand 5.8.2.35 Repair
Version: 5.8.2.35
Developer: Mitchell1
Category: Auto, DB
Language: English (USA)
Platform / OS: WinXP - Win7 (32/64-bit)
Activating: Keygen + detailed instructions
File Format: .ISZ
Daignosis and Repair - section on repair and diagnostics - the location of identity, especially a device separate mechanisms, standards of various parameters (volume of gas tanks, wheel alignment, etc.) used diagnostic and repair equipment and special tools, job descriptions for assembly, disassembly , adjustment, repair and diagnostic information about the location of the components and mechanisms, etc. specifically for the diagnostician the following information: location of the diagnostic socket, detailed tables of the transcripts of fault codes indicating the possible causes of failure, symptoms, and the sequence of tests to resolve the problem, a description of the content read blocks of the current parameters, indicating normal values, working with channel adaptation, etc. The information in the section is divided into blocks:
- All Diagnostic Trouble Codes (DTC)
- Relays and Modules
- Sensors and Switches
- Maintenance
- Engine, Cooling and Exhaust
- Powertrain Management
- Transmission and Drivetrain
- Brakes and Traction Control
- Starting and Charging
- Power and Ground Distribution
- Steering and Suspension
- Heating and Air Conditioning
- Restraint Systems
- Accessories and Optional Equipment
- Body and Frame
- Cruise Control
- Instrument Panel, Gausses and Warning Indicators
- Lighting and Horns
- Windows and Glass
- Wiper and Washer Systems
Parts and Labour - in this section, you can get the original part numbers, illustrations and prices of spare parts in USD. This section also provides information on the bodywork. You can quickly make a calculation of all types of work for any car.
Popular Information - The most important information presented in the program.
Diagnostic Trouble Codes DTC - Diagnostic Trouble Codes malfunction (causes decoding errors and how to eliminate them).
Technical Service Bulletins - Technical bulletins serisnye.
Specifications - Specifications (electrical, mechanical, gas volumes and types of liquids, etc.).
Locations - location of the components (fuses, relays, control units, switches, sensors, solenoids, motors, etc.).
Diagrams - diagnostic information and instructions on how to ustaraneniyu faults, wiring diagrams, layout of connectors and their pinouts, vacuum diagrams, types of wiring harnesses, and their location, etc.
Service Precautions - Safety Instructions.
Technician Safety Information - Technical Information on safety.
Vehicle Damage Warnings - Information on safety when performing any types of work (eg work with airbags AirBag).
Vehicle Identification - Location identification plate car.
Tools and Equipment - Instruments and necessary diagnostic equipment.
System Diagnosis
Five-Step Troubleshooting
Troubleshooting Precautions
Troubleshooting Tests
General Troubleshooting
Power Relay Test
Full list of models available on each disc Mitchell OnDemand- look in the file xxx_DVD-LIST.rtf and/or in the archive with the installation CD. This file is also available on each file-exchanger in the section Download.
Installation instructions - See in the archive containing the installation CD (detailed description with pictures).
- In the archive "MOD_Install.CD_xxx.RAR" are: Installation CD + Portable version and detailed installation instructions.
Additional Information:
- In this version, finally made a new type of activation - without the floppy and virtual drives. Keygen is attached.
- The program is easy to put on Win 7 x64 and works with drives Q1.2011.
Links download:
HƯỚNG DẪN DOWNLOAD
Các bạn vào trang sau đây:
Sau đó các bạn đăng nhập vào bằng Usename và Password mà mình cung cấp cuối bài
Khi đăng nhập thành công, các bạn click vào Remote Downloader
Dán links Mitchell vào như hình
Nhấp vào Sumit. Nếu thành công sẽ như thế này:
Dùng IDM down về thôi.
Usename Và Pass ngày 19/09/2012
Lưu ý: Mỗi acc chỉ sống được 1 ngày. Nếu quá nhiều người cùng sử dụng acc thì có thể bạn sẽ không đăng nhập được.
Mình sẽ cố gắng Update acc thường xuyên cho các bạn.
Chúc thành công.
Version: 5.8.2.35
Category: Auto, DB
File Format: .ISZ
- Maintenance
- Restraint Systems
- Body and Frame
- Cruise Control
- Windows and Glass
System Diagnosis
Power Relay Test
Links download:
Mã:
[COLOR="#0000FF"]http://www.netload.in/dateizWgQM1ZtUt/3qmo.part01.rar.htm
http://www.netload.in/dateiXo9Cjt7eF9/3qmo.part02.rar.htm
http://www.netload.in/dateiZq8oH42oWv/3qmo.part03.rar.htm
http://www.netload.in/dateioXojd0KxUG/3qmo.part04.rar.htm
http://www.netload.in/datei74Cv5v3MzA/3qmo.part05.rar.htm
http://www.netload.in/datei4z6JDLsSJ2/3qmo.part06.rar.htm
http://www.netload.in/dateiSjIoj9Akku/3qmo.part07.rar.htm
http://www.netload.in/dateiDB7H7zD9bI/3qmo.part08.rar.htm
http://www.netload.in/dateiXsYOUQn0PM/3qmo.part09.rar.htm
http://www.netload.in/dateikKqn4TwbIo/3qmo.part10.rar.htm
http://www.netload.in/dateiuST5aRhoWU/3qmo.part11.rar.htm
http://www.netload.in/dateiIAq7OachTa/3qmo.part12.rar.htm
http://www.netload.in/datei5kw5Jfj59G/3qmo.part13.rar.htm
http://www.netload.in/dateiRKD6VatN6i/3qmo.part14.rar.htm
http://www.netload.in/datei3Mw1cQZPp6/3qmo.part15.rar.htm
http://www.netload.in/dateiGdla1rSK1H/3qmo.part16.rar.htm
http://www.netload.in/dateibHxbiU5Gdh/3qmo.part17.rar.htm
http://www.netload.in/dateiuh2LYTRMLD/3qmo.part18.rar.htm
http://www.netload.in/datei9yEBe4FrSL/3qmo.part19.rar.htm
http://www.netload.in/datei1aagt6esnk/3qmo.part20.rar.htm
http://www.netload.in/dateiwOWOBecEHN/3qmo.part21.rar.htm
http://www.netload.in/dateiojXhSCzIcP/3qmo.part22.rar.htm
http://www.netload.in/dateiSb7Ggf4kA8/3qmo.part23.rar.htm
http://www.netload.in/datei1ZYxb1EYGl/3qmo.part24.rar.htm
http://www.netload.in/dateiwaV6mLhezn/3qmo.part25.rar.htm
http://www.netload.in/dateiYh11S7GGOX/3qmo.part26.rar.htm
http://www.netload.in/dateibZ3ZdvoxHf/3qmo.part27.rar.htm
http://www.netload.in/dateiIlV41JWeMI/3qmo.part28.rar.htm
http://www.netload.in/dateih0KJvnyjUt/3qmo.part29.rar.htm
http://www.netload.in/dateiFR4ZBDmHw0/3qmo.part30.rar.htm
http://www.netload.in/dateiClIzwnsjTd/3qmo.part31.rar.htm
http://www.netload.in/datei4q6Gdrcmnc/3qmo.part32.rar.htm
http://www.netload.in/dateiW3bsYk7EL9/3qmo.part33.rar.htm
http://www.netload.in/datei3otJ5Qkx12/3qmo.part34.rar.htm
http://www.netload.in/dateijhBBJX2LKE/3qmo.part35.rar.htm
http://www.netload.in/dateiLvFGAYhdSV/3qmo.part36.rar.htm
http://www.netload.in/dateitfGcgk4nD3/3qmo.part37.rar.htm
http://www.netload.in/dateivvE5LtUAU2/3qmo.part38.rar.htm
http://www.netload.in/datei6dWONXHxVw/3qmo.part39.rar.htm
http://www.netload.in/dateiuiIYt9Ljg4/3qmo.part40.rar.htm
http://www.netload.in/datei8OJS9t8MP8/3qmo.part41.rar.htm
http://www.netload.in/dateiND8NM4VIVI/3qmo.part42.rar.htm
http://www.netload.in/dateizHJ7Rg9mrO/3qmo.part43.rar.htm
http://www.netload.in/dateizPuFIuutdX/3qmo.part44.rar.htm[/COLOR]
HƯỚNG DẪN DOWNLOAD
Mã:
[COLOR="#0000FF"]http://speedyshare.com/[/COLOR]
Mã:
username: u13591924
password: mobanarujinu
Mã:
username: u13591927
password: silulahesufi
Chúc thành công.
