cùng nhau dịch anh văn
Bình luận: 1Lượt xem: 1,647
thanhxuanoto
Main window toolbar button opening this window.
In this window main fuel properties are set.
The DIESEL-RK supports simulation of engine with different fuels. The properties of every fuel are kept in Libraries. There are two libraries: System Fuel Library and Project Fuel Library. First is intended for saving the properties of all fuels; second is intended for saving the properties of fuels used in current project.
User can assign the separate fuel for every operating mode of the engine.
System Fuel Library is kept in the system folder of the DIESEL-RK. This library includes different Groups of fuels: Diesel, BioFuel, Petrol, Gas, etc. Every Group of Fuels may include several fuels, for example BioFuel may include several blends of Soybean (SME) or Rapeseed Methyl Ester (RME) with Diesel Oil; each blend has own fractions of BioFuel and diesel oil. System Fuel Library is presented in the right side of the window. Fuel properties can not be amended in the System Fuel Library directly and ones are presented only for information. If some fuel property in Project Fuel Library differs from same in the System Fuel Library, value of last will be displayed by different color.
User can create own Groups of fuel and add new Fuels in the existing Groups. Mechanism "how to do it" is presented in Project Fuel Library description.
Symbols S and U means System fuel or User fuel. System fuel can not be deleted from System Fuel Library. User fuel can be deleted from System Fuel Library or its properties may be amended. Correction of User Fuel properties is possible only in the Project Fuel Library. To delete User Fuel from the System Fuel Library right click one in the right-top panel and select "Remove Fuel"
các bác nào giúp tớ vơi
email thanhxuan_oto07@yahoo.com.vn
vnv811
Cái nì đơn giản mà bạn. Sao không tự dịch để nâng trình của mình lên.
