Đặc tính động cơ Toyota 2E, 4E, 4AGE, 4AGZE, 1JZ-GTE, 2JZ GTE
khoadongluc
Bình luận: 1Lượt xem: 7,872
khoadongluc
Nothing Is Impossible
2E-TE/TELU
Used in: Toyota Starlet EP71, EP81, EP90
Valvetrain : SOHC
FI:Turbocharged
Displacement : 1296cc
Bore : 73.0 mm
Stroke : 77.4 mm
Gearbox : C152
Power - 2E-TE :101hp
2E-TELU :110hp
4E-FTE
Toyota Starlet 4E
Used in: Starlet GT Turbo, Starlet Glanza V
Valvetrain : DOHC
FI : Turborcharged
Displacement : 1331cc
Compression Ratio : 8.2:1
Bore : 74mm
Stroke : 77.4mm
Gearbox : C152
Power : 135HP@6400rpm
Torque : 157NM@4800rpm
4A-GE(16Valve)
4A-GE 16 VALVE
Used in:Toyota MR2 AW11(MR)
Corolla AE86 GT-S(RWD),
Corolla AE82 FX-16(FWD),
Corolla AE92 GT-S(FWD)
-FIRST/SECOND GENERATION(83-89)-
Valvetrain : DOHC 16Valve(TVIS)
Fuel System : MPFI(Multi Point Fuel Injection)
Displacement : 1587cc (straight 4)
Compression Ratio : 9.4:1
Bore : 81mm
Stroke : 77mm
Power : 112HP@6600rpm (US, MAF Sensor)
130HP@6600rpm(Japan, MAP sensor)
Torque : 131Nm@4800rpm
-THIRD GENERATION(REDTOP)-
Compression Ratio : 10.3:1
Bore : 81mm
Stroke : 77mm
Power : 138@7200rpm
Torque : 149Nm@4800 rpm
4AGE FORMULA ATLANTIC
-A modified 4A-GE(16valve) from Toyota Racing Development(TRD) for the Formula Atlantic cars.Producing a healthy 240bhp@8400rpm and revving out to 10-12000rpm.This is the engine that is rumoured as the engine in the Fujiwara Takumi Corolla AE86 Trueno(INITIAL D Anime/Manga)
4AGE SILVERTOP(20Valve)
4A-GE SILVERTOP 20VALVE
Used in:1992 Toyota Levin/Trueno AE101 GT Apex, GT-V Models
1992 Toyota Corolla AE101: GT, FX Models
Valvetrain : DOHC VVT(Variable Valve Timing)
Air Intake : Four Throttle, Airflow Sensor
Displacement :1587cc
Compression Ratio : 10.5:1
Bore : 81mm
Stroke : 77mm
Power : 158HP@7400rpm
Torque :162Nm@5200rpm
4AGE BLACKTOP
Used in:1995 Toyota Levin/Trueno AE111: BZG, BZR, BZV Models
1998 Toyota Corolla AE111: GT, Carib BZ, RSi Models
Air Intake : Four Throttle, MAP Sensor
Compression Ratio : 11:1
Bore : 81mm
Stroke : 77mm
Power : 162HP@7800rpm
4AGZE SUPERCHARGE
TOYOTA 4A-GZE SUPERCHARGED
Used In : supercharged AW11 Toyota MR2, AE92 Corolla, AE101 Corolla
FI:Supercharged
Bore : 81mm
Stroke : 77mm
Power - AW11 Toyota MR2 : 145HP
AE92, AE101 Corolla : 165HP
Torque – AW11 Toyota MR2 : 195Nm
AE92, AE101 Corolla :210Nm
1JZGTE
TOYOTA 1JZ-GTE
Used in:
Toyota Chaser/Cresta/Mark II Tourer V (JZX81, JZX90, JZX100, JZX110),
Toyota Soarer (JZZ30)
Toyota Supra MK III (JZA70)
Toyota Verossa
Toyota Crown (JZS170)
-FIRST/SECOND GENERATION-
FI:Twin Turbo Turbine : CT12 x2
Valvetrain : DOHC
Displacement : 2491cc
Compression Ratio : 8.5:1
Bore : 86.0mm
Stroke : 71.5mm
Power : 280HP@6200rpm
Torque : 363Nm@4800rpm
-THIRD GENERATION-
FI:Turbocharged
Valvetrain : DOHC VVT-i(continuously variable valve timing)
Compression Ratio : 9.0:1
Bore : 86.0mm
Stroke : 71.5mm
Torque :379Nm@2800rpm
2JZGTE
TOYOTA 2JZ-GTE
Used in:Toyota A341E 4-speed automatic
Toyota V160 and V161
Toyota Aristo V300 JZS161 (Japan-only)
Toyota Supra RZ/Turbo JZA80
FI:Twin Turbocharged
Valvetrain : DOHC (VVT-i 1997 and above)
Displacement : 2997cc
Bore : 86.0mm
Stroke : 86.0mm
Power : 280HP@5600rpm
Torque : 1993-96 – 437Nm@3600rpm (323 ft/lb)
1997+ – VVTi 458Nm@3600rpm (338ft/lb)
Abbreviation:FI=Forced Induction
DOHC=Double OverHead Cam
