Đèn cờ lê sáng - check mã lỗi P0170
K
Bình luận: 7Lượt xem: 1,355
kenshinjar
Các bác, xe đáng đi thì đèn báo cờ lê sáng, cắm cổng odb máy báo lỗi P0170, và kiểm tra thì một số sensor báo lỗi sau. Em ko hiểu nhiều về kỹ thuật, các bác giúp em lỗi này phải xử lý ntn ạ.
Test report:
MID:$01 TID:$0a
Sensor period(calculated) - O2 Bank 1 Sensor 1
Max: 2,400ms Min: 0ms
Test result value: 600ms
PASS
MID:$21 TID:$0a
Sensor period(calculated) - Catalyst Monitor Bank 1
Max: 40Count Min: 0Count
Test result value: 1,164Count
FAIL
MID:$39 TID:$80
Max: 2,048Pa Min: 0Pa
Test result value: 2,048Pa
PASS
MID:$3a TID:$80
- EVAP Monitor (cap off)
PASS
MID:$3b TID:$80
- EVAP Monitor (0.090")
Max: 0.03233inch Min: 0inch
Test result value: 0inch
PASS
MID:$41 TID:$80
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 0.1A Min: 0A
Test result value: 0.583A
FAIL
MID:$42 TID:$80
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 0.1A Min: 0A
Test result value: 0.555A
FAIL
MID:$81 TID:$85
- Fuel System Monitor Bank 1
Max: 18 Min: -18
Test result value: -7.1
PASS
MID:$81 TID:$86
Test incomplete or dependant test failed
MID:$9f TID:$f4
Max: 8,192 Min: 6,241
Test result value: 2,888
FAIL
MID:$a1 TID:$86
- Misfire Monitor General Data
Max: 65,535 Min: 0
PASS
End of report.
Test report:
MID:$01 TID:$0a
PASS
MID:$21 TID:$0a
FAIL
MID:$39 TID:$80
PASS
MID:$3a TID:$80
PASS
MID:$3b TID:$80
PASS
MID:$41 TID:$80
Max: 0.1A Min: 0A
FAIL
MID:$42 TID:$80
Max: 0.1A Min: 0A
FAIL
MID:$81 TID:$85
Max: 18 Min: -18
PASS
MID:$81 TID:$86
MID:$9f TID:$f4
FAIL
MID:$a1 TID:$86
Max: 65,535 Min: 0
PASS
End of report.
P0170 là cái gì, bác phải đưa cụ thể chứ
