điện thân xe mazda
V
Bình luận: 0Lượt xem: 1,941
vothanhtam19
Nội dung :
Wiring Diagrams, Understanding Diagrams, Lighting Systems Headlights Page L-1, 2. Turnsignals & Hazard Page L-2, 3. Stop Lights Page L-3, 4.Backup / Horn Page L-4 Accessories Systems 1. Power Windows Page A-1 2. Power Mirrors Page A-2 3. Door Locks Page A-3 4. Clock & Cig Lighter Page A-4 5. Front Wiper & Washer Page A-5 6. Blower Page A-6.
1. Trace in GREEN the portion of the circuit below that you suspect could be at fault. Both TURN SIGNAL do not work, but the Hazard lamps do work correctly.
2. Trace in RED the portion of the circuit below that you suspect could be at fault. The LEFT TURN SIGNAL does not work. The Hazard Lamps function normally.
3. Trace in BLUE the portion of the circuit below that you suspect could be at fault. The HAZARD LAMPS do not work. The Turn Signal Lamps function normally.
4. Trace in ORANGE the portion of the circuit below that you suspect could be at fault. Both the HAZARD LAMPS and the TURN SIGNAL LIGHTS do not work in any Position.
Ngôn ngữ tiếng anh.
